Mike |
Not a single IN-N-OUT Burger joint in Idah .Nearest location is a 2hr 40min drive. W rth it!. . . Just got home from an amazing morning of flight. 3Sbach for my speed fix. 3SB3D for my flying fix. 60° & calm. ![]() ![]() rc ![]() ps...I grew up in Klamath Falls. Perfect view of Mt. Shasta out our kitchen window. Delta Darts continually in the air. http://en.wikipedia.org/wiki/Convair_F-106_Delta_Dart Flying control line planes and dreaming of RC. Good times! |
Delta Dart is a great name for that aircraft. We used to live in remote area of Trinty Co. on the Eel River. Military Jets would come in low through the river drainage to practice radar evasion below hill tops . I could see their helmets. My wife was a fire lookout. They would buzz her tower, one on each side below her position. One did a roll next to her tower! Glad they are on our side! ![]() Mike |
Joined Aug 2012
Pickle,
Thanks for the CA on control horn tip. I tried it and then flew. I can not believe how much better it flies now. It will actually fly straight instead of me always having to use a bit of rudder input. I thought this plane was amazing before... Now it is an even better flier. Thanks for the tip, Bumpy |
sorry had to go there. ![]() -Brian |
I will build a "washer" from thin servo arms- and glue this on the stock horn--fits perfect at my old SBach . Also a little problem is the U-linkage...we will see what we can do here...
Id be careful with the u bend. Itd be okay on the elevator or ailerons, but the rudder also controls steering.
I remember when people would add nose steering to the old PZ Cessna 210s the servo would always strip quickly unless they added a u bend. While these linear servos have come along way, so has the stress and weight and speed and AS3X built up pressure on the servo, Id stick to focusing on the control horn. |
Ca on the control horn worked well for me, just broke z bend loose after the glue dried, took all the slop out. I was thinking of bridging the u bend with a small piece of cf to see if it helps the dolphin tail action. on 3s I cant stress enough on prop balance, on the ground no bad vibes but when the prop unloaded in the air it sounded terriable past 3/4 throttle, I actually could get it to porpoise going vertical at full throttle..., smooth as glass on the ground at wot...
Oh man!
new Nano 300mah lipos with the UMX connector! http://www.hobbyking.com/hobbyking/s...mpatible_.html $4.90 each.... |
Edit: the 300s are 1 gram heavier. Danny |
| Thread Tools | |
| Sold E Flite UMX SBACH w/AS3X - 2s, 3s - $118 OBO shipped | flyrtim | Aircraft - Electric - Airplanes (FS/W) | 1 | Sep 11, 2012 10:42 PM |
| Sold E-flite UMX Sbach 342 NIB $135 shipped | ton2di | Aircraft - Electric - Micro & Indoor Airplanes | 0 | Aug 29, 2012 02:41 PM |
| Discussion Baby S-Bach (E-Flite SBach UMX) | mikhail tupulov | Micro RTF | 1 | Aug 21, 2012 04:45 PM |
| For Sale E-Flite UMX SBach NIB $135 Shipped | pldawg | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Aug 08, 2012 11:26 PM |
| For Sale E-Flite Sbach 342 UMX | mdv | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 12, 2012 08:29 PM |
