Old Nov 18, 2012, 04:41 PM
thtaco is offline
Find More Posts by thtaco
thtaco's Avatar
United States, VA, Timberville
Joined Oct 2012
Lesson Learned ..... next weekend will be better.
thtaco is offline Find More Posts by thtaco
Old Nov 18, 2012, 04:56 PM
thtaco is offline
thtaco's Avatar
Joined Oct 2012
some pictures befor epoxy and cotton flox went to 250 degrees
Old Nov 18, 2012, 08:51 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Oh so close! stupid me
invertmast is offline Find More Posts by invertmast
Old Nov 19, 2012, 02:52 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Minor setback for a builder of your calibre
Btw,thanks for the parting board tutorial,clearest guide I've seen.
Regards Stuart
Stuart A is offline Find More Posts by Stuart A
Old Nov 24, 2012, 10:07 AM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
FANTASTIC plug work.
Around 20 years ago that happened to us once. Almost cost a Hawker Typhoon wing. Something one always considers once it happens.
For me personally, I think the plug work is where the talent is. It's the original.
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Nov 24, 2012, 10:57 AM
Joined Mar 2004
Thanks steve,
This plus isnt as nice as i would have liked it. There are a few areas that have some texture in the paint, but since it was a wood skinned aircraft, i left it as is. To me it looks like some wood grain showing through. They are shallow enough though that they are easily filled in during the final paint, heck they may just barely even transfer to the final parts. Time will tell!
Pva and the final coat of surface resin are applied. Ill start filling in corners and applying glass in about 1/2 hour
Old Nov 24, 2012, 07:35 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Its been pretty quiet for the last few hours....Invertmast and thtaco must be must laying down fiberglass on a successful gelcoat!!!!
pdawg is online now Find More Posts by pdawg
Old Nov 24, 2012, 08:20 PM
thtaco is offline
thtaco's Avatar
Joined Oct 2012
some pictures of mold work
invertmast woked on the mold for 13 hours straight. i started helping after work at around 2:00 finished at around 8:00
Old Nov 24, 2012, 08:22 PM
Joined Mar 2004
Top is molded. Tomorrow we will pop the partings planes around the inlets off and mold those, so the top will be completely molded by the end of the weekend. Next weekend, we will be doing the bottom. So by Dec. 1 we will have the center section completely molded.
Once completely molded, the mold will sit for 7 days to fully cure and while that happens, I will begin working on the internal structure "masters" so we can easily copy-cut multiples of the same parts.
Beginning of the molding process, the first layer of white surface resin has been applied:
13 hours of work later, The top is nearly done (just the inlets left).
Old Nov 24, 2012, 09:11 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
very nice.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 24, 2012, 09:14 PM
Joined Apr 2004
I have a question. On your glass reinforcement, the glass does not follow the rear of the jet engine housing down to the "fuse" section as shown in your surface coat.. Did you guys glass the section separately, then cover over it? Or are going to cut it out??
Also, why did you guys use white pigment in the surface coat?. We use black since it shows up all the voids in the glass work easier. Unless painting in the mold, then doesn't matter.
Your pics make me want to hurry up and get mine done too!
Steve
Old Nov 24, 2012, 09:35 PM
Joined Mar 2004
Steve,
An epoxy toing dough was used to fill in those areas and make a fairing to blend in the exhaust to the rest of the wing section
Old Nov 24, 2012, 09:54 PM
P. Richards is offline
Find More Posts by P. Richards
Swat Team Member
P. Richards's Avatar
LV, NV
Joined Apr 2003
Mixing cups
I have found out through working with Mach 2 Jets that a mixing plate works better than the cup for large projects. The chemical reaction is different and you have more time to add the epoxy vs it kicking off in a matter of minutes when you see the smoke rise from the cup. Ted Goodwin also used the plate method with great success with his molds for the F-16...
P. Richards aka SwatTeam
P. Richards is offline Find More Posts by P. Richards
Old Nov 24, 2012, 09:59 PM
Joined Mar 2004
Plates works well for really large quantities of resin if your cloth doesnt soak it up really fast.
The last few layers of cloth on the mold is 22oz cloth. It takes roughly 46oz of resin for one layer of this cloth on the horten.
When you have a cloth that takes that much resin, you dont brush it on, you literally pour it on and spread it, then leave it to soak in.
For lighter weight cloths, we only mix 125 grams of resin at a time
Old Nov 25, 2012, 09:29 AM
Joined Apr 2004
Thanks for the quick response ivertm.
Steve
Ho 229 Build northropn9m Flying Wings 154 Oct 22, 2009 05:42 PM
Building the Luftwaffe secret weapon - Horten Ho 9/229 XPHAM Electric Ducted Fan Jet Talk 107 Dec 15, 2005 01:31 PM
Ho 229 Tempest Electric Ducted Fan Jet Talk 0 Nov 05, 2004 03:39 PM
Jack Cooper's ho 229 (sting wing) mothflyer Slope 4 Sep 01, 2003 11:26 AM
Building the secret Luftwaffe weapon - Horten Ho 9/229 XPHAM Scale Kit/Scratch Built 14 Apr 01, 2003 08:26 PM
