Old Sep 26, 2012, 09:00 PM
kalmon is online now
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by jabsten View Post
Well my new as3x sbach build went sour today when my 3S flight was cutoff in mid flight. The esc shut off, and I couldn't get the plane to land smoothly causing a break in fuse and front...I tested before flight and it wasn't shutting off. After I came inside it was working again. No 3S flight for this conversion...bummer because it was very fast for the one minute I flew it. Sucks because I spent so much time on the build, and it went south. At least the cracks were easily repairable. Guess I won't be trying it on my as3x beast. I was using 2500kv motor and 5030 prop....
J
The Sbach, without modification has absolutely ZERO airflow to the Voltage regulator. On mine I added a cooling hole directly under the VR to allow it to stay cooler. I also strongly recommend adding a heatsink to the ESC and VR to prevent these shutdowns.
-Brian
kalmon is online now Find More Posts by kalmon
Old Sep 26, 2012, 10:31 PM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
-Brian
I figured that was what was happening. Some people haven't needed to do the vent cooling or heatsinks. I don't really know how to add heatsinks so I will be back to 2S. I will be selling my 4 new babbelbatts I just purchased.
J
jabsten is offline Find More Posts by jabsten
Old Sep 26, 2012, 10:34 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
J
My Beast does something kinda like this
I have to throttle back to 0 for a couple seconds and the esc rearms and I can fly again... but again that's on my Beast.. now on my Sbach I have no issues at all..
brushless55 is offline Find More Posts by brushless55
Old Sep 27, 2012, 12:59 AM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
I wasn't even at full throttle when it would shut off...I am afraid to try on the beast. I don't like having no control.
J
Old Sep 27, 2012, 01:03 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
J
Yeah... the Beast is pretty tough to fly with no damage without power. It literally flies like a brick.
erkq is online now Find More Posts by erkq
Old Sep 27, 2012, 10:41 AM
wgarman is offline
Find More Posts by wgarman
More Planes Than Sense
wgarman's Avatar
United States, PA, Wexford
Joined Feb 2010
J
Had the same problem with my GeeBee. HH said it may have been a 'servo' issue. (no other explanation given) They had me send it in. Sent back a new plane.
wgarman is offline Find More Posts by wgarman
Old Sep 27, 2012, 10:46 AM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
I can't wait for this one to come out, sold my V1 hoping they would release an AS3X version. Actually like the thunderbolt pattern better but I ain't complaning!
IndyMatt is offline Find More Posts by IndyMatt
erkq is online now
Joined Dec 2010
I think they're discussing running it on 3S! I believe HH would say it's an over-voltage problem and leave you on your own.
Old Sep 27, 2012, 11:54 AM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
Lol
Old Sep 29, 2012, 05:24 PM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
3s is impressive, but I think this one would really like to stay as light as possible..
3000 kv motor adds 1000 rpm and bolts in with no modification.
Stay 2s and save weight for best 3d performance.
MikeRx is offline Find More Posts by MikeRx
Old Sep 29, 2012, 06:57 PM
big ignore list
Joined Nov 2011
J
My Beast would cut out at anything over 75% throttle
but my Sbach runs WOT on 3s till my timer beeps
3D the lighter 2s sestup is better, but on 3s we are at around 250 watts per lb+
stock 2s is about 110 watts per lb
Old Sep 30, 2012, 07:06 PM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
This has probably been covered but since I didn't see it I'll go over it...
I was experimenting with 3S and damaged the ESC on my Beast brick...NitroCharged (Dave) gave the point out on the brick to get the throttle signal, so I installed a separate external 6 amp ESC...I got everything working so I went out for a test flight...I checked the throws and discovered that the ailerons were reversed...I must have got the aileron servo plugs reversed on the brick---No big deal, I'll just reverse the servos in the TX...Got everything working in the correct direction and the AS3X seemed to be working properly as well...I hand launched and the plane was ALL OVER THE PLACE and crashed into my pond in the back yard...After retrieving the plane from the pond I dried everything out and went to try it out again---This time taking off from the asphalt street...I advanced the throttle and it looked good so I gave some up elevator...The plane lifted off about a foot and I initiated a right turn...All of a sudden the plane snapped over on its back and nosed in on the asphalt as though the ailerons were reversed!!!...Broken prop, destroyed spinner, and a small amount of road rash but it could have been worse...I got to thinking---I reversed the ailerons but I was wondering if the AS3X system was still in the normal non-reversed mode...I looked at the ailerons with the AS3X active and it LOOKED to be functioning properly...Just to be sure I removed the canopy hatch for the umpteenth time and put the servos back into their proper recepticles on the brick---Retaped the hatch back on and went out to fly with the street light now on and almost dark...I again took off from the asphalt as the last hand launch had me lacking confidence in a hand launch...I advanced the throttle and she lifted off---AND FLEW LIKE THE AS3X SYSTEM IS SUPPOSED TO FUNCTION!!!...I was back in business!!!
The bottom line is to NOT reverse the ailerons in the TX but do it with programming in the brick if necessary...I recommend to NOT reverse anything and go with factory default settings...By not going with my gut and being too lazy to open up the fuselage cost me a pristine looking plane...The Beast isn't too banged up but as we all do, we want to keep a plane as pristine as possible for as long as possible...Oh---And I did all of this testing/flying in the rain!!!..(I've been flying models for 42 years and have this flying itch BAD!!!)
This post is just a heads up or a reminder if already posted that reversing any control surface in the TX with an AS3X brick can cause the plane to not fly...(Non-AS3X equipped bricks will do FINE if you need to do a reverse in the TX...)
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Sep 30, 2012, 08:30 PM
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Kevin
Very True, I know I've said it before! It is also in the user manual for the AS3X USB Programmer!
-Brian
Old Sep 30, 2012, 09:07 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
Kevin
Weird I reversed my ail through my tx on my build and the as3x worked fine.
J
Old Sep 30, 2012, 09:41 PM
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
J
Well it's not important that the TX is reverse or normal but that the Brick is moving the control surfaces correctly from AS3X corrections. See above.
-Brian
Sold E Flite UMX SBACH w/AS3X - 2s, 3s - $118 OBO shipped flyrtim Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2012 10:42 PM
Sold E-flite UMX Sbach 342 NIB $135 shipped ton2di Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 29, 2012 02:41 PM
Discussion Baby S-Bach (E-Flite SBach UMX) mikhail tupulov Micro Ready-to-Fly 1 Aug 21, 2012 04:45 PM
For Sale E-Flite UMX SBach NIB $135 Shipped pldawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Aug 08, 2012 11:26 PM
Sold E-Flite Sbach 342 UMX mdv Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2012 08:29 PM
