Old Oct 17, 2012, 07:09 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by whichwaysup View Post
So a split an inch down the prop - is that bad?
naw, just get out some scissors and fix it right up
-Brian
kalmon is offline Find More Posts by kalmon
Old Oct 17, 2012, 07:10 PM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
So apparently the lesson here is nicks in the prop and or bent prop adapter can happen fairly easily with these little guys,, and in my case can apparently cause vibrations that can make the ASX go nuts
Airman74 is offline Find More Posts by Airman74
Old Oct 17, 2012, 07:47 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
I would be too. It was gusting over 10 yesterday and it was still fun, but if it had been any stronger there's NO WAY I would have risked it. Thing is just to pretty to do that to!
LOL
If you look at what I posted the gusts were 39MPH
I've flown my V1 in 10-15mph and had a blast, but 20-40mph winds I'de rather fly in calmer weather to really see and enjoy this one on its maiden flight
plus 40mph gust is about what this plane does for top speed I would think..
full throttle harriers
would be a hoot to catch that tail wind with my Bushnell!
brushless55 is offline Find More Posts by brushless55
Old Oct 17, 2012, 08:23 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Yup. Any plane that uses a gyro on the roll-axis will be sensitive to an out-of-balance prop. Just like heli flybarless controllers, which are sensitive to main & tail rotor vibration.
Joel
turboparker is offline Find More Posts by turboparker
Old Oct 17, 2012, 08:40 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Stuck a balanced 5043 on her to test out as the hobbyshop was out of 5030's.We will see how it goes!
IndyMatt is offline Find More Posts by IndyMatt
Old Oct 17, 2012, 08:55 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
I know we suspect this 2500kv is different from past 2500kv. But if it's not that prop is going to really load it up.
erkq is offline Find More Posts by erkq
Old Oct 17, 2012, 08:59 PM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
Load it up amp draw wise? I forgot that I kept all of my stock props from other planes, so I have plenty of OEM props to switch back to.
Old Oct 17, 2012, 09:02 PM
erkq is offline
Joined Dec 2010
Yes. And you don't get the rpm's either. The performance is pretty poor. The 2300kv motor is the only one the really shines using the 5043. But people have noticed the 2500 is this new Sbach seems to be stronger than the old ones.
Old Oct 17, 2012, 09:04 PM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
Got two flights in tonight between the rain and flew in 10 mph winds with gusts over 15 at the time. It was fun and she just penetrated the wind like nothing. Much better flights as I was at ease just throwing her around. Trying to land was interesting even with power off the plane wanting to just hold about a foot off the ground. It takes a lot of down elevator to get her to the ground, may be my CG.
Old Oct 17, 2012, 09:06 PM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
Well I would take a video of the flight but my keychain cams usb port is toast, tried to resolder it and it was no good. Ordered another and it will be here next week.
Old Oct 17, 2012, 09:08 PM
erkq is offline
Joined Dec 2010
I meticulously cut foam out so my 450mAh GensAces would fit as I've been reading about people using 400 and wanting to try 500mAh batteries. I was able to get the CG good at 36mm but it's really too heavy for my taste. The plane is so much more nimble and versatile with a Hyperion 240mAh pack.
For those following my performance travails, I swapped another 2300kv motor into it. The old motor spun 9,000rpm on a fresh pack. Thisnew one spins 10,500! (both with the same 5043) I wonder what the heck happened to that 9,000 motor. It spins freely by hand, sounds normal. It just doesn't have to punch.
Now verticals are unlimited with both the 450's and the 240's.
Old Oct 17, 2012, 10:50 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
I am confused, Clarification please
with 5043 on all motors?, with same battery on all
2300 kv spun ___
old 2500 spun ___
new 2500 spun- 10,500 ?
flyrtim is offline Find More Posts by flyrtim
Old Oct 17, 2012, 11:00 PM
erkq is offline
Joined Dec 2010
2300 kv spun ___
old 2500 spun ___
Ah... All motors were 2300kv. All props were 5043. First motor was 1500 rpm down for some reason and it made the plane feel lethargic. I swapped the 2500 out after the first flight. I'm spoiled by the quiet of 2300 power.
Old Oct 17, 2012, 11:05 PM
Joined Jul 2009
I noticed that with mine. Nonetheless, the stock prop seems to outperform the 5030 on my S3D, while the 5030 was the clear winner on both of my V1s. Go figure...
The plane has plenty of performance for me as it is, but I will most likely install a 2300 & 5043 soon. In my crystal ball, I also see an Sbach 3S3D in my future... I don't recall ever complaining about having too much power in anything - full-scale, RC, lawnmowers, cars, whatever. In fact, there has been no such thing as too much power since the throttle was invented.
Joel
Old Oct 17, 2012, 11:10 PM
WSEN is offline
Find More Posts by WSEN
McCarthy, Alaska
Joined Jun 2004
OK, you guys convinced me. Called HH and used my 15% code from taking a survey to order one. Said they are in stock and shipping
wohoo!
WSEN is offline Find More Posts by WSEN
Sold E Flite UMX SBACH w/AS3X - 2s, 3s - $118 OBO shipped flyrtim Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2012 10:42 PM
Sold E-flite UMX Sbach 342 NIB $135 shipped ton2di Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 29, 2012 02:41 PM
Discussion Baby S-Bach (E-Flite SBach UMX) mikhail tupulov Micro Ready-to-Fly 1 Aug 21, 2012 04:45 PM
For Sale E-Flite UMX SBach NIB $135 Shipped pldawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Aug 08, 2012 11:26 PM
Sold E-Flite Sbach 342 UMX mdv Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2012 08:29 PM
