Old Sep 13, 2012, 11:36 AM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Question
Two Nanos for a Big Plane - Two Rx Batteries?
I'm finishing up a Four Star 120 and plan to use two Nanos to get enough channels to have a four servo wing (flaps and ailerons), rudder, elevator and throttle.
I have a 2x2300mah 6.6v A123 pack that I can use for Rx and servo power. I was thinking as an alternative I could use two 2x1100mah A123 packs - one on each Rx. Perhaps providing a degree of redundancy.
Are there any problems with this approach?
Please advise. Thanks,
Paul
FlyingW is offline Find More Posts by FlyingW
Old Sep 13, 2012, 12:42 PM
Uff-Da RC is offline
Find More Posts by Uff-Da RC
Joined Dec 2007
I did something similar on my 38% Extra, but I did not run the two nanos on two separate batteries. I hooked up the two batteries in parallel, and powered both Nanos that way. As long as they were identical batteries with the same mAh rating, it is working just fine.
Uff-Da RC is offline Find More Posts by Uff-Da RC
Old Sep 13, 2012, 05:45 PM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
We run one battery to the 1st receiver, and another battery to the 2nd receiver - and we put a jumper (female-female servo lead) between both receivers. If either battery fails, power will pass through to both receivers. You could also run both batteries in parallel directly.
JimDrew is online now Find More Posts by JimDrew
Old Sep 13, 2012, 07:29 PM
FlyingW is offline
FlyingW's Avatar
Joined Dec 2001
Thanks Jim, and Uff-Da RC.
I didn't think about the jumper between. Very interesting setup.
Take care,
Paul
Old Sep 13, 2012, 10:16 PM
ChuckA is online now
Find More Posts by ChuckA
Tennessee
Joined Sep 2003
How would you know if a battery failed. I certainly wouldn't fly again until the problem was fixed.
ChuckA is online now Find More Posts by ChuckA
Old Sep 14, 2012, 12:29 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
They don't need to have the same capacity, only voltage.
It's a good idea to use a diode inline with each pack, as some batteries fails shorted and will take out the other one too.
Fred
flarssen is online now Find More Posts by flarssen
Old Sep 14, 2012, 08:13 AM
FlyingW is offline
FlyingW's Avatar
Joined Dec 2001
Fred,
Can you please elaborate on this battery and diode design? Over the years I've heard about doing this years, but it hadn't yet applied to me - now it may apply and I want to understand it.
Paul
Old Sep 14, 2012, 10:09 AM
Lake Havasu, AZ
Joined Jun 2005
We run a Tattletale on the bus of each receiver. If there is a problem, we know it!
The diode setup prevent voltage from flowing the opposite direction (short).
Old Sep 14, 2012, 11:19 AM
Son, Norway
Joined Sep 2004
Originally Posted by FlyingW View Post
Fred,
Paul
A short in one battery will not drain the other one. If level of charge is different, the high pack will not "charge" the other one.
Take a look here.
Note that charging needs to be done on the battery side of the diode, for instance via balancing connector.
Fred
Old Sep 14, 2012, 06:58 PM
FlyingW is offline
FlyingW's Avatar
Joined Dec 2001
I understand. Thanks,
Paul
Old Sep 16, 2012, 09:36 AM
jblloyd is offline
Find More Posts by jblloyd
Brandon, MS
Joined May 2006
As an alternative, take a look at the Fromoco Wolverine switch. I have been using them for several years on big birds and turbines to power two receivers with two batteries. http://www.fromeco.org/products/04frcwo-430b/
jblloyd is offline Find More Posts by jblloyd
Old Oct 05, 2012, 09:11 PM
FlyingW is offline
FlyingW's Avatar
Joined Dec 2001
The big Four Star had her successful maiden this afternoon. It was a bit inconvenient making the power lead connections but I think the arrangement can be improved.
In the current arrangement I made up a custom 16ga cable with an Astroflight zero loss connector on the battery end. The cable is about 12 inches long. There are two pigtails with 22ga JR-type plugs at the receiver end.
I want to put a high-quality switch in there somewhere so I can leave the plugged connections made while the plane is assembled at the field.
At jblloyd's excellent urging I looked at the Fromeco Wolverine switch - cool product, however; I think it may be overkill for my application since I'm using only one battery. I looked at Fromeco's Badger switch as a possible alternative:
http://www.fromeco.org/Products/04FRCBADSW-420b/
One Badger option has 16ga wire as the input from the battery, and two JR plugs out towards the receiver (just like my custom cable). Fromeco's intent for this arrangement is to plug both JR plugs into a single receiver to deliver double the power.
My arrangement is slightly different in that I have two receivers. The nano in the fuse has two servos - rudder and elevator, both HS-5645s. The nano in the wing has four servos - ailerons HS-635s and flaps HS-645MGs.
I had one flight with the basic cable and pigtails and it worked fine with several full flap landings.
Here is the question: Do you think that the Fromeco switch acts equivalently to the basic cable and pigtails? I guess the question comes down to whether or not the Badger with its two 3-amp JR plugs can deliver enough power to each nano.
What is your opinion?
Paul
Old Oct 06, 2012, 01:29 AM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
products like the Badger switches protect against battery failure, specifically shorting. Most batteries fail open circuit, so if you have two packs in parallel, one failing and going open circuit it will be fine. But it basic parallel connection and one fails and shorts, it will hose the second pack.
Battery share will also make sure both packs are drained at the same voltage, can use different capacity packs, etc.
What size/type of plane is it you're flying?...
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Oct 06, 2012, 07:36 AM
FlyingW is offline
FlyingW's Avatar
Joined Dec 2001
Four Star 120. 11 pounds, 12xA123 cells. Sport flyer.
Old Oct 08, 2012, 01:34 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
two three amp plugs should be fine. if you want a little bit of headroom, you can solder an extra Y or two to add an extra plug.
Discussion Single Rx for two planes? electricrc68 Radios 3 Aug 03, 2012 07:07 PM
Found XPS XtremeLink® 2.4GHz 6 channel Nano E or Nano RX's two hope jcstalls Aircraft - General - Radio Equipment (FS/W) 1 Jun 30, 2012 04:58 PM
Question How big of battery do you need for 46 glow plane? rlfgary Fuel Plane Talk 36 Apr 06, 2012 08:45 AM
Discussion The big battery question : Zippy , Nano , Blue....5000mah 6S?? JEFFRO503 3D Flying 17 Feb 23, 2012 01:52 PM
For Sale Big batteries for big planes Milton Aircraft - Electric - Batteries & Chargers (FS/W) 6 Oct 14, 2006 12:12 AM
