Old Dec 08, 2012, 09:11 PM
Dillion is offline
Find More Posts by Dillion
Balsa Dust and CA Fumes
Dillion's Avatar
United States, PA, West Chester
Joined Oct 2007
Shocks
Well I finished the shocks. I found these huge 6" foam wheels which I think they look right on the Bee. It needs BIG wheels. The shocks are for a RC truck. I used nylon spacers and loock nuts. Also used Locknut everywhere. I think it looks good. Mark you appear to be the last one on this Blog. Thanks for hanging in there.
Dillion is offline Find More Posts by Dillion
Old Dec 08, 2012, 09:16 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
Looks real slick. Those tires will be more user friendly and last longer than the trexlers. Mine are already cracking after a little over a year.
Let me know what your final weight and wingspan is.
TexasClouds is offline Find More Posts by TexasClouds
Old Dec 08, 2012, 11:57 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Along with Tex on Trexlers. They drip coolness, but reality is a pain. Pumping them up, not getting damp inside of them, stopping the air leaking out, etc etc...
Will probably keep them on my regularLazy. My LazySpeedy has foamie wheels. To heck with it!
The shocks thing will be interesting to follow. Have long thought I should try them, but that's as far as I have got.
D
Dereck is offline Find More Posts by Dereck
Old Dec 09, 2012, 08:22 AM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
My Bee has been using the same pair of Trexlers since December 1997. Only had one puncture when I misjudged a landing. It was at an event where they had a paved runway and I put it down on the center line instead of on the grass next to it. I fixed the puncture with a patch for bicycle tubes and a Bandaid. It has been fine for years, but the Bandaid has to be replaced a few times each year.
Al M is offline Find More Posts by Al M
Old Dec 09, 2012, 08:56 AM
Joined Feb 2010
do you store yours with air, deflated, in powder or what?
i deflate mine when not inuse then leave on the model hanging in my shed. as a result mine have a bunch of cracks on the outside when i air up. i had one leak early on, but thin CA fixed it.
Old Dec 09, 2012, 09:47 AM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Looking good Dillian. Keep it up she looks like she is almost ready for the air.
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Dec 09, 2012, 10:17 AM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
they dry rot here something fierce...I've started using fun cub wheels...same look and no air issues
David Hogue is offline Find More Posts by David Hogue
Old Dec 09, 2012, 12:58 PM
Al M is offline
Wallingford, Ct
Joined Sep 2001
I only deflate my Trexlers if I don't plan to use them for a month or more. I always leave them a little soft. Sometimes a lot soft.
Old Dec 09, 2012, 03:20 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Motor
Okay heree is what I have for power. A Monster Power 10 1100Kv 375W Idle Current 2.1A Coutinuous Current 30A Max Burst 38A 2-3 LiPo. I have both a 30A and 50A ESC. I plan to run a 2150 3cell. Props 10X5 to 12X6 The plane fron what i can determine from just parts weighs 50oz and the current motor, battery and ESC weight 12. So the Bee will come in at 62Oz. or 3 3/4 lbs. That gives the plane about 100W per pound
Old Dec 09, 2012, 03:44 PM
Joined Feb 2010
Note that an esc rating is with 5mph airflow over it. If you aren't blowing air through the fuselage then you might want to use the larger esc...especially if you plan to use full throttle a lot.
Old Dec 09, 2012, 04:16 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Airflow
So should I drill a few holes in the front of the fuselage? This bee has nice vents cut up front. You think I should do the same?
Old Dec 09, 2012, 05:12 PM
Joined Feb 2010
That is where I put my air inlet right in the nose behind the prop. My air exits out the large pushrod exits in the tail. Some leave a couple side windows open to let air escape. My esc is in the nose area beneith the esc.
However, with a large cavernous fuselage like the bee has, and a properly sized power system, you may not have excessive heat buildup as is. I say fly around five minutes and check the esc and battery temps. If cool then u probably can get away without the airflow. If warm then add some holes later.
Old Dec 09, 2012, 06:12 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Motor
Mark, do you think I'll be okay with the Monster power 10 and the 30A ESC or should I use the 50A ESC?
Old Dec 09, 2012, 06:52 PM
Joined Feb 2010
50a esc
Old Dec 10, 2012, 10:06 AM
Dereck is offline
Joined Dec 1996
Air cooling - a way out is probably as important as a way in for cooling air. Those front vents look good, should work and if you ever take up waterBee flying, you can tape them over easily.
Having said that, none of my e-Bees have had any cooling air inlets or outlets...
You might want to look at some bigger batteries - though the age of the pack and its C rating come in here. There is a tendency from some country who's name escapes me right now to be a little optimistic on C rating too. A lot depends on how you fly your Bee. Mine was spotted in straight and level once, but I can't recall when I suspect some of my older 2200-ish 3S packs are on the rundown, but at least replacements don't cost a lot.
If you have a bigger ESC lying around, use it. Extra capacity never hurts here.
D
For Sale BNF Clancy Aviation Lazy Bee 40" wingspan LIZZAY Aircraft - Electric - Airplanes (FS/W) 7 Jul 12, 2012 05:43 PM
Discussion Help: Brand new UMX gee bee ailerons going same direction. 2yy4u Scratchbuilt Indoor and Micro Models 11 May 01, 2012 04:21 AM
Discussion lazy bee aileron with twin motors, any better? nemoskull Scratchbuilt Indoor and Micro Models 0 Mar 12, 2011 01:36 PM
For Sale Clancy Lazy Bee Aileron Wing Plan rjapodaca Aircraft - Fuel - Airplanes (FS/W) 1 Sep 06, 2008 01:42 PM
For Sale Clancy Lazy Bee Aileron Wing Plan rjapodaca Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2008 07:47 PM
