Old Oct 22, 2012, 06:36 AM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Originally Posted by flyrtim View Post
could you please provide link to digikey parts
http://www.digikey.com/
Female UMX (PH) Connector - Plane Side - 455-1705-ND (http://www.digikey.com/product-searc...Words=455-1705)
Male UMX (PH) Connector - Battery Side 455-1126-ND (http://www.digikey.com/product-detai...1126-ND/527357)
Pins for the Male Connector - 455-1318-1-ND (http://www.digikey.com/product-detai...18-1-ND/608807)
Take your time soldering, on the female sockets you can actually heat the pin up enough to melt the plastic housing enought to move them. It takes a very small amount. The pins for the male terminal are tiny so just a tad of solder is needed. I solder them and then used some pliers to bend the tabs doen around the soldered joint (or you could cut them off). Once the pin is soldered up they click into the male housing. I got enough for 50 connectors and I would have been able to only buy 7 with the pigtails attached.
IndyMatt is offline Find More Posts by IndyMatt
Old Oct 22, 2012, 06:42 AM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
I love this thing, it flies straight as an arrow for me! I got the tail beefed up last niight as well.. Probably do the same thing to my beast to prepare for the 3S powah!
Old Oct 22, 2012, 07:17 AM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Originally Posted by RealGambler View Post
The 325 is truly 12C (written on the pack as well) and trust me, it can take it! It's kind of funny when you have a bunch of them, and want to charge them in parallel! That's almost 4 amp for one single batteries, so if you have a lot, you need a really beefy charger, just for charging some tiny batteries. That's a very nice problem though!
Not 100% but I charged one of my 300 Nano packs at 4c and it charged in 11min
will up it to 5c to see how long that takes
Originally Posted by bobly View Post
Sure you are aware, but you haven't had to trim it with the transmitter have you? I have done this not thinking about the as3x system. It does not like transmitter trims in the mix. I have heard no more than 4 clicks, but I'm not sure even less than this confuse it somewhat.
I don't need much trim on my Sbach if any
yesterday it was that Ail that were going a little nuts while flying with the 2300kv motor.. with that motor being so quiet you can really hear the as3x working
brushless55 is offline Find More Posts by brushless55
Old Oct 22, 2012, 07:35 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
The Nano-Tech take 5C. I, myself, accidentally charged 4 of them at 12C. I knew one of those days, I would make a mistake, and I surely did! I found out because I very quickly got the beep for the balancing stage, so, I knew something was wrong. Batteries were not even warm. I probably added about 25 cycles on them since then, and they are still as good as my other ones. I would not recommend that at all though.
Normally, I don't charge them at more than 3C, and I would say most of the time, around 1C.
RealGambler is offline Find More Posts by RealGambler
Old Oct 22, 2012, 08:56 AM
big ignore list
Joined Nov 2011
I need to make some connectors to charge 6 of these packs at the same time on my balance board.. 6 lipos charged in 11min or so.. Heck yeah!
Old Oct 22, 2012, 09:02 AM
medic45 is offline
Find More Posts by medic45
United States, KY, Booneville
Joined Jul 2012
lol at brushless.. that would be sweet....
medic45 is offline Find More Posts by medic45
Old Oct 22, 2012, 09:47 AM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
I've been charging the NanoTechs @3 C since new---They don't even show a hint of being warm...On HK's specs for these batteries they list 2C as the max---I'm thinking this is a misprint..Oh, and at 3C it takes about 15 minutes to charge a batt from 3.75v to 4.20v
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Oct 22, 2012, 10:11 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Man, I love this thing more and more. I actually pulled the Mig out for the first time since I bought the Sbach and it felt like a SLUG. I was so bored of it, I put it away after one flight and it remained there the whole rest of the day.
I did have a rather exciting moment, following the Mig flight. I had switched my ailerons to high rates and forgot to change it back when I pulled out the Sbach. I thought it rolled fast before - it was a blue and black blur! I will DEFINITELY be switching to high rates here pretty soon.
This thing has me questioning how badly I really want that new Corsair. I'd LOVE to have a bigger Sbach to fly - anyone got any suggestions??
whichwaysup is offline Find More Posts by whichwaysup
Old Oct 22, 2012, 10:18 AM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by erkq View Post
Holy cow! 12C charging?? I've got the chargers to do that (2x200W) but my TP's are only 25C 250's, so I think I'd better stick to 5C charging... like is says I should... right on the pack. Am I being a wuss?
