Old Dec 02, 2012, 12:41 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
The first is 40mm and the second is 25mm.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Dec 02, 2012, 03:06 AM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
i like the 25mm with that 16,000kv motor, i bet the thrust from that is insane. I hope you post some stats about that setup.
chester2240 is offline Find More Posts by chester2240
Old Dec 02, 2012, 04:41 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
test results.
EDF weight: 3.9 grams (scale 0.1 resolution)
motor: bidproduct 2.3 ohm (low Kv motor)
spektrum AR6400
370mah 1S nano
draw: 327mah spike, 300mah normal
thrust (static): 4.9 grams
thrust to weight: 1.25
draw per gram: 61.22 mah/gram of thrust
conclusions:
thrust to weight ratio is too small for all but the lightest electronics. a deltang and acts might work. a 70mah 25c cell could run a 4 engine jet. 19 grams of thrust, 16 in engine weight.
a 30 gram AUW aircraft would mean an airframe weight of 11 grams. probly doable, but not a very good solution.
next up is a trying to bump up thrust with a shroud.
nemoskull is offline Find More Posts by nemoskull
Old Dec 02, 2012, 04:43 AM
nemoskull's Avatar
Joined Sep 2009
am i the only one who likes the above setup?
some how it makes me feel like im in the dawn of the jet age, when thrust was low, throttle was touchy and planes could bearly take off, and multi engined mosters with common...
edit: like, WW1, only with turbines
edit2:
2s test. WOT (battery direct)
2.3 ohm
10 second - 15 grams thrust
15 second - 12 grams thrust
20 second - 4 grams turust - dead.
this is 8.4 volts. i wonder how it would do at 5 or 6 volts. maybe a high PWM ESC set at 6 volts?
i must try later. (think i still have a few motors.)
edit3: we all assume these are only 1S motors, in fact, they are 1v motors. i must runs some tests later.
Old Dec 02, 2012, 08:55 AM
jahel is online now
Find More Posts by jahel
United States, FL, Clearwater
Joined Jun 2011
There is a quick test
40mm bim shroud
NEU 705 20mm motor
1050mah 30c 3S lipo
CC esc
BIM40mm EDF NEU Motor (0 min 29 sec)
jahel is online now Find More Posts by jahel
Old Dec 03, 2012, 02:07 PM
Joined Nov 2007
I thought some of you might be interested in this.
http://www.hobbyking.com/hobbyking/s...elicopter.html
If it can run on 2s, it should be a pretty good motor for the 25mm outrunner unit.
Old Dec 03, 2012, 08:55 PM
nemoskull's Avatar
Joined Sep 2009
oops, broke my houseing! the fit was tight, and when trying to remove motor, it cracked! stupid me, i knew it was over tight, but did nothing about it, but shove it in.
on an intresting note, the 2.3 motor get 3.6g max when the wrong rotor is used.
i tried an albatros motor, reads about 1.4 ohms, tho tat may be wrong.
i get 5 grams at 50% thrust, draw 415 mah
6.2 grams at 100%, draw of 520 mah
perhaps the rotor is stalling out?
edit: im selling this one, as i have no use for one. bim, ill be buying more from you soon, if thats okay
Old Dec 03, 2012, 09:08 PM
Joined Nov 2007
Which unit broke?
As far as stalling out, Joe A10 proved better in air performance than static performance. I'm really not surprised at the fact that the static thrust numbers aren't that high.
Old Dec 03, 2012, 09:41 PM
nemoskull's Avatar
Joined Sep 2009
yeah, i was thinking that as i was posting. EDF are different from open air props.
at any rate, im down to one unit and i need a twin to fly. (ar6400 and all that).
probly order some 22mm 7mm units later this week.
hobbyking has been out of stock on the 10mm motors forever!
i have two in back order.im tempted to just keep ordering one at a time as i can. they have to get them in stock sometime....
Old Jan 08, 2013, 10:45 AM
Joined Nov 2007
I heard back from SW. Simply put, that 0.7mm minimum thickness does not account for margin of safety. I have to go back over key areas.
Old Jan 09, 2013, 01:30 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
BIM, i know its not fan related, but i love the BRZ! or is that a FRS?
corsair nut is offline Find More Posts by corsair nut
Old Jan 11, 2013, 12:55 PM
Joined Nov 2007
Thanks. It's the FR-S.
Old Jan 11, 2013, 02:55 PM
jahel is online now
Joined Jun 2011
nice ride!!!
Old Feb 15, 2013, 12:19 PM
Joined Nov 2007
^ Thanks.
pdawg asked if I could make the 40mm shrouds "no rotor trimming needed". I epanded the ID by 0.6mm which puts them at 40.6mm. That should swork for the GWS rotor and as far as I'm aware, the AEO shrouds are GWS altered copies so the AEO rotors should work too. I'm just waiting on confirmation.
Old Feb 15, 2013, 01:18 PM
Joined Nov 2007
size reference...
Sold K&B .82 Ducted Fan Engine (New) Steve35436 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 27, 2012 09:37 PM
Sold 2 Turbax Fan. 2 K&B .45 Ducted fan engines one new Green Fuel Boy Aircraft - Fuel - Jets (FS/W) 2 Jun 16, 2012 11:58 PM
For Sale 2 Turbax Fan. 2 K&B .45 Ducted fan engines one new Green Fuel Boy Aircraft - Fuel - Jets (FS/W) 0 Mar 02, 2012 06:33 PM
For Sale bimRC NDF22 Shrouds: 22mm Ducted Fans boredom.is.me Aircraft - Electric - Jets (FS/W) 2 Jan 28, 2012 11:06 PM
For Sale bimRC NDF22 Shrouds: 22mm Ducted Fans boredom.is.me Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 28, 2012 11:05 PM
