Old Dec 02, 2012, 12:35 PM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Originally Posted by 1st timer View Post
Well got my maiden over and done with(Saturday),Wow what a nice plane 3/4 throttle andCG set at 22mm (hood opening to end of battery) 180mah first then 200mah after and now battery position is 20mm,gentle push and we're off with nothing unexpected
This thing flies so well high alpha's, KE,s no problems at all can fly slow with confidence,but hovering I found a little harder at first as I've got to pulse the throttle to get it to come up high and straight.by the 3rd battery I was doing blenders 1foot high speed KE's across the field and back and still haven't tried the SFG's yet.
Today(Sunday) I went to the local hockey club,to use there carpark for a fly,it was a little windy with afew gusts,no idea what the wind speed was cause that didn't seem to matter for me that is,doing my usual thing but this time it got away from me and flew over my head and lost it and I piled it into the ground(nose 1st ) but to my surprise it didn't explode(Tough little sucker) but only cracked the underside of the cowl and bent the prop adapter.
So it's fixed now with afew pieces of CF stripe and abit of CA and I used the motor&prop out of my Hyper Taxi,so for the moment it's all good to go...hey what effect will the lager prop have on this little beasty?
Later
If you have the stock motor, the 2500kv, the recommended upgrade prop would be the GWS 5030. If you aren't familiar with the change over, the GWS blades are great, but need balancing. Also when you pull the stock blade off take care not to lose the small o-ring spacer that holds the prop away from the cowling.
The Sbach is a favorite of mine. Have many great flights with it.
shastamike is offline Find More Posts by shastamike
Old Dec 02, 2012, 04:09 PM
Dannyboy85 is offline
Find More Posts by Dannyboy85
Dannyboy85's Avatar
United Kingdom, England, Southport
Joined Jan 2011
5030 is great! I have about 100 flights on mine and its still going strong! Only thing I have had to fix is removing the broken "wheel pants" and the tail fin came unglued so the little carbon rod came out... NBD.
Dannyboy85 is offline Find More Posts by Dannyboy85
Old Dec 02, 2012, 04:27 PM
justinlee1 is offline
Find More Posts by justinlee1
justinlee1's Avatar
United States, GA, Atlanta
Joined Sep 2012
Guys, I was having oscillation issues with my Sbach AS3X and finally fixed it. I started an AS3X thread here if anyone is interested in splitting the topic into its own easily indexed area:
http://www.rcgroups.com/forums/showthread.php?t=1781549
justinlee1 is offline Find More Posts by justinlee1
Old Dec 02, 2012, 05:43 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by RCBABBEL View Post
Not yet on the S3D.
Edge got all the attention.
Decided not to fly my S3D until she gets the cf mod treatment.
Going 3S on maiden.
rc
Hey RC,
Did you get the maiden in yet??
Joel
turboparker is online now Find More Posts by turboparker
Old Dec 02, 2012, 06:22 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Originally Posted by turboparker View Post
Hey RC,
Joel
PM sent.
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Dec 02, 2012, 06:54 PM
Dannyboy85's Avatar
Joined Jan 2011
E-Flight UMX Sbach 342 (3 min 53 sec)
Old Dec 03, 2012, 12:07 PM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Nice Flying! Landing takes a little while on these. . .
whichwaysup is offline Find More Posts by whichwaysup
Old Dec 03, 2012, 01:18 PM
Joined Jul 2009
Yeah, nice flying! Regarding the landing - if you manage descent rate with throttle & manage airspeed with elevator, and carry a bit of power all the way down, you'll be able to grease her in right at your feet just about every time.
Joel
Old Dec 03, 2012, 02:16 PM
AustinG is offline
Find More Posts by AustinG
United States, FL, Eustis
Joined Oct 2012
Danny,
Is the airplane in that video stock or 3S? It seemed to really be moving.
AustinG is offline Find More Posts by AustinG
Old Dec 03, 2012, 04:14 PM
Dannyboy85's Avatar
Joined Jan 2011
Originally Posted by AustinG View Post
Danny,
I am using the 2s 260mah Nanotec along with a 5030 GWS prop so it is an improvement over the stock prop and crappy e-flight battery's.
Old Dec 03, 2012, 06:06 PM
AustinG is offline
Joined Oct 2012
Thanks, seemed normal watching it now on my pc. Had watched it before on my phone which made seems look smaller, farther away, and thus faster.
Old Dec 03, 2012, 06:31 PM
Dannyboy85's Avatar
Joined Jan 2011
Perhaps a cheaper way to go faster is fly looking through binoculars backwards..
Old Dec 04, 2012, 09:18 AM
AustinG is offline
Joined Oct 2012
Call it the alternative to flying in a smaller venue for the same effect.
Old Dec 04, 2012, 10:37 AM
Dannyboy85's Avatar
Joined Jan 2011
Haha exactly.
Old Dec 04, 2012, 07:19 PM
JJ460 is offline
Find More Posts by JJ460
United States, OR, Sherwood
Joined Jan 2009
Just picked up my Sbach UMX today. Are the wing servo's connected via a Y-connect or ?. I am thinking I would like to program them for flaperons if the brick is reprogrammable like the earlier AR6400's. If it has already been done and explained in this forum, please let me know where so I don't have to look through 100 pages of records. Tx....JJ460
JJ460 is offline Find More Posts by JJ460
Sold E Flite UMX SBACH w/AS3X - 2s, 3s - $118 OBO shipped flyrtim Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2012 10:42 PM
Sold E-flite UMX Sbach 342 NIB $135 shipped ton2di Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 29, 2012 02:41 PM
Discussion Baby S-Bach (E-Flite SBach UMX) mikhail tupulov Micro Ready-to-Fly 1 Aug 21, 2012 04:45 PM
For Sale E-Flite UMX SBach NIB $135 Shipped pldawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Aug 08, 2012 11:26 PM
Sold E-Flite Sbach 342 UMX mdv Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2012 08:29 PM
