Old Sep 17, 2012, 06:04 AM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
Originally Posted by SilentPilot View Post
Hmm... Makes me think this actually has the 3000kv in there.
HH said the Cub came with a 2500 but we found it to be the better 2300. Do you think they are trying to kid us again? I suppose they could have re-engineered the 25 to make it better.
Tony
My cub has the 2500kv motor.
J
jabsten is offline Find More Posts by jabsten
Old Sep 17, 2012, 06:10 AM
FredM69 is offline
Find More Posts by FredM69
Joined Sep 2012
awesome case and hinges and wheel pants
Thank's !
what exactly are you "small plastique hinges " ?
i just cut in a small plastic box (about half millimeter thick) some hinges (about 2 cm long and 1 cm large). Then i bend each of them in the middel to get a good hinge and i glue it in holes i did with a cutter in both the wings and the ailerons and it works great !!
what are you wheelpants made of ?
You will find it here :
http://www.shapeways.com/model/29299...eel-pants.html
It is virtually indestructable and very light. I did it for the cone prop too and it never breaks anymore...
create your own hinges for UMX foamies--suggestions ?
My last floppy disc got tossed in 1992--well the 5 1/2" version anyway.
hinge tape? I have never used it but have seen it for sale[/QUOTE]
FredM69 is offline Find More Posts by FredM69
Old Sep 17, 2012, 06:42 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
J
Only if you've put one in yourself! It might say 2500 on the box but if you check the actual motor they are fitted with the [better] 2300kv version.
Originally Posted by FredM69 View Post
Hi Silentpilot,
I make this flight case by myself... i mean, i ordered the case and cut myself the inside to fit with the transmitter, one UMX sbach and Beast, one MCPX and one Blade 130X. Plus battery, chargers, inboard cam, some tools to fit any unwanted dammage and the sun glass... ;-)
A very good job you have done too Sir!
Do you care to share the internal dimensions of the cutouts? You can PM me if you prefer
Tony
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Sep 17, 2012, 06:44 AM
BMFA 190658
Joined Mar 2007
The old 5.25" floppy disks are I believe made of mylar. Cut up they make ideal hinges
Old Sep 17, 2012, 07:04 AM
GBLynden is online now
Find More Posts by GBLynden
I am GBLynden
GBLynden's Avatar
United States, WA, Lynden
Joined Mar 2011
If that is the case, go to Wal-Mart and pick an emergency blanket for a buck. Those are made of that material and will give you a lifetime supply.
GBLynden is online now Find More Posts by GBLynden
Old Sep 17, 2012, 08:05 AM
FredM69 is offline
Joined Sep 2012
Tony
Hi Tony,
No problem to share the cutouts but i don't have any dimension or plan. I begin with the sbach and transmitter, then i ad the beast 3D, and the 2 hélis... I just adapted the case with time, in order to put more and more material in it...
I can give you the internal dimensions of the case but for the planes and the hélis you must take the mesures of each "toys" and ad 2 cm for an easy tidying up. Take my picture to have an idee of how to place them correcly in order to be able to fit everything on that case size.
Inside mesurement of the case is 50cm large, 65cm long and 14cm height...
But be aware that if you want to place bigger planes or hélis you will have to buy a bigger case... It only fit for these models.
Hope you get enough info to make yours !
Regards,
Fred
Old Sep 17, 2012, 09:37 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by UNGN View Post
Thanks for the video, Chuck!
The Differences in flight characteristics shown in the video look the same as my stock Sbach and AS3X Sbach.
The AS3X plane is on rails while the non AS3X plane is balloony in the wind, when you move the CG back.
When you went to WOT, I have not heard that scream come out of either of my Sbachs. That sounded fast.
Yeah that sounded really fast, I have 3 2500kv motors and none of them sound like that. But My B3D with the 3000kv sounds EXACTLY like that. My guess is that they relabeled the 3000kv motors with 2500kv stickers or did some serious redesign.
Tony
I completely agree. I'm one of the few who has tested all three back to back. This plane flew exactly like my 3000kv, even sounded the same.
-Brian
kalmon is offline Find More Posts by kalmon
Old Sep 17, 2012, 09:52 AM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
How did you do that with that case? I'd have to hire a full time CAD designer to make all that fit in one case!! Do you have blueprints/designs?
-Brian[/QUOTE]
Brian,
Most of these cases have two layers of foam.
Lay the object flat against the top foam layer and trace an outline around it with a sharpie.
Remove the top foam layer and cut the traced out area with a kitchen electric carving knife.
Cuts like butter.
Many different inexpensive plastic gun cases out there.
My Tx case was $10 at Walmart.
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Sep 17, 2012, 11:33 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Originally Posted by RCBABBEL View Post
Brian,
Cuts like butter.
rc
Yeah I was talking about how many things were in that one case. It didn't even look that big. I think I'll have to try and make one myself.
Old Sep 17, 2012, 01:20 PM
eltreato is offline
Find More Posts by eltreato
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
With pleasure !!!
Best case ever Fred!
eltreato is offline Find More Posts by eltreato
Old Sep 17, 2012, 03:59 PM
lesodell is offline
Find More Posts by lesodell
good till the first drop
lesodell's Avatar
michigan usa
Joined Jan 2005
I cant wait
lesodell is offline Find More Posts by lesodell
Old Sep 17, 2012, 04:55 PM
Dave Eichstedt is offline
Find More Posts by Dave Eichstedt
Warbird & Jet Lover
Mahomet, Illinois
Joined Aug 2007
For the doubters regarding availability:
The Sbach 3D was on the water when we announced it.
Dave Eichstedt is offline Find More Posts by Dave Eichstedt
Old Sep 17, 2012, 05:44 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Thanks for the update. Would be nice to have one for the Spitfire and Ask-21 too...
RealGambler is offline Find More Posts by RealGambler
Old Sep 17, 2012, 06:30 PM
HuffDaddy is online now
Find More Posts by HuffDaddy
No Guts, No Glory!
HuffDaddy's Avatar
USA, WA, South Hill
Joined Sep 2008
at the risk of sounding like a dunce , I just did a search on this thread for "water"... I don't see any hits besides the post today
for those of us coming to the party a little late, need a little more info I think..
maybe I'm reading this incorrectly... is it being said the new SBach was already on the water the day it was revealed/announced? which looks like was Sept 12th...
HuffDaddy is online now Find More Posts by HuffDaddy
Old Sep 17, 2012, 07:24 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Dave, perhaps you can make the downloadable programming available for those of us that have the USB Programmer?
Good to hear that it'll be here soon!!
-Brian
Sold E Flite UMX SBACH w/AS3X - 2s, 3s - $118 OBO shipped flyrtim Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2012 11:42 PM
Sold E-flite UMX Sbach 342 NIB $135 shipped ton2di Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 29, 2012 03:41 PM
Discussion Baby S-Bach (E-Flite SBach UMX) mikhail tupulov Micro Ready-to-Fly 1 Aug 21, 2012 05:45 PM
For Sale E-Flite UMX SBach NIB $135 Shipped pldawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Aug 09, 2012 12:26 AM
Sold E-Flite Sbach 342 UMX mdv Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2012 09:29 PM
