Old Nov 15, 2012, 05:24 PM
Greg Knipp is offline
Find More Posts by Greg Knipp
Greg Knipp's Avatar
Manitowoc, Wisconsin
Joined Dec 2003
The file download worked!!!!
Thank you so much.
Greg
Greg Knipp is offline Find More Posts by Greg Knipp
Old Nov 18, 2012, 03:09 PM
Dillion is offline
Find More Posts by Dillion
Balsa Dust and CA Fumes
Dillion's Avatar
United States, PA, West Chester
Joined Oct 2007
Greg,
If you build the wing, let me know what changes you needed to make, to get the wing to work. I'll change them on the plans. Any suggestion you have please let me know here
Dillion is offline Find More Posts by Dillion
Old Nov 24, 2012, 03:08 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
I hope everyone had a wonderful Thanksgiving. I know I had a great meal at my in-laws. Some good football.
Well back to this BEE. I covered the tail section and added exit ports for the pushy rods. I installed the push rod guide tubes. I finish covering the fuselage now.
Old Nov 25, 2012, 07:23 AM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Looking good and your right about good football on thursday "Hail To The Redskins"
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Nov 25, 2012, 05:21 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Football - is that where teams of 50-odd guys wear shoulder pads and throw their funny shaped balls around by hand between commercials?
Bee is looking great. Get on with you and get her out to fly. After building six of them, flying them strikes me as the only reason to have one!
D
Dereck is offline Find More Posts by Dereck
Old Nov 25, 2012, 05:32 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
push rod exits should help streamline the Bee a bit ;-)
TexasClouds is offline Find More Posts by TexasClouds
Old Nov 25, 2012, 11:04 PM
lindart is offline
Find More Posts by lindart
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
Sometimes crossing the pushrods gives a more straight shot at the horns....
lindart is offline Find More Posts by lindart
Old Nov 26, 2012, 09:39 AM
Dereck is offline
Joined Dec 1996
Mine's got a streamlined cowling. Does that help?
D
Old Nov 27, 2012, 12:21 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Real Football
Dereck, Yes REAL Football, I was referring to. LOL
I have the push rods installed, but I'm going to look at crossing them to see if that in fact does give them a straighter line. I like the engine cover idea. I'll look into building one. Are you holding it down with earth magnets?
I had such a hard time with servos. I have a pair of Airtronic 94831 servos that I could not get to work. The plugs appear to be to big and if I did get them in a receiver they just didn't work. How could that be? Two that didn't work?. Are these special servos that require something beside 4.8v? Airtronics only sells the case and gears, not the servo. Should I just discard them?
Old Nov 27, 2012, 12:41 PM
Joined Feb 2010
D
That should give you a little more vertical surface for extended knife edge flight
[QUOTE=Dillion;23376979]...I have a pair of Airtronic 94831 servos that I could not get to work....[QUOTE]
Here are the specs on those servos: http://www.servodatabase.com/servo/airtronics/94831z
I have had good luck with these standard size servos for 40 class sport planes:
Towerpro SG5010 Standard Servo
Old Nov 27, 2012, 01:05 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Iindart
lindart, you where right on with crossing the push rod tubes. It did give it a straighter line. Thanks.
Mumble mumble. I had CA'ed the tubes in place and had to rip out the balsa I used to hold the tubes in place.
If I wanted to do this wrong I wouldn't of ask you guys for advice, Thanks to all of you again. I'm getting great suggestion from all of you, please speak up when you see a better way to do something. I think this plane is going to be perfect
Old Nov 27, 2012, 01:21 PM
Joined Feb 2010
I did pull pull with mine for some crazy reason I think it was b/c I didn't want to buy the pushrods or maybe to save weight.
Mark's Clancy Big Fokker Bee 57 inch - tail test (1 min 33 sec)
Old Nov 28, 2012, 01:05 AM
lindart is offline
Art Schmitz
Joined Jan 2012
Dillion, you may wish to compare the wiring order colors at the plugs of the Airtronics servos to that of a JR or Futaba.
A pin can be used to depress the locking detail of the individual wires while giving them a slight pull.
art
Old Nov 28, 2012, 04:03 AM
Flying Low
Joined Mar 2012
I like the red baron look on you bee Texas clouds and also how you made the entire verticle move over just having a rudder. Does it give it any extra athority or is it about the same as with just having a rudder?
Old Nov 28, 2012, 04:36 AM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Nice Bee
TC, A very nice Fokker Bee. You know for future builds I have to stop thing so traditionally. Mounting the servo upside down is a great idea. That way you have access equally. Do you have a side door to get to the servos?
I changed the push rod setup. Not sure if you guys use the black tube included. You get a piece of rubber tube which you cut into small bands and slide them over the guide tubes. I had to heat the bands to get them to stretch over the rods. Here you can see the new arrangement of the push rods and the black bands to hold the guide rods in place.
I'll put a note on those servo for future need about the wiring. For now I don't need them, so in the box they go.
For Sale BNF Clancy Aviation Lazy Bee 40" wingspan LIZZAY Aircraft - Electric - Airplanes (FS/W) 7 Jul 12, 2012 04:43 PM
Discussion Help: Brand new UMX gee bee ailerons going same direction. 2yy4u Scratchbuilt Indoor and Micro Models 11 May 01, 2012 03:21 AM
Discussion lazy bee aileron with twin motors, any better? nemoskull Scratchbuilt Indoor and Micro Models 0 Mar 12, 2011 12:36 PM
For Sale Clancy Lazy Bee Aileron Wing Plan rjapodaca Aircraft - Fuel - Airplanes (FS/W) 1 Sep 06, 2008 12:42 PM
For Sale Clancy Lazy Bee Aileron Wing Plan rjapodaca Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2008 06:47 PM