Erkq,
No. Those packs are not designed for 12c charging! Only the newer G6 65c packs are designed for that. Their G6 45c packs are designed for 8c charging, and most of their current lower-c packs are rated for 5c charging.
Originally Posted by airpower View Post
A year ago i thought 5C charging was the future....
5c charging has been available for awhile. Those of us who use Hyperions have been enjoying 5c charging with no reduction in performance or cycle-life for around 4 years. I have a number of larger Hyp 35c VX packs that are about 4 years old. After 300+ 5c charges, they still perform well in demanding apps, and none of them are the least bit puffy.
Originally Posted by turbovector View Post
I wonder why Horizon put servo covers on the Carbon Cub and not this one.
Because the CC is designed for ROW flying, while the Sbach is a strictly a land-based plane.
That's why I picked up a Thunder Power TP820CD for my larger stuff back when the 12c charge packs came out. Dual channels, 20A/400W max per channel, 8s support, 24 memories, and 10.5-28V input.
Originally Posted by whichwaysup View Post
......I'd LOVE to have a bigger Sbach to fly - anyone got any suggestions??
This 18%-scale 53" wood & carbon-fiber electric from Pilot RC would be an excellent choice. And it comes from a manufacturer that's noted for producing top-notch planes with impeccable handling & flight-qualities: http://www.chiefaircraft.com/prc-sbach18-01.html
Also, Hacker makes a 39" EPP version: http://www.hacker-model.com/uk/sbach1000.html
If you want something with excellent engineering & build-quality, that flies precisely & can handle some wind, I'd definitely go with Pilot RC's version.
Joel
turboparker is online now Find More Posts by turboparker
Old Oct 22, 2012, 10:24 AM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Would be?? It is.Why not go 8? http://www.rc-connectors.com/index.p...qlggbq9ielmmj3
erkq is offline Find More Posts by erkq
Old Oct 22, 2012, 10:31 AM
RCBABBEL is online now
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
BL55,
Fast parallel charging is better than peanut butter.
Even Jif!!
rc
My Sbach 3D ships today.
RCBABBEL is online now Find More Posts by RCBABBEL
Old Oct 22, 2012, 11:50 AM
jpt1205 is offline
Find More Posts by jpt1205
Mayday! Mayday!
jpt1205's Avatar
Joined Aug 2010
HK also has a parallel connector for 2S UMX style lipos that will charge 6 at once, with the power leads already soldered on...I have one and it works great, for only $3.99 you can't go wrong!
http://www.hobbyking.com/hobbyking/s...2S_Lipoly.html
jpt1205 is offline Find More Posts by jpt1205
Old Oct 22, 2012, 12:01 PM
erkq is offline
Joined Dec 2010
Oh... right... he sells ones with the connector leads already soldered on also. I just picked the wrong one to post.
Old Oct 22, 2012, 12:26 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
I suppose a big harness is neat, but I never really feel the need. I have two chargers and always charge the nano's at 5c. So I fly for around 6-7 minutes, recharge in around 11, so could almost fly continuously with 1 battery. Don't you just love these little 2 cell planes. I put my Yak up for slightly over 4 minutes and then have to put 2300 ma back in the $40 4-cell battery or fly my Sbach for 6+ minutes and put 110ma back in my $5 battery. And this is with a couple of cheapo 6 amp max charger which is way heavier than I really need for the 2c bats.
bobly is offline Find More Posts by bobly
Old Oct 22, 2012, 12:27 PM
Joined Mar 2007
Here's a nice foam Sbach that even comes with SFG's...Looks like the big brother to the UMX Sbach...
http://www.nitroplanes.com/60a-dy894...h342-arf.html#
Sold E Flite UMX SBACH w/AS3X - 2s, 3s - $118 OBO shipped flyrtim Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2012 10:42 PM
Sold E-flite UMX Sbach 342 NIB $135 shipped ton2di Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 29, 2012 02:41 PM
Discussion Baby S-Bach (E-Flite SBach UMX) mikhail tupulov Micro Ready-to-Fly 1 Aug 21, 2012 04:45 PM
For Sale E-Flite UMX SBach NIB $135 Shipped pldawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Aug 08, 2012 11:26 PM
Sold E-Flite Sbach 342 UMX mdv Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2012 08:29 PM
