Old Sep 30, 2012, 10:51 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
BIM, is this your 22mm unit?
I found in bottom of a box of parts purchased.
I sanded the rotor down so it fit in the housing, mounted it on a Mustang 8.4mm and it seems like it makes an OK amount of thrust for being so tiny.
I'd like to get some more of these.
Do you sell the 6 blade rotors?
Also, is there is reverse rotation rotor since these spin the brushed motors backwards?
UNGN is offline Find More Posts by UNGN
Old Sep 30, 2012, 11:31 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Yep, that was from the very first batch back in 2010! The 8.4mm housing too. I don't think I've seen anyone else actually use that combo though. If I recall correctly, they were too heavy compared to the amount of thrust they put out.
Is there any chance that you would be able to get some numbers for that unit right there?
If you are really interested, I can dig it back up and add a few updated features to it.
Those rotors are GWS rotors, but I do have my own rotors from my smaller units that I can work with. I'll have them ready by Wednesday. I can make them reverse rotation too. Do you think the motor needs to be loaded more?
boredom.is.me is offline Find More Posts by boredom.is.me
Old Oct 01, 2012, 01:09 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
7mm might be the best route to go. I made a test rig out of plastic cups and it makes about 10g of thrust with a 6.6g weight. If a 7mm makes the same 10g of thrust, it will save 2.5g per motor, @ 7mm motors are only $2 instead of of $8.
I think I will be ordering some 7mm housings from you. I'm thinking of a "throttled" 2S mini 747 or A380.
Old Oct 01, 2012, 10:39 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I tested the Albatros 7mm wih a GWS 6 blade fan in a 22mm housing.
AUW was 4.5g with plug... probably less because I used duct tape to make up the difference between 7mm and 8.5mm. Thrust was over 8g.
If you'll make them, I'll take 6 pcs of belled 22mm housing for a 7mm motor.
Old Oct 03, 2012, 11:44 AM
Joined Nov 2007
I got the 7mm shrouds finished and up to spec. They have a theoretical mass of 1.14g. They have the same specs as the DF22.
DF22
* I.D. = 22mm
* O.D. = 23.4mm
* O.D. with Lip = 28mm
* Motor Option(s) = 7mm, 10mm, 2g outrunner
* Stator Count = 3
* Optional Intake Lip = yes
* Weight of 7mm =
* Weight of 10mm =
* Weight of 2g Outrunner =
* Specific Rotor = no
I also got the rotors completed, but I'm not sure which is the better option: 3 blade or 4 blade...
I'll shoot you a PM.
Old Oct 03, 2012, 01:07 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The cut down GWS Rotor seems to load the 7mm fine and it doesn't get too hot... I don't think it got hot at all...
Kev,
What do you think the thrust difference would be going to the smaller diameter...say 20mm? If the thrust is about the same, I'd go with the smaller housing.
Or going with a 3 or 4 blade SLA rotor instead of the GWS unit in the 22mm housing?
I will order 2 22mm housings for 7mm motors, 4 20mm housings and rotors for these (maybe 3 Std and 3 reverse rotation)
PM me a quote for this and I will paypal you.
I'm thinking of trying these on a DF A380 with a Mosquito brick to see if it will work, before building something full fuse.
Old Oct 03, 2012, 02:45 PM
Joined Nov 2007
We can compare it to Joe's test. That was with a much smaller motor and 2mm less toward the diameter. With the same rotor (of appropriate diameter), it won't make less. I'ld say that 8g sounds reasonable. Now the 7mm can obviously handle more than any 6mm, much less the Ares super short motor.
How does this sound? For every 3 blade rotor you get, I'll add in a 4 blade at my expense.
No matter what units you get, the cost for the std rotation is the same as the counter rotation.
I'll get on it.
DF18
* Motor = Ares 6mm 4.5ohm Coreless with unknown capaciter
* Motor Option = 6mm
* Thrust = 4.8g
* Rotor = DF18 Rotor
* Cell Count = 1s
* Current =
* Weight = 2.1g
- Thanks to Joe Malinchak
The DF A380 is a good idea!
Old Oct 03, 2012, 04:13 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
That's sounds good, just shoot me a total and I'll paypal you.
I have a lot of projects so I'm not in a huge hurry for the units.
Old Oct 18, 2012, 02:49 PM
Joined Nov 2007
SO MANY PARTS! I just finished cleaning them. Now I have to trim them. Finally, I'll have to sort them for shipping.
There are all of the rotors in both rotations as well as many of the different shrouds from 15mm to 22mm with and without lips.
Description:
Old Oct 18, 2012, 05:27 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Did you hear that a new shapeways factory was just opened in NYC? That should make getting parts the US faster.
pdawg is offline Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old Oct 18, 2012, 05:51 PM
Joined Nov 2007
Ya I saw. It looks nice too. I think it is just a bigger facility than before though.
Old Oct 18, 2012, 07:23 PM
jahel is offline
Find More Posts by jahel
Commonwealth of Puerto Rico
Joined Jun 2011
Have a better shipping cost too???
jahel is offline Find More Posts by jahel
Old Oct 18, 2012, 07:25 PM
Joined Nov 2007
$6.50 is a standard US shipping cost.
Old Oct 18, 2012, 08:29 PM
jahel is offline
Joined Jun 2011
Bim I send you a PM...
Old Oct 18, 2012, 09:05 PM
Joined Nov 2007
I'm going to start including screws that can be used to mount most sub 25mm and under units, provided your order passes through me. It's just something I'ld like to throw in as extra.
UNGN will be the first of this offer (aside from when I sold complete units).
Sold K&B .82 Ducted Fan Engine (New) Steve35436 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 27, 2012 09:37 PM
Sold 2 Turbax Fan. 2 K&B .45 Ducted fan engines one new Green Fuel Boy Aircraft - Fuel - Jets (FS/W) 2 Jun 16, 2012 11:58 PM
For Sale 2 Turbax Fan. 2 K&B .45 Ducted fan engines one new Green Fuel Boy Aircraft - Fuel - Jets (FS/W) 0 Mar 02, 2012 06:33 PM
For Sale bimRC NDF22 Shrouds: 22mm Ducted Fans boredom.is.me Aircraft - Electric - Jets (FS/W) 2 Jan 28, 2012 11:06 PM
For Sale bimRC NDF22 Shrouds: 22mm Ducted Fans boredom.is.me Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 28, 2012 11:05 PM
