Old Oct 09, 2012, 10:16 PM
Dillion is offline
Find More Posts by Dillion
Balsa Dust and CA Fumes
Dillion's Avatar
United States, PA, West Chester
Joined Oct 2007
Dereck, I don't understand where FS-1 is. I certainly will consider all suggestions. If a support brace is needed someplace I want to understand where.
Dillion is offline Find More Posts by Dillion
Old Oct 09, 2012, 11:28 PM
iva is offline
iva
Find More Posts by iva
iva
iva's Avatar
Vancouver Harbour Sp, Canada
Joined Jan 2001
I believe that is WS 1 on your photo - the part trapping the bolt head.
If that is what Dereck meant, I agree completely. I have some 1/8" triangles on mine and you could use either 3/16 or 1/4 hard balsa triangles.
iva is offline Find More Posts by iva
Old Oct 10, 2012, 08:14 AM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Dillion,
I believe your oak wing holding block is more than strong enough, however; It is tied only to the leading edge and the center rib.
I therefore recommend that you install additional bracing to share the load. How about two more ribs, one on each side, maybe at the width of the fuse. Then add gussets from the three center ribs to the oak block.
Looking good.
Paul
FlyingW is offline Find More Posts by FlyingW
Old Oct 10, 2012, 09:13 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Oops, sorry. Should have been more attentive, reading it upside-down. It's WS1, the near semi-circular horizontal former under the wing LE.
D
Dereck is offline Find More Posts by Dereck
Old Oct 10, 2012, 10:11 AM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Braces
I added the braces to WS-1 and glued in the rear wing mounting wood for the rear mounting screws (Nylon) I glued a small triangular piece of wood under the mounting wood for strength.
"W" Really? You really think two more ribs are needed in this wing? The original uses a hook lip and thats pretty much just glued to the W-1 Rib only. I have to think about adding that kind of weight to the plane.
Old Oct 11, 2012, 12:41 AM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Wing Bolts
I completed the wing bolt on section. Installing the thread insert, epoxying everything, both WS-1 and mounting wood for screw attachment.
Was pleased to see all the lumber so far only weighs 25 ounces.
Whats next??? The wing tips maybe, have I forgot anything on the fuselage?
Wheels are on order.
Old Oct 11, 2012, 07:32 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Wing Tips
Started the Wing Tips, One at a time, letting it dry.
Old Oct 11, 2012, 10:15 PM
lindart is offline
Find More Posts by lindart
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
I found the top of the wing easier to cover when cap stripped at the polyhedral break. They are added to the ribs and not on top of them.
lindart is offline Find More Posts by lindart
Old Oct 12, 2012, 10:14 AM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Doesn't look right
I attached the wing tips and am beginning to add the top spars. Does this look right. Is the spar suppose to look like this? I'm thinking I might "Crack" the spar right at the rib to give the wing tip a straighter look. What did I do wrong?
I cracked a spar and clapped it in place, this looks better.
Old Oct 12, 2012, 02:12 PM
iva is offline
iva
iva
iva's Avatar
Joined Jan 2001
You definitely have to crack all the spars at that last rib.
Old Oct 12, 2012, 03:53 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Cracked Spars
I cracked all the spars, added webbing, and Gussets.
Still have the other side to do.
Old Oct 14, 2012, 04:42 PM
Dereck is offline
Joined Dec 1996
It 'Bee' looking good! As long as you have all the gussets fitted, albeit to 'scale' sizes, it'll Bee fine
D
Old Oct 15, 2012, 01:11 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Sanding Lazy Bee WING
So this was more than I thought it would be. Took almost two hours to shape the Leading and Trailing Edges. I started out very practical, using a sanding block, then progressed over to my Large 100 grit sanding block. My thinking was that I need to be careful not to break anything. Well this is one tough wing, I can't be lieve how strong it is. In handling it tyo sand all of the edges, I only knocked out three Gussets. I feel thats good. A NOTE: When sanding this wing, handle it by gripping the web area, which is by far the strongest area. Below are some photos of a rounding sanding block I made to keep the leading edge consistent and the other sanding devices I used.
Old Oct 15, 2012, 01:18 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
I used a razor blade then sanding blocks on mine. Last weekend I picked up a master airscrew razor plane to try out on my d-vii build. I'm doing a build thread in the fuel warbirds section if interested.
I was going to fly my Bee last Saturday but the 12-15 mph winds scared me off. I did a fine job of crashing my ult bipe 40 though! It was a arf so I had no emotional attachments.
TexasClouds is offline Find More Posts by TexasClouds
Old Oct 15, 2012, 01:41 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Texas, please give us all the link of your blog.
For Sale BNF Clancy Aviation Lazy Bee 40" wingspan LIZZAY Aircraft - Electric - Airplanes (FS/W) 7 Jul 12, 2012 04:43 PM
Discussion Help: Brand new UMX gee bee ailerons going same direction. 2yy4u Scratchbuilt Indoor and Micro Models 11 May 01, 2012 03:21 AM
Discussion lazy bee aileron with twin motors, any better? nemoskull Scratchbuilt Indoor and Micro Models 0 Mar 12, 2011 12:36 PM
For Sale Clancy Lazy Bee Aileron Wing Plan rjapodaca Aircraft - Fuel - Airplanes (FS/W) 1 Sep 06, 2008 12:42 PM
For Sale Clancy Lazy Bee Aileron Wing Plan rjapodaca Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2008 06:47 PM
