Old Nov 25, 2012, 05:07 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Top is completely done. We also made the master templates for the center section. There are some changes to be made to them, but they are cut out.
invertmast is offline Find More Posts by invertmast
Old Nov 25, 2012, 05:42 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Sounds great! Are you planning to assemble the center section structure in the mold...unlike the WoW version?
pdawg is offline Find More Posts by pdawg
Old Nov 25, 2012, 05:45 PM
Joined Mar 2004
Yep,
We sure are! Basically all that the center section will involve, is painting and equipment install.
Old Nov 25, 2012, 06:06 PM
Joined Mar 2004
Templates were cut out and glued to some plywood:
Then my buddy Tom got to cutting out parts while I was doing the inlet molds:
Parts cut to shape. All that is left, is to make the wing tube notch's and figure out the lightning hole/battery tray arrangement:
Inlet molds with the first coat of surface resin applied:
Top half of the inlet molds completed:
Old Nov 26, 2012, 12:32 PM
worldraft is offline
Find More Posts by worldraft
worldraft's Avatar
Canada, ON, L'Orignal
Joined Sep 2006
What would it cost me for a copy of that plan?
worldraft is offline Find More Posts by worldraft
Old Nov 26, 2012, 02:09 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Check wings on the web...That is where the orig plan came from
Old Nov 26, 2012, 06:51 PM
worldraft's Avatar
Joined Sep 2006
I've been trying to go to the wings web site but I don't seem to find it so would you give me the whole address.
Jean
Old Nov 26, 2012, 06:55 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
http://www.wingsontheweb.com/
Here ya go
Old Nov 26, 2012, 07:06 PM
Joined Mar 2004
Gary and myself have an agreement that will allow me to include copies of my plans with our center sections without requiring you guys to buy a set of his 82" version.
Old Nov 28, 2012, 08:36 PM
thtaco is offline
Find More Posts by thtaco
thtaco's Avatar
United States, VA, Timberville
Joined Oct 2012
After work today started prep work for this saturdays work on the bottom part of the mold.
Flipped over the center section trimmed up the flange and rewaxed.
thtaco is offline Find More Posts by thtaco
Old Nov 28, 2012, 08:50 PM
Joined Mar 2004
And some more photo's:
I also have 3/4 of the panels lines drawn onto the outer wing panels. All that is left, is the panel lines on the bottom of one wing panel:
Old Nov 28, 2012, 09:05 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
erm..originals' Wings were as one piece plywood skinned surfaces.. as in virtually no visible or intended panel lines beyond the leading edge join seam and the movable surfaces.
Bare is offline Find More Posts by Bare
Old Nov 28, 2012, 09:09 PM
Joined Mar 2004
I'd say it is nearly impossible to have One single piece of plywood to skin that entire wing, there were "joints" in the skin, and that is essentially what I am replicating. granted they would be much smaller than a typical sheet-metal panel line, I can deal with it to give the wings some "life", as my experience with this paint and my FW-190 is that if you keep the primer over the tape light and then wet-sand down to the tape, the paint nearly fills in the panel line left when the tape is peeled.
Speaking of, I could even leave the tape on the surface and then it would be a small ridge instead of an indentation..
Things to ponder one still..
Oh, and the wingtip and curved LE at the tip was actually aluminum, so these area's will get flite-metal'd, along with the access hatch's.
Old Nov 29, 2012, 01:27 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Great work Invertmast!
And a nice building speed
Hope you make your F14 ready soon!
regards Martin
MaHö is offline Find More Posts by MaHö
Old Dec 01, 2012, 06:43 PM
Joined Mar 2004
The larger portion of thd bottom of the center section is molded. Tomorrow we will mold the bottom half of the inlet lips.
And on the subject of F14, i have a gentleman machining up parts for it. So i sillbe molding more components of that soon as well
Ho 229 Build northropn9m Flying Wings 154 Oct 22, 2009 05:42 PM
Building the Luftwaffe secret weapon - Horten Ho 9/229 XPHAM Electric Ducted Fan Jet Talk 107 Dec 15, 2005 01:31 PM
Ho 229 Tempest Electric Ducted Fan Jet Talk 0 Nov 05, 2004 03:39 PM
Jack Cooper's ho 229 (sting wing) mothflyer Slope 4 Sep 01, 2003 11:26 AM
Building the secret Luftwaffe weapon - Horten Ho 9/229 XPHAM Scale Kit/Scratch Built 14 Apr 01, 2003 08:26 PM
