Old Sep 13, 2012, 09:34 AM
GuerillaFilm is offline
Find More Posts by GuerillaFilm
GuerillaFilm's Avatar
Iceland
Joined May 2012
4S 8" props vs 3S 10" props Performance & Flight Times
I fly a DJI Naza F450 with 10" props and 4400mah 45C lipos.
What's the difference in performance and flight times when switching from 3S 10" props to 4S 8" props? Will 8" props have less thrust, but be compensated by the extra volts in power?
GuerillaFilm is offline Find More Posts by GuerillaFilm
Old Sep 13, 2012, 10:33 AM
iskoos is offline
Find More Posts by iskoos
Orlando, FL
Add me to the list. I wanna find out as well. Plus I also want to know the difference in handling.
I heard that higher volt(rpm) and smaller prop makes the handling easier. It didn't seem very logical to me.
I hope someone shares...
iskoos is offline Find More Posts by iskoos
Old Sep 13, 2012, 12:27 PM
Iceland
Joined May 2012
bump
Old Sep 13, 2012, 01:15 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Well to give some reference a 1kg quad with 10" props on 3s 4500ma will hover for 20.64 min @ 69% throttle and same quad with 8" props on 4s 4500ma will hover 20.92 min @ 77% throttle. Calculated using ecalc. I would prefer the larger props.
pug398 is offline Find More Posts by pug398
Old Sep 13, 2012, 01:27 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
I've used 10" and 9" Gemfan props on both an F450 and F550. To me there's no difference in flight times, I think a 2200mah 4S Lipo gives roughly the same flight time as a 2200mah 3S. Maybe even a tiny bit more, you need less amps to hover. Do not use the stock 10" props on 4S, the motors will get very arm. 10" Graupnrs and CF Gemfans are alright though, it'll have heaps of power and won't overheat.
WiseDuck is offline Find More Posts by WiseDuck
Old Sep 13, 2012, 04:06 PM
Torque66 is offline
Find More Posts by Torque66
Noob
Torque66's Avatar
Canada, ON, Toronto
Joined Dec 2011
I fly with 4S 4000-4500 batts on 10" props in manual mode flight times are 4-5 minutes... i'll run my motors at 150Fand after 50+ packs the motors are fine.
3S + 10" props = lame..... 4S + 8" props = lamer.
I can lie but the video can't...
DJI F450 Shellpark (4 min 28 sec)
Torque66 is offline Find More Posts by Torque66
Old Sep 13, 2012, 04:52 PM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
Ecalc is great for guesstimations.
More and more it is proving unreliable for accurate predictions for multirotor use.
Its better to get your own experience and until you get that, the opinion of relatively trustworthy personal who have used certain motor and prop combinations.
There is something wrong with getting 5 minute flights on a 4S 4500mAh on a DJI 450.
Oversized motors? Weight? Prop selection? What is it?
Your times should be above 10 minutes.
Sad Sack is offline Find More Posts by Sad Sack
Old Sep 13, 2012, 05:24 PM
Torque66 is offline
Noob
Torque66's Avatar
Canada, ON, Toronto
Joined Dec 2011
I take it you've never flown in manual mode... sure in atti mode i can get 7-10 minutes of yawnola.
Old Sep 13, 2012, 05:53 PM
BillzillaAus is online now
Find More Posts by BillzillaAus
My cat moderates better
BillzillaAus's Avatar
Australia, QLD, Worongary
Joined Apr 2011
I get noticeably more flight time with 10" props compared to the 8" ones.
BillzillaAus is online now Find More Posts by BillzillaAus
Old Sep 13, 2012, 06:08 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
http://youtu.be/oVv1Rl3eqTM
How many Amps are you pulling?
Mike Freas is offline Find More Posts by Mike Freas
Old Sep 16, 2012, 09:06 AM
caotri is offline
Find More Posts by caotri
Hochiminh City
Joined Mar 2004
I believe it is over weight for this size with 4500mah.
I fly F450 , 4S 1800mah on sunny angle 980Kv 8x4 props and can fly 6 minutes
caotri is offline Find More Posts by caotri
Old Sep 16, 2012, 05:43 PM
cyberbillp is offline
Find More Posts by cyberbillp
cyberbillp's Avatar
United States, FL, Melbourne
Joined Mar 2012
wow
Dude, did you see him fly? He's a maniac!
cyberbillp is offline Find More Posts by cyberbillp
Old Sep 16, 2012, 06:50 PM
QUENAZ is offline
Find More Posts by QUENAZ
Brazil, São Paulo, São José dos Campos
Joined Aug 2012
Crius Multiwii SE with GPS Ublox
I fly with 3S 2200mAh battery on 8"x4.5 props...about 6-7 minutes...sometimes using GPS PH and RTH on this video bellow.
Crius Multiwii SE with GPS Ublox - PH and RTH with camera on board. (7 min 0 sec)
QUENAZ is offline Find More Posts by QUENAZ
Discussion 3S vs 4S for Naza F450 for 3 blade props GuerillaFilm Multirotor Talk 1 Jul 18, 2012 11:15 AM
Discussion KV vs Prop Size Vs Flight Time Foam boy Multirotor Talk 12 Jun 28, 2012 06:03 PM
Question Theoretical flight-time -vs.- practical Flight-time vineet_p Multirotor Talk 16 May 26, 2012 12:49 PM
Discussion Hobbywing 80 amp esc performance on 4s vs mamba monster on 4s tiforce Off-road Cars 0 May 02, 2012 05:45 PM
Eco 8 vs. Logo 10 flight time. n111kx Electric Heli Talk 26 Nov 21, 2003 09:07 AM
