Old Nov 28, 2012, 10:09 AM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Originally Posted by brushless55 View Post
I ask so I know how much to right the check
Originally Posted by Kevin Greene View Post
GOOD comeback!!!!...Gotta put that one to memory!!!......
Kevin
Like this play toy I picked up last week!
brushless55 is offline Find More Posts by brushless55
Old Nov 28, 2012, 11:20 AM
Var. is offline
Find More Posts by Var.
United States, CA, Burlingame
Joined Jul 2012
Originally Posted by erkq View Post
There's a lot of reading here in this thread that would answer that question if you were really interested. There are only a couple of 3D moves this thing can't do and that's because it has no mass. For example, it can't do a pop-top.
But, crimony... how can you sell such a capable plane that will run on 3S and give you 300watts/lb.?? Ah, well... to each his own...
I guess those are good reasons. But meh. I didn't like it. Oh well. I bought a profile plane from RAcores. We'll see how that works out once I build it.
Var. is offline Find More Posts by Var.
Old Nov 28, 2012, 11:28 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by Var. View Post
I bought this model a couple weeks back. Flew it 4 or 5 times and sold it to a friend. I dunno what it is that people enjoy about them. I think eflite is using the term 3D a little loosely.
Sorry it did not work out for you.
And, as a very happy owner and a frequent flier of both the ASX "3D" Beast, and the ASX "3D" Sbach, I agree 100% that they are using the term 3D a bit loosely, on those two offerings in particular.
Now, when it comes to the new Edge540qq.... I think the term is right on the money!
Woot -- - the mailman brought the new 450mah 3S packs for the Edge just now, so I'm ready to hit the park with it this afternoon!
tracknoob is offline Find More Posts by tracknoob
Old Nov 28, 2012, 11:29 AM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Nice timing.
shastamike is offline Find More Posts by shastamike
Old Nov 28, 2012, 12:35 PM
TurboRacer is offline
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
My converted V1 Sbach just developed a high speed elevator flutter out of nowhere..
I examined and the "hinges" on one side separated. I taped the langth of the hinge and was happy that I thought I found the problem... Nope.. Still flutters at high speed.. Very rapid flutter, barely affects the way it flies, but I can tell when it's happening. And I can hear the servo, sounds like a dolphin. hahaaa
What else to check? I tried a different hole on the control horn and same result.. I'm about to just do a new fuselage/tail if I can't figure it out.
TurboRacer is offline Find More Posts by TurboRacer
Old Nov 28, 2012, 01:04 PM
Fish99 is offline
Find More Posts by Fish99
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
Originally Posted by Tomdomification View Post
Well I maidened! It was a pretty short flight though as it got too dark. The battery charged fine with the Parkzone charger as well.
The plane feels very floaty after flying the Micro T-28. I think it's because it has so much power :-)
The landing was tough too as I couldn't really see the plane and my elevator was on low-rates (70%). Because I was landing on grass, I was planning to harrier in but I didn't have enough throw and it just flipped forwards with no damage.
The bad news: I have a dodgy elevator servo! After flying, my Dad and I looked at the throws to adjust the dual-rates. On full down elevator, the servo just hung for a few seconds. I brought the travel down to 90% but it still stuck. It has become even worse and now when I use down elevator it gets stuck at about half-stick!
It's a pity as I don't want to pester Modelflight about replacements!
What do you guys think I should do?
Tom
Tom,
DEFINATELY go back to Modelflight and get a fix. (I am sorry, have not pulled the SBach open, so not sure if it is a separate servo, or integrated to the board.) HH is excellent here in North America on their service, so assume MF will be the same for them over there.
Marlin
Fish99 is offline Find More Posts by Fish99
Old Nov 28, 2012, 01:08 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
How many hours are on the servos? Maybe the elevator servo just needs to be cleaned.
Joel
turboparker is online now Find More Posts by turboparker
Old Nov 28, 2012, 01:17 PM
kalmon is online now
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Tom
The servos are not on the brick like the B3D, all 4 servos are separate. With it being new you could take it back to MF, however if you can source some DeOxit that might fix up the servo.Get the F series Fader lube. I give mine a tiny squirt every 50 flights or so.
-Brian
kalmon is online now Find More Posts by kalmon
Old Nov 28, 2012, 01:44 PM
shastamike's Avatar
Joined Jun 2010
I have a bad aileron servo. Sometimes gets the jitters. Not up and down flapping like its looking for center. Just the jitters. I've sprayed it with DeOxit, but no fix. I wonder if I have to take it apart and clean it also? BTW...its not the AS3X that kicking in, it does it before throttle up and on the bench at home.
Old Nov 28, 2012, 01:49 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
too much play in linkages, u-bend?
extra glue on horizontal stab where meets fuse?
extra carbon rod on horizontal stab?
flyrtim is offline Find More Posts by flyrtim
Old Nov 28, 2012, 02:00 PM
shastamike's Avatar
Joined Jun 2010
I'm rebuilding my Sbach after a very bad landing, actually there wasn't much of a landing, more like an explosion of Styrofoam. FoamTac is amazing and I used it to make hinges on the ailerons. Used too much and the aileron wasn't flexable enough so I took a hot blade and removed about 3/4 of the cured FoamTac. Aileron is servicable, but doesn't look so good now. The fuse is probably on it's last fix and so is the wing. I'm wondering about a rainy day rebuild. Should I use airframe parts from the old version Sbach or the new? My Sbach is a converted old version.
Old or new? What do you guys think?
Old Nov 28, 2012, 02:14 PM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
If it were me, I'd put an ad out on classifieds for aiframe only and see what pops up. I'd guess that there are a lot of folks who might want to buy a new version just for the guts to put into their old V1. Personally, I think the new version is prettier, though I have to admit that I've lost orientation with it once or twice.
So, my vote is - get what you can, and if given a choice, go BLUE!
whichwaysup is offline Find More Posts by whichwaysup
Old Nov 28, 2012, 02:15 PM
Var. is offline
Joined Jul 2012
Wow..you think it's good huh? After flying the Beast and the Sbach, I thought to myself I can't trust eflite's 3D branding. But then when I watch videos on the 540qq, it really DOES look like a 3D plane. I just don't wanna spend the money to be disappointed again.
But maybe the 540qq is what I need.
Old Nov 28, 2012, 03:17 PM
dalecheek1 is offline
Find More Posts by dalecheek1
United States, NC, Garner
Joined Nov 2012
maybe ...some ....SKILLSSSS.....LOL
dalecheek1 is offline Find More Posts by dalecheek1
Old Nov 28, 2012, 04:26 PM
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
I'll admit that the branding 3D was used loosely. However the sbach3d is perfectly capable of almost all 3D maneuvers. Pop-tops being an exception, then again anyone that expects a 2oz piece of foan to have the energy required is delusional.
-Brian
Sold E Flite UMX SBACH w/AS3X - 2s, 3s - $118 OBO shipped flyrtim Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2012 10:42 PM
Sold E-flite UMX Sbach 342 NIB $135 shipped ton2di Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 29, 2012 02:41 PM
Discussion Baby S-Bach (E-Flite SBach UMX) mikhail tupulov Micro Ready-to-Fly 1 Aug 21, 2012 04:45 PM
For Sale E-Flite UMX SBach NIB $135 Shipped pldawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Aug 08, 2012 11:26 PM
Sold E-Flite Sbach 342 UMX mdv Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2012 08:29 PM
