Old Sep 16, 2012, 02:16 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Originally Posted by wildpalms View Post
Since this is the F3P not the foamies or indoor forum I will make a couple of suggestions.
20g motor is heavy. The Axi at 18g all in is really a lot these days (gets away with it on bigger models as so good a motor).
240'ish batteries for sport flying. 180's for flying the schedules.
Servos. Try the next size down. Nothing bigger than 4.5-5.0g on all surfaces. Use 1 aileron servo.
Unless you have built a brick you will need nothing more than a 6A esc. My overweight Helix (120g) runs fine on small esc. Averaging less than 2A on current schedule flight.
One piece wing is ideal for home build but not if you are going to ship any to customers :-)
Dave
Well i haven't built it yet so i can still go for different electronic choices
so how about this motor http://www.hobbyking.com/hobbyking/s...arehouse_.html
and these servos http://www.hobbyking.com/hobbyking/s...sec_Servo.html
i already have 2 180Mah 2s lipos
and i also already own an 8A ESC with 2A BEC
hows That ?
K
P.s now it is a 2 peice wing for Reasons Stated by Wildpalms
Keenan smith is offline Find More Posts by Keenan smith
Old Sep 16, 2012, 02:54 AM
Joined Dec 2010
Brett i sent you a PM
K
Old Sep 16, 2012, 08:52 AM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Although I have heard lots of good things about the 19T, I would go with a Hacker A10-15S and CC 6. It will pull around a 125 gram plane like a feather. And the combination only weighs ~20 grams.
Servos, I would go with Futabas, Hitecs, and or Diamonds.
Free
P.S. You pay for what you get.
Free is offline Find More Posts by Free
Old Sep 16, 2012, 03:36 PM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
Can't comment on those servos in particular. Servos in the size are often a lottery. Suck 'em and see :-)
That Hobby-King motor is very common down here. I know of several models that competed at EIM last year with them. 8x4.3 GWS Slow Fly prop. Can even be machined down on a lathe to save a few grams (I fly with a few people even more anal than me). They last well. I have one in a general knockabout model and I hate to think how many hundreds of flights it has.
I have the Hacker as well. Very noisy and I wasn't too keen on it. Fantastic motor for indoor pylon with the 7" prop though.
8A esc is ideal.
Weight is your enemy and equipment the only real way to get decent savings. Depron Aero saves quite a bit over normal Depron as well.
For the carbon work take a look at models like the Disney. The aileron bracing it uses really works.
Steer clear of real cheap carbon rod as well. Can be very floppy and heavier as well (lower carbon to resin ratio). Quite surprising just how much all the carbon can weigh when you end up with several metres of the stuff.
wildpalms is offline Find More Posts by wildpalms
Old Sep 16, 2012, 05:08 PM
Free is offline
Free's Avatar
Joined Jan 2012
Look at this post, I found it very helpful(and depressing, lol).
http://www.rcgroups.com/forums/showp...5&postcount=96
Free
P.S. Also notice the bracing(kind of complicated)
Old Sep 17, 2012, 09:24 AM
RCvehicleGuy is offline
Find More Posts by RCvehicleGuy
Mr. Foam, Tape, and Carbon
RCvehicleGuy's Avatar
Joined Feb 2011
The lighter the better. I watched the ETOC and their airplanes are nbelieveable. I forget who I talked to but one of the guys had a Hacker a10-9l on his with a 10 inch carbon fiber prop. He had his throttle adjusted in the travel adjusts of his radio for thirty percent. His plane was in the sub 120 gram range.
Generally when an F3P plane is made, they will either mill it down till it is almost nothing. Or they will mill it out all the way and put a saran wrap like material over it. All of this is in a life or death attempt at getting as close to nothing in weight as they possibly can. They do anything and everything to make these so ungodly light and fragile. Also, you will likely go through a few prototypes, F3P demands precision down to the inch, this means that a plane cannot have any weird tendencies. Sure a pilot can correct, but judges like to see the plane not only on clean lines, but a clean attitude as well.
F3P is a complicated world, people do different things to get the performance they want. But it all ends up on a couple deciding factors: Does the airplane weigh less than 3.5 ounces? And do you have 200 practice flights on it?
RCvehicleGuy is offline Find More Posts by RCvehicleGuy
Old Sep 17, 2012, 09:29 AM
Joined Feb 2011
The link that Free provided shows an example of how unbelievably anal all these F3P guys are. This is why I stick to 3D depron sub 200 gram planes. Just slap it together and go hucking around the yard. The end.
Chris G.
Old Sep 17, 2012, 09:34 AM
Joined Dec 2010
Chris G.
You Remind me of Me When i made my 3DDF Genesis... (whacked it together)
Old Sep 17, 2012, 09:35 AM
Joined Dec 2010
+ i also Sand my CF Rods Surface's To save some Wieght.
Old Sep 17, 2012, 09:53 AM
Joined Feb 2011
Haha! I say I whack my stuff together... Tell me what you think of this model I made up...
http://www.rcgroups.com/forums/showthread.php?t=1618054 Not a SINGLE reply on this one.
Put a lot of work into this one too... http://www.rcgroups.com/forums/showthread.php?t=1582557
Anyways, ya, F3P is kinda complicated. Selling kits is kinda complicated. That is why I just make stuff for myself and post the plans for free on RCGroups. Good luck with your business venture though!
Chris G.
Old Sep 17, 2012, 12:11 PM
rgj is offline
rgj
Find More Posts by rgj
rgj
Joined Dec 2010
a good model
If you are building a F3p model that you are going to use in a gym with a bit limited space (from floor to celing) you have to think weight, and milling is a must its not just fancy works, you have to use good light servoes and a light motor and esc, you cant comprimize with anything.
If it is to heavy it will build up speed at downlines to fast , in the gym where I fly at the most its 8 meter under the roof and if you are going to have time for some rolls in the downline it cant weigh to much..if its to heavy its useless.
Thats at least what I found out I had one model that ended up at 125 gr with batteri I found it to heavy.....next was 106gr ..perfect
rgj is offline Find More Posts by rgj
Old Sep 17, 2012, 02:10 PM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
I have to ask why is the canopy a separate piece? Its another glue joint you just dont need
Andy
Andycap is offline Find More Posts by Andycap
Old Sep 17, 2012, 03:07 PM
Joined Dec 2010
Andy
Mailing space...
Old Sep 17, 2012, 03:08 PM
Joined Dec 2010
Im aiming for 100-106g but I'll have to build it as light as possible (without crazy milling ) and Use Aero-brakes to Slow things down ....
K
Old Sep 17, 2012, 03:37 PM
Joined Dec 2010
You guys Should I Add Some Aero-Brakes?
Discussion Find hobby shop open www.f-hobby.com find hobby Other Websites 226 Jun 15, 2016 11:38 AM
Question 3D Hobby Shop OR Twisted Hobbies turboready 3D Foamies 35 Apr 14, 2013 10:32 AM
New Product 3D DreamFactory (3DDF) Genesis 34 BETA TESTERS WANTED! Keenan smith Indoor Pattern/F3P 53 Oct 07, 2012 05:31 PM
