Old Sep 28, 2012, 03:42 PM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Originally Posted by Dillion View Post
Where did everyone go? I thought we'd build this together. I lost all of you?
been busy with work. I would start in the middle for the wing and work your way out. as far as steel you would need to find a local metal supplier. Lowes or HD may have it but not sure about that size.
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Sep 28, 2012, 04:00 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
i'm lurking.
did you sand the wing tips yet? here is a tip, don't add any ca to the laminations before sanding...or else it will get rock hard! don't ask me how i know
TexasClouds is offline Find More Posts by TexasClouds
Old Sep 28, 2012, 05:04 PM
iva is offline
iva
Find More Posts by iva
iva
iva's Avatar
Vancouver Harbour Sp, Canada
Joined Jan 2001
I would not start shaping the laminations before they are attached to the rest of the wing tip sections.
I used sending as the last phase of shaping of the laminations. I did most shaping by David plane. The plane is based on a heavy duty razor blade. I believe that Master Airscrew is making a low end (plastic) version of the tool. Patience in this phase will pay off. Check the progress frequently. You do not want to remove too much of the material!
If you can slide the wing over the building board, you may only need to move it for one rib bay to complete the center section of the wing and that should not be a problem (no need to buy a new "building board"). Again, while gluing the tips to the center section you need support for the portion of the center section only-not the full length.
iva is offline Find More Posts by iva
Old Sep 29, 2012, 07:43 AM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
Still watching Dillion!
Yes, glue on the wingtips and then do the sanding. Just follow the directions and you'll be fine!
Joe
jodini is offline Find More Posts by jodini
Old Sep 29, 2012, 07:13 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
The clever trick with the tip bows is how they change shape and taper, from a full 1/2" deep LE curved section at the front joint matching the centre section LE to a 1/4" deep tapered rectangle matching the TE.
As it's much harder to replace wood than whittle it away, this job demands some pre-thought and careful whittlin'.
Dereck is offline Find More Posts by Dereck
Old Oct 01, 2012, 04:37 PM
Dillion is offline
Find More Posts by Dillion
Balsa Dust and CA Fumes
Dillion's Avatar
United States, PA, West Chester
Joined Oct 2007
Building Board
I purchased a piece of metal 2' X 3' the largest I could fine. Its's thinner than the board I have so I also purchased a piece MBS board, 2' X 4'. I'm going to attach it via small screws in the corners. I'm planning on placing the metal to one left edge. Was thinking of gluing it on with liquid nails.
Do you think there will be a problem if I don't cut W1 ply? It's cut out of a hard balsa 3/16" thick
Dillion is offline Find More Posts by Dillion
Old Oct 02, 2012, 08:59 PM
Dereck is offline
Joined Dec 1996
Two days drive from my Bee-hive, am going to guess that w1 is the centre rib. Balsa will do fine if you're rubber banding the wing on. My presentBee has the ply front bolt-on hooks glued onto a balsa centre rib, though ply sounds a good idea for a biggaBee.
D
Old Oct 04, 2012, 10:32 AM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Plans
I had a set of the 48" wing enlarged 125%. But after advice from the forum, I decided to go with the 40" wing proportion, so I cut out one bay on each side and moved the center ribs out a bit to get the 50" needed. I'll go cut the center W1 rib out of ply as that seems to be the consensus that would be needed. I might be able to start the wing today.
Also, looking at these huge chunks of wood I'm going to use for ribs, should I drill lightening holes? Not sure how much weight this will really save, or are the strength of the ribs needed for one reason or another.
Old Oct 04, 2012, 01:58 PM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
I wouldn't bother with lightening holes as there really aren't that many ribs. Small "breather holes" - yes - to allow the passage of expanding interior air while covering.
That size wing will fly well and certainly bee good fun.
FlyingW is offline Find More Posts by FlyingW
Old Oct 04, 2012, 02:45 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
breather holes
W, As per your suggestion, I drilled a few breather holes rather than cutting out larger lightening holes.
Old Oct 04, 2012, 04:09 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Starting the wing
After slicing the plans to suit my needs of a 50" wing withe bays at about equal distance, I'm beginning the wing construction.
Wax paper is laid over the plans and the bottom spars are locked in place with my magnet system. I love these! As you can see. I can hold the spars aligned with the plans, also held tight to the plans by pressing down on them and locked left and right with a couple more magnets.
Old Oct 04, 2012, 04:39 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
All Dried Fitted
I dry fitted the three ribs and spars, ready to glue. Carpenters Glue?
Old Oct 04, 2012, 05:57 PM
Flying Low
Joined Mar 2012
Tite Bond 3 is the best glue I have found. takes longer to dry but holds really well. I am trusting it on my 30%er I'm building.
Old Oct 04, 2012, 09:01 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Glue
I use to use Titebond 3, but then didn't think I needed three. I purchased the original Tilebond. Now I wanted to see what was the difference. The original is a carpenters glue. II is watrer resistance and III is waterproof. Now I don't expect to get my Bee wet, but you never know, so I'm exchanging the original for three. Thanks "cbarnes"
Old Oct 05, 2012, 12:07 AM
Flying Low
Joined Mar 2012
I have never done any test myself but I have been told that the 3 has a little strong bond. Its funny I have seen other glues and epoxies and what sorts that will tell you how much weight they should hold to give you an idea of how good it is but I can't find anywhere on the bottle. I just upgraded to the 16oz bottle today as my Cap232 has emptied the smaller 8 oz bottle.
For Sale BNF Clancy Aviation Lazy Bee 40" wingspan LIZZAY Aircraft - Electric - Airplanes (FS/W) 7 Jul 12, 2012 04:43 PM
Discussion Help: Brand new UMX gee bee ailerons going same direction. 2yy4u Scratchbuilt Indoor and Micro Models 11 May 01, 2012 03:21 AM
Discussion lazy bee aileron with twin motors, any better? nemoskull Scratchbuilt Indoor and Micro Models 0 Mar 12, 2011 12:36 PM
For Sale Clancy Lazy Bee Aileron Wing Plan rjapodaca Aircraft - Fuel - Airplanes (FS/W) 1 Sep 06, 2008 12:42 PM
For Sale Clancy Lazy Bee Aileron Wing Plan rjapodaca Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2008 06:47 PM
