Old Oct 12, 2012, 02:16 PM
skubacb is offline
Find More Posts by skubacb
skubacb's Avatar
Tucson, AZ
Joined Aug 2006
Take a look at this for using two batteries.
http://www.tech-aero.net/plr5-dr2
It allows you to use the two batteries simultaneously or with one main battery and one as backup.
Tech-aero's stuff has been rock solid for us. Since his battery regs worked so well we started using his ignition battery eliminator. Now we have over 20 planes with no ignition battery. Tried the Wike Mike stuff first and had multiple failures (Tech-aero was not making them at that time).
skubacb is offline Find More Posts by skubacb
Old Oct 19, 2012, 12:24 PM
dirtybird is online now
Find More Posts by dirtybird
United States, AZ, Queen Creek
Joined Aug 2004
The best way to power two receivers with two batteries.
Take two diodes with the sufficient capacity and tie their positive pins together. Run that connection to both receivers.( positive)
Then tie one of diodes negative pin to the positive of one battery and the other diode to the other battery. Connect the negative of both batteries together and to the negative of both receivers.
This way the battery with the most voltage will supply the load unless it gets overloaded and its voltage drops. Then the other battery will pitch in and help.
In the event one battery shorts out it will be isolated from the circuit.
This will cost you quite a bit less than $85
dirtybird is online now Find More Posts by dirtybird
Discussion Single Rx for two planes? electricrc68 Radios 3 Aug 03, 2012 07:07 PM
Found XPS XtremeLink® 2.4GHz 6 channel Nano E or Nano RX's two hope jcstalls Aircraft - General - Radio Equipment (FS/W) 1 Jun 30, 2012 04:58 PM
Question How big of battery do you need for 46 glow plane? rlfgary Fuel Plane Talk 36 Apr 06, 2012 08:45 AM
Discussion The big battery question : Zippy , Nano , Blue....5000mah 6S?? JEFFRO503 3D Flying 17 Feb 23, 2012 01:52 PM
For Sale Big batteries for big planes Milton Aircraft - Electric - Batteries & Chargers (FS/W) 6 Oct 14, 2006 12:12 AM
