Old Sep 13, 2012, 04:06 PM
Frank Søndervik is offline
Find More Posts by Frank Søndervik
United States, TX, Houston
Joined Sep 2004
Kolibri Jet Engine For SALE!
Im selling my Kolibri jet engine for $1800 (price negotiabel) + shipping.
It have two test runs only!!!
Comes with two new tanks for Multiplex FunJet and TwinJet
Lives in USA..
Details:
Thrust: 15N (1.5kp) at 243,000 RPM
Weight (engine alone): 200g
System weight incl. accessories and fuel for 8 minutes flight duration: ca. 750g
Dimensions: 55mm diameter, 125mm length
RPM: 95,000 to 243,000
Residual thrust at idle: ca. 2N (0.2kp)
Fuels: kerosene, JetA1, paraffine, each blended with 5% Aeroshell 500
Consumption at full power: ca. 65ml/min
Exhaust gas temperature at full power: ca. 680°C
Pressure ratio: 2.2
Air mass flow: 0.05kg/s
Exhaust gas velocity: ca. 330m/s
Starting: semi-automatic with external blower and LPG for combutor pre-heat
Control system: FADEC with RPM and EGT supervision
Fuel System: electric gear type pump and vaporizing combustor
Package Contents:
T32 Kolibri Turbine engine with RPM and EGT sensors and engine mount
Fuel pump with wiring harness
Fuel solenoid valve
Manually controlled gas valve
NIMH accu with 6 or 7 cells 350 -1000 mAh or LiPo with 2 cells 800mAh
Check valve for LPG
Quick release connectors for fuel and LPG
Tubing 3 and 4mm diameter
Fuel filter
Electronic engine control device (FADEC)
Hand data terminal
Startup blower 12VDC (car battery or lead-gel-accu)
Description:
Description:
Frank Søndervik is offline Find More Posts by Frank Søndervik
Old Sep 17, 2012, 02:14 PM
jrwingit is offline
Find More Posts by jrwingit
United States, GA, Macon
Joined Aug 2010
I am interested in you turbine email me at jrwingit@yahoo.com
jrwingit is offline Find More Posts by jrwingit
Old Sep 19, 2012, 07:18 AM
jrwingit is offline
Joined Aug 2010
This is my secound reaply , I will take the engine, let me know can we do Pay Pal
Old Sep 20, 2012, 01:49 PM
larry11 is offline
Find More Posts by larry11
Did you sell this?
Sent pms, but no response from ya
larry11 is offline Find More Posts by larry11
Old Oct 19, 2012, 12:02 PM
Joined Sep 2004
Hi,
Yes the engine was sold...
Sold Dyna-Jet pulse jet engine. wmupilot Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 15, 2012 09:09 AM
Discussion Kolibri Jet in fomy F-18 claesmeijer Jet Turbines 2 Nov 03, 2011 02:48 PM
Sold Ikara kolibris for sale shoutchen Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 08, 2010 08:41 PM
For Sale/Trade: KAVAN Jet Ranger w/ Engine cyberthreat Aircraft - Electric - Helis (FS/W) 1 Nov 16, 2003 08:54 PM
