Old Sep 13, 2012, 09:35 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
New Product
ICE V4.02 Firmware
I see that itís listed in the history file as being released 9/12/12 but there is no new download to get it? Did someone forget to update the Download page or what?
http://www.castlecreations.com/downl...h-phoenix.html
RC Man is offline Find More Posts by RC Man
Old Sep 13, 2012, 09:41 AM
RC Man is offline
United States
Joined Feb 2001
Also does the new version solve the data log full problem? Flybarless controllers won’t let you power up at full throttle to clear the data log? That’s also a problem with multirotors.
Old Sep 13, 2012, 10:34 AM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
I'm wondering how CC can solve this problem, because it is complicated.
1) You don't always want to clear the memory, especially if you are logging several flights.
2) If the memory fills up, does the user really want to clear the entire log?
3) It is probably difficult for the microcontroller to figure out how to clear a single session, since due to data compression, it has a variable length. Then to take care of that, you would have to program in a more (I think) sophisticated file handling system. And does it do this on the "fly". I am not sure I want the micro to be taking care of bookkeeping while it is also keeping track of commutations!
4) Also due to the compression, it really isn't possible to simply overwrite previous data, since you may not really know how large (in bytes) each time stamp data point(s) is/are. So you are in danger of leaving partially cleared sessions in memory. Some of this stuff can be figured out offline where you can program a sophisticated reading program, but how to do it in realtime, with the micro handling a real motor (with lots of power going through it) isn't obvious to me.
I am not saying it can't be done, but just that there are some complications.
As to the full stick to enter programming/data clearing, this is probably a tough nut to crack too, because there are now so many "smart" things between the ESC and the battery that have their own safety systems. Back in the old days of simple receivers, you could use low, high, and everything in-between as special cases, but as you point out, the ESC has something between it and the receiver throttle channel output, it probably becomes almost impossible to have a simple coding that the ESC can use to enter specific states (like arming, programming).
I suppose you could have a "Morse Code" type affair, but most of us would screw it up (I know I would). The only thing I can think of is to use the Field Card plugged into the Castle Quick connect. I don't know if the Field card already supports stuff like this or not--I have one, but haven't actually used it for anything.
Long post--it would be good to hear something back from CC on where they are going here in the world where their simple stick programming is becoming hard to almost impossible to use.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Sep 13, 2012, 10:57 AM
RC Man is offline
United States
Joined Feb 2001
Well itís fairly useless they way it is now so they need to do something.
The most important thing is if you have a problem you always want to have the latest data available so that you can see what happened.
Maybe there should be some selectable options:
1. Do they way it is now
2. Auto clear the entire log when it gets full
3. Clear on power up if the Castle Link is not connected.
4. How about some other suggestions to help Castle out. They have been struggling with this problem for a couple of years and itís obvious that they need some new ideas.
Old Sep 13, 2012, 03:09 PM
3Dmuse is offline
Find More Posts by 3Dmuse
Ontario, Canada
Joined Sep 2009
Any changes of interest for those of us who still fly the internal governor?
3Dmuse is offline Find More Posts by 3Dmuse
Old Sep 13, 2012, 03:11 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Flybarless controllers wonít let you power up at full throttle to clear the data log?
Looks like I just found another benefit of wiring my BEC to a single 6s pack in my 12s setup.
Gregor99 is offline Find More Posts by Gregor99
Old Sep 13, 2012, 03:14 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Partner with Spektrum and Futabu to get CastleLive mainstream. Data is streamed to and stored on the Tx. Tx vendors should step up and display ESC logged data on thier under utilized displays.
Old Sep 13, 2012, 05:20 PM
Jonny1 is offline
Find More Posts by Jonny1
Joined Nov 2011
Or a external, easy to remove tiny logger.
Jonny1 is offline Find More Posts by Jonny1
Old Sep 14, 2012, 03:16 AM
DIGITDUCK is offline
Find More Posts by DIGITDUCK
Joined Dec 2010
Hey Gregor and jonny
take a look here http://www.rcgroups.com/forums/showp...94&postcount=8 , tom did it already and we will start betatesting now, we need one tester for mpx and one for jeti. Spektrum is the next step from tom.
DIGITDUCK is offline Find More Posts by DIGITDUCK
Old Sep 15, 2012, 08:11 AM
sandyem16 is offline
Find More Posts by sandyem16
sandyem16's Avatar
Enid, OK
Joined Jun 2006
Hey Clint..
What s the setup procedure for 4.02 and vbar?
sandyem16 is offline Find More Posts by sandyem16
Old Sep 15, 2012, 08:20 AM
rick0007 is offline
Find More Posts by rick0007
Joined Apr 2004
Works fine for me.
rick0007 is offline Find More Posts by rick0007
Old Sep 15, 2012, 11:41 AM
jdanks is offline
Find More Posts by jdanks
United States, OR, Bend
Joined Sep 2004
Anyone know if they fixed the motor start up issue so you don't have to crank the start up power all the way to get the motor to go?
jdanks is offline Find More Posts by jdanks
Old Sep 15, 2012, 12:41 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Thats a step in the right direction. But I had envisioned a feature integrated onto the Tx and telemetry Tx on the model. Log review on Tx screen as well as download to PC, which should be using Bluetooth.
Old Sep 16, 2012, 10:04 AM
nsg is offline
nsg
Find More Posts by nsg
nsg
Yardley, PA
Joined Sep 2006
In terms of what it should do, I don't see anything particularly complicated here. They should just record the last thirty minutes (or whatever the buffer holds). I suspect at this point it would be a substantial change for Castle, though, probably in h/w as well as s/w.
As a quick fix, perhaps Castle could add a log reset function to the field card?
nsg is offline Find More Posts by nsg
Old Sep 17, 2012, 05:59 AM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Not sure why the Beta release was held up...
There are some cool new logging options and the help menus are much better... As soon as it is posted to the web the download will show up.
Clintstone is offline Find More Posts by Clintstone
Discussion OPTIC 6 SPORT 2.4 - Firmware update V1.02(0) A.T. Hitec/Multiplex USA 4 Apr 11, 2012 08:24 PM
Discussion Was there any reported issue with ICE firmware v4 ? ricoalonso Castle Creations 3 Mar 30, 2012 07:57 PM
Alert OPTIC 6 SPORT 2.4 - Firmware update V1.02(0) A.T. Radios 0 Mar 05, 2012 03:58 AM
Discussion Firmware Phoenix, Phoenix HV, and Phoenix Ice Series 4.00 Beta 02/22/12 imagine 50 Castle Creations 25 Mar 04, 2012 01:24 PM
Question Firmware v4.5 vs. v4.7 Dave8888 Multirotor Talk 1 Dec 16, 2011 12:28 PM
