From the beginning I thought the SBACH was stupid (what is an Sbach, anyway.. why not a Warbird) and overpriced, but fly one with AS3X and you will think this is THE GREATEST MICRO PLANE EVER.
With the new lower price and $4 batteries available from multiple vendors, this plane is a must have in everyone's fleet. This is the plane everyone thought the Original SU-26m would be when we first saw the videos 4 years ago... then we realized we weren't Professional World Aerobatic champions and could do none of that stuff with the Sukhoi. This plane will do that stuff. |
Latest blog entry: AR6400 guillows Space Shuttle
USA, CA, Chico
Joined Feb 2011
![]() I got my Nano 300mah 35/70c packs yesterday and today the weather is looking very nice.. but I have a busy day at work so...... ![]()
I do. However - the 5043 preformed dismally on my V1 Sbach & Beast 3D both in static & flight-testing, and the stock prop seemed to outperform the 5030 in my Sbach 3D flight-tests. I don't expect that the 5043 will perform any better in this app, but I'll do an abbreviated test with a Hyp 240. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
OK BABY! not sure if its just me, but this as3x makes landings a bit harder for me ![]()
Come in slow, point it slightly downwardwith a touch of down elevator and let the AS3X lock it in, throttle little less than1/4. Don't float in and cut throttle, it will "plop and squeal". I had to read up and run through 2 batteries doing low fly bys, touch and go's. Hard to practice when what you want to do is to point it towards the sky and rip.
Mike |
BL - It isn't just you. Not sure if ground effect kicks in and throws the Gyro off, or if something else is at play, but it seems like at exactly 1 foot off the deck, earth repels this plane. . . .until you come down on the prop.
I'm no expert, but thanks to (arrgh, can't remember who to credit), I rarely hit the prop anymore. Here's the ticket that seems to deliver some really nice, consistent, greased landings: 1) Keep a negative attitude. No, not you - the plane! keep that nose pointed DOWN as long as possible. Once it starts doing that tail-squatting thing, it you have to go into "alternative landing" mode (see below). 2) when you get a foot or two off the deck, let the nose level out a bit and watch the plane closely, if it is still dropping vertically, apply power (you may be surprised by how much it can take and still descend). 3) Pour on plenty of backstick when you are about a foot off the deck. you'll be in high alpha at this point, so don't be afraid to give (even more) throttle. If I did this with my GeeBee, it would be disasterous - the GeeBee would shoot up into the air. The Sbach doesn't. Even with power, the extreme elevator just seems to provide less lift and the thing settles down - sometimes tailwheel first. Alternative landing: If you do come in "flat" and you can see the tail wagging up and down as the gyro avoids tip stall, you've got to give it a significant amount of elevator and then significant amounts of power. Again, you're shooting to get into a high alpha position. Your entire goal is to keep the prop up and the tail down. Not sure why this works for the Sbach - on any other airframe, even an AS3X equipped one, this would be a recipe for a nasty tip stall. On the Sbach, though, it's the recipe for a beautiful landing. A few posts back, i posted a link to UNGN's video on the regular Sbach thread - watch his landings (it's a converted V1 with As3X) and you'll see what I'm talking about. |
Remember that when you're on approach, elevator controls airspeed, while throttle controls rate-of-descent. Set up your approach attitude (which controls airspeed) with elevator & then control the descent-rate with throttle. Resist the temptation to chase the descent-rate with elevator on the way down. AS3X will do its best to maintain the attitude last commanded all the way down to the deck. If you're coming in a bit slow, smoothly relax the elevator a bit. If you're coming in hot, ease back on the stick a bit to slow down. If it looks like you'll land a bit short, smoothly add a bit of power. If you're coming in a bit long, smoothly reduce power. If you master the above landing technique, you will be in command of your landings, and you'll be able to put most any plane right where you want it on the runway. If you do full-stall 3-point landings as WWU described, the elevator stick will be nearly all the way back during the flare, and it will be all the way back as the plane settles into ground-effect just before touchdown. As we know, AS3X authority diminishes as stick-deflection increases & it is completely bypassed on a particular axis at full-stick. So, if you do full-stall 3-point landings, AS3X will have little effect on the plane's behavior in pitch during the landing. Check out WWU's landing practice clip: http://www.rcgroups.com/forums/showp...&postcount=553 Check out my touch & goes in the clip I posted on Tuesday - starting at the 8:30 mark: http://www.rcgroups.com/forums/showp...&postcount=528 Joel |
Well said, Joel - it is amazing how much power you have to put on just before touching down. I'm finding that, the more I fly this thing, the more able to predict it's behavior (right about now is when jinxed myself and will crash due 100% to pilot error). I find that you have to pour the throttle on BEFORE the plane drops, otherwise it's too late and you hear that God-awful screeching noise when the prop strikes pavement.
By the way - NICE landing right there at the end of the video! |
| Thread Tools | |
| Sold E Flite UMX SBACH w/AS3X - 2s, 3s - $118 OBO shipped | flyrtim | Aircraft - Electric - Airplanes (FS/W) | 1 | Sep 11, 2012 10:42 PM |
| Sold E-flite UMX Sbach 342 NIB $135 shipped | ton2di | Aircraft - Electric - Micro & Indoor Airplanes | 0 | Aug 29, 2012 02:41 PM |
| Discussion Baby S-Bach (E-Flite SBach UMX) | mikhail tupulov | Micro RTF | 1 | Aug 21, 2012 04:45 PM |
| For Sale E-Flite UMX SBach NIB $135 Shipped | pldawg | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Aug 08, 2012 11:26 PM |
| For Sale E-Flite Sbach 342 UMX | mdv | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 12, 2012 08:29 PM |
