Old Nov 29, 2012, 05:21 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Threw the SFGs on the Sbach today for the first time, and had good fun! It slows the roll rate, aids in knife edge (of course!) and also makes it a bit easier to see at a distance. Not sure how much I'll fly with them but it was a nice change of pace. I tried both sets and decided if you are going to do it, best bet is to go all the way, so I liked the larger ones better, but can see why someone who just wants a *bit* more side force would want the smaller set.
tracknoob is offline Find More Posts by tracknoob
Old Nov 29, 2012, 08:17 PM
Var. is offline
Find More Posts by Var.
United States, CA, Burlingame
Joined Jul 2012
Originally Posted by turboparker View Post
BTW - the Beast 3D can fly a lot slower than any other plane in its category. Remember - it is a true-scale biplane that even has scale symmetrical airfoils. As with the Sbach - one would not expect it to fly anything like a 3D flattie. They are simply different tools in the toolbox. If one wants to do aerobatics in slow-motion, one flies an F3P ship. I started watching F3P about a year ago. Absolutely amazing. There's a video of an F3P ship with AS3X on the first page of the AS3X FAQ thread. I have never seen anything so graceful & fluid. It was as if it were flying in oil.
Joel
Nice i'll have to look at that video. If you know of any FP3 plans that can be scaled down to the size of an sbach and still fly proper I'm all ears.
Var. is offline Find More Posts by Var.
Old Nov 30, 2012, 08:19 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Originally Posted by erjpilot View Post
So I have a pretty good dent in the leading edge of one wing on my SBach. Are you saying if I put hot water on it, it will pull the dent out? If so, how hot? Tap water hot or close to boiling?
Thanks, Travis
Travis - try hot water - not boiling, and be careful. Too hot and it will blister, not hot enough and it won't do anything. I usually bring the water to just below boiling and then watch the foam carefully, dipping and holding it under for a 30 seconds at a time and massaging the foam in between dips.
If that doesn't work, go get some DAP light weight spackling. It is great for filling in big gaps in the foam. I flew my Sbach into a tree and got some similar dents in the wing's LE, so I used the spackling on it, and smoothed it out with a light piece of cardboard folded over to match the airfoil. Once it dried, I use a black sharpie to color it - not a perfect texture/color match so I did the entre leading edge - then covered the entire leading edge with a piece of scotch tape. I think the repairs are somewhere on this thread.
Anyway - it worked great.
whichwaysup is offline Find More Posts by whichwaysup
Old Nov 30, 2012, 08:56 AM
erjpilot is online now
Find More Posts by erjpilot
Qtown, PA
Joined Dec 2003
whichwaysup,
Thanks, I will give the hot water a try. I think I may end up with the spackle fix in the end though as it is a petty good dent. Tree grabbed mine as well...
Travis
erjpilot is online now Find More Posts by erjpilot
Old Nov 30, 2012, 10:56 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Took the Sbach out in some high winds with huge gust component today -- wrote a quick note about it here:
http://www.rcgroups.com/forums/showp...postcount=1855
Old Nov 30, 2012, 11:25 AM
Joined Apr 2012
Horrifically off topic, Tracknoob, but did I see that you ripped your LG off the HK balsa Sbach? I'm slowly wearing down my wife to allow me to get one, curious if you'd still recommend it.
Old Nov 30, 2012, 11:58 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Yup, I tore it clean off with a bad landing on rough field. I guess it's standard to replace the provided cap screws with plastic screws so that they shear off instead of breaking an internal support from a bad landing, but I got that memo too late!
I liked the way it flew except for being underpowered on the Park 450, so no regrets here: I've got some plank and also stick balsa from LHS in order to see if I can create a new landing gear mount, and I got an .10 Rimfire for it, too.
Not sure it can be repaired, or what it will look like when I'm done, but I'll give it a shot when I have the time.
EDIT TO ADD:
Okay, here she is -- full of Gorilla Glue, a new Rimfire 10, an upgraded 40 Amp ESC, and a 11x6 prop -- all full of pith and vinegar ready to hit the field tomorrow. Either those gear will hold or they wont....if not, I guess I've now got a little more experience and all the running gear to field a replacement airframe...
Old Nov 30, 2012, 08:54 PM
Tomdomification is offline
Find More Posts by Tomdomification
Tomdomification's Avatar
Joined Sep 2011
I had my second flight yesterday. Once again it was pretty windy, especially for a second flight, but it handled fine. I tested the vertical power on this plane and I can say it's a change be from the Micro T-28. At full-power it really goes up!
I'm pretty desperate to fly this plane be when it's calm as it's hard to get an idea of the flight characteristics in wind.
Still, it's very fun and looks awesome in the air!
Tom
EDIT: I forgot to mention, my Dad and I think we might have worked the dodgy servo. At full down-elevator, the little lip from the heat-shrink tube on the pushrod was getting stuck on the servo itself. We carefully shaved and got rid of the lip on the tube. The servo works fine now, so hopefully that's fixed it as replacing the servo looks pretty hard!
Tomdomification is offline Find More Posts by Tomdomification
Old Nov 30, 2012, 08:57 PM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
I'm putting in a 2300/5043 combo and I was warned that the 2300kv leads to the esc were short and needed to be lengthen with wire, but really....they are just about a quarter inch short! So close, yet so far. Fire up the soldering iron time for me.
shastamike is offline Find More Posts by shastamike
Old Nov 30, 2012, 09:00 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
A miss is as good as a mile... as they say. We don't have leaping electrons in the 7 to 11 volt range yet.
erkq is offline Find More Posts by erkq
Old Nov 30, 2012, 09:05 PM
shastamike's Avatar
Joined Jun 2010
Ya..I tried stretching the wire also...that didn't work.
Old Nov 30, 2012, 11:47 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
i've been running the 5043 on the stock 2500 with no problems.
jim350 is offline Find More Posts by jim350
Old Nov 30, 2012, 11:54 PM
erkq is offline
Joined Dec 2010
The only problem is you don't get the performance. If you compare what you're running to a 5030 on the 2500 or a 5043 on a 2300, you'll see why people don't generally run the 5043 on the 2500. It sags out.
Old Dec 01, 2012, 01:32 AM
jim350 is offline
Joined Aug 2011
Haven't noticed any sag.
I tried the 5030 first however the 5043 seems better to me.
I am running 300mah 35c nanotechs so maybe my batteries are delivering the required amps.
Old Dec 01, 2012, 01:47 AM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
I like the 5030 on my 2500kv motor running 300mah nano
and 5043 on a 2300kv motor, and that combo is my favorite!
brushless55 is offline Find More Posts by brushless55
Sold E Flite UMX SBACH w/AS3X - 2s, 3s - $118 OBO shipped flyrtim Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2012 10:42 PM
Sold E-flite UMX Sbach 342 NIB $135 shipped ton2di Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 29, 2012 02:41 PM
Discussion Baby S-Bach (E-Flite SBach UMX) mikhail tupulov Micro Ready-to-Fly 1 Aug 21, 2012 04:45 PM
For Sale E-Flite UMX SBach NIB $135 Shipped pldawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Aug 08, 2012 11:26 PM
Sold E-Flite Sbach 342 UMX mdv Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2012 08:29 PM
