Old Dec 03, 2012, 10:08 AM
Dillion is offline
Find More Posts by Dillion
Balsa Dust and CA Fumes
Dillion's Avatar
United States, PA, West Chester
Joined Oct 2007
Beautiful
Texas Very clean looking build, please keeps us updated on it's progression. I want to see this build.
Dillion is offline Find More Posts by Dillion
Old Dec 03, 2012, 10:16 AM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
I'm doing a build thread here: http://www.rcgroups.com/forums/showthread.php?t=1749010
TexasClouds is offline Find More Posts by TexasClouds
Old Dec 04, 2012, 12:00 AM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Acrylic
The Acrylic plastic isn't the best idea, Very hard to glue. I found GOOP will hold itt, but it's so stringie that I got glue on the plastic. Not the best look. Anyway the silicon didn't hold it so I used plumbers putty to act as clips to hole the side panes in. The fron I may do over. For now they will do
Old Dec 04, 2012, 12:42 AM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
How about cutting the windows out of a clear soda bottle. cheap easy to cut and with a little bit of heat from your heat gun it will mold around things pretty well.
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Dec 04, 2012, 07:38 AM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
Just use cleat Ultracote or similar.
Al M is offline Find More Posts by Al M
Old Dec 04, 2012, 02:25 PM
lindart is offline
Find More Posts by lindart
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
What worked well for me was to make a light posterboard template that wrapped around
the top of the windscreen opening and conformed to the cowl, not touching the braces. Plastic was cut per template and secured at its perimeter.
I used very small T pins to hold it in position and used very small dabs of epoxy on a tooth pick to spot glue it.
The resulting pin holes received a speck of epoxy and looked like rivits. FWIW. art
lindart is offline Find More Posts by lindart
Old Dec 04, 2012, 07:16 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Bad windows
So you all agree I should kick the windows out of the front and try again.
Old Dec 04, 2012, 09:07 PM
Joined Feb 2010
Onl if the current job bothers you. Step back 5 feet and u probably won't notice any flaws.
On my Fokker I'm kinda leaning against doing lozenge camo on the wings. I'll just be flying it for fun at my local field...I don't need it to be 100% scale. I'm tempted to whip up a color scheme of my own.
Old Dec 04, 2012, 10:57 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Design your own
Texas. I would design your own. Your not going to enter it any contest are you? Then build the plane to please yourself. All the things I changed on this plane because you guys offered another suggestion was ONLY because I thought them to be a better solution, but in the end, it's you plane and design a nice color scheme that you'll be proud of. I Used Clancy's design scheme only because I wanted a Lazy Bee that looked like one. I should dig out a photo of my Speedy Bee that I designed to look like a P51. Lets see what your designing, I would love to be involved. Do it for yourself.
What is your name?
I'm Dylon
Old Dec 04, 2012, 11:42 PM
Greg Knipp is offline
Find More Posts by Greg Knipp
Greg Knipp's Avatar
Manitowoc, Wisconsin
Joined Dec 2003
The Lazy Bee is an excellent candidate for clear Monokote windows all around. each piece remains flat and makes it super simple.
Greg Knipp is offline Find More Posts by Greg Knipp
Old Dec 05, 2012, 06:33 AM
Joined Feb 2010
Texas. ...
What is your name?
I'm Dylon
I'm Mark and would like to see pics of the Speedy Mustang!
Old Dec 06, 2012, 02:21 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
P51 Speedy Bee
Mark,m this will get you to the link on RCUniverse
http://www.rcuniverse.com/forum/m_10...m.htm#10982391
Let me know
Old Dec 06, 2012, 03:36 PM
Joined Feb 2010
Let me know
I like the shocks!
Old Dec 06, 2012, 08:49 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Shocks??
Should I put Shocks on the LAZY BEE? I have a cheap set
Old Dec 07, 2012, 12:38 AM
Joined Feb 2010
The shocks add to the goofiness, so yes!
For Sale BNF Clancy Aviation Lazy Bee 40" wingspan LIZZAY Aircraft - Electric - Airplanes (FS/W) 7 Jul 12, 2012 04:43 PM
Discussion Help: Brand new UMX gee bee ailerons going same direction. 2yy4u Scratchbuilt Indoor and Micro Models 11 May 01, 2012 03:21 AM
Discussion lazy bee aileron with twin motors, any better? nemoskull Scratchbuilt Indoor and Micro Models 0 Mar 12, 2011 12:36 PM
For Sale Clancy Lazy Bee Aileron Wing Plan rjapodaca Aircraft - Fuel - Airplanes (FS/W) 1 Sep 06, 2008 12:42 PM
For Sale Clancy Lazy Bee Aileron Wing Plan rjapodaca Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2008 06:47 PM
