Old Sep 13, 2012, 09:28 AM
beachflyer is offline
Find More Posts by beachflyer
RC since 1979!! AMA 112747
beachflyer's Avatar
Neptune Beach FL USA
Joined Nov 2000
Chaos 600 flybar version. Need Help with radio install.
I have recently purchased a Chaos 600 flybar version. I cant find any help with setting up servos and gyro anywhere. I am using a DX7. Anyone have some numbers and info on what servos are doing what on the heli. I have only setup smaller CP helis and just need some help. The manual is no help at all. Nothing about electronics setup
John
beachflyer is offline Find More Posts by beachflyer
Old Sep 13, 2012, 10:04 AM
Greybird is offline
Find More Posts by Greybird
Greybird's Avatar
Florida
Joined Nov 2004
http://www.readyheli.com/pdf/align-t...00E-manual.pdf
Greybird is offline Find More Posts by Greybird
Old Sep 13, 2012, 10:09 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
i have the same 600, but use a futaba radio . if you setup the smaller CP then this should be the same, as long as they use 2 servos for the aileron / pitch . the spectrum manual may have something in it .? the only thing i can think of is check out the finless bob videos on helifreaks . in a few setups he uses spectrum and JR , which should be similar .
jombo is offline Find More Posts by jombo
Old Sep 13, 2012, 01:01 PM
beachflyer's Avatar
Joined Nov 2000
Old Sep 13, 2012, 02:10 PM
The Valkman is offline
Find More Posts by The Valkman
The Valkman's Avatar
Joined Nov 2011
Hope this helps you out mate...........................
swash type ........3 servos 120 deg
channel 1 norm
2 reversed
3 rev
4 norm
5 norm
6 norm
Swash mix aile +60
elev+60
Pit -60
The Valkman is offline Find More Posts by The Valkman
Old Sep 13, 2012, 05:06 PM
beachflyer's Avatar
Joined Nov 2000
Thanks for all the help. I figured it out from Trex manual and did settings on my own and it flys great.
John
Old Sep 13, 2012, 08:09 PM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
Old Sep 13, 2012, 08:11 PM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
So, that heli has no issues? Quality seems OK? Is it all aluminum and carbon? I might get one to put in a RCAerodyne fuselage.
Old Sep 13, 2012, 09:04 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
No, the tail is plastic . Its more like the first 600 align came out with . If you want the all aluminum one then you need the TT version.
The good news is , it uses standard size servos because the frame is wider .
Old Sep 14, 2012, 03:49 AM
Joined Nov 2011
The manuals are also on the RCA web site for each version if you need them.
I would put the TT version into a scale bird.
Old Sep 14, 2012, 03:14 PM
beachflyer's Avatar
Joined Nov 2000
Mine is Carbon fiber and all aluminum head and tail. Flys real smooth.
Old Sep 14, 2012, 05:05 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
yes, but the tail blade holders are plastic
i replaced mine with the align metal tail blade grips
Old Sep 15, 2012, 04:50 PM
beachflyer's Avatar
Joined Nov 2000
No, Mine are aluminum also.
I guess the previous owner upgraded. Only thing plastic are the two seasaw arms on the head.
Old Sep 16, 2012, 12:09 PM
Jonathan Ott is offline
Find More Posts by Jonathan Ott
Will fly for food.
Jonathan Ott's Avatar
United States, IN, Fishers
Joined Jul 2002
The only plastic om my Chaos head is the radius arms, and I think that is pretty standard across all heli's, Align or clone.
My tail is all metal (torque tube) and the only stock plastic there was the slider bearing and the little pitch links.
Jon
Jonathan Ott is offline Find More Posts by Jonathan Ott
Discussion Help needed with Fatshark Dominator and Futaba 14mz radio woreoutpilot FPV Talk 0 Aug 29, 2012 03:21 PM
Discussion Help me install battery in MCPx Version 2 steveap1 Beginner Training Area (Heli-Electric) 7 May 16, 2012 08:21 PM
For Sale Chaos 600 align clone with Dx6i RTF$750 taco32 Aircraft - Fuel - Helis (FS/W) 1 Apr 17, 2012 08:58 PM
Discussion Help with radio install in D VII RayRangel Parkflyers 3 Mar 30, 2012 07:15 PM
For Sale Chaos 600 RTF with a Dx6i $800 taco32 Aircraft - Electric - Helis (FS/W) 6 Mar 22, 2012 09:53 PM
