Old Feb 15, 2013, 01:44 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
where are you guys getting the gws40mm rotos?
chester2240 is offline Find More Posts by chester2240
Old Feb 15, 2013, 01:50 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
GWS is no longer a prominent company like they used to be. They chose to try and sell inventory that no one wanted. Eventually they stopped come out with new products and now the only thing you'll know them for are smaller propellers.
I wouldn't recommend their blades since there are much newer and better designed blades from AEO. I referenced GWS because AEORC used all of the same measurements as GWS.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Feb 15, 2013, 01:58 PM
Joined Jul 2011
o so hows that 8 blade Aero rotor doing ? I just orderd one for my 32mm it will be used with a 4800kv inrunner
Old Feb 15, 2013, 03:06 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Radicalrc.com has them but they will shred with too much power. The Aeorc rotors have never come apart on me. I've tested them in excess of 350 watts and they are probably good for a lot more. Additionally the 2mm shaft adapter is very nice when it comes to servicing the power system. Gws does have a new rotor with adapter but I have not personally tested it. It might be better than the aeorc rotor in terms of efficiency at lower power levels but aeorc is hands down the way to go for high power at this particular time....untill something new comes out
pdawg is online now Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old Mar 19, 2013, 09:55 PM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Bim,
Here is your 35mm shroud with the Aeorc rotor. It's almost a perfect fit. Would you consider enlarging the shroud diameter by the half the shroud thickness so the fan won't require trimming? The 40mm shroud is now a perfect fit with the stock aeorc rotors
Old Mar 19, 2013, 10:17 PM
Joined Nov 2007
Sweet. Thanks for the update. I'll make that change.
Old Mar 20, 2013, 12:10 AM
Joined Jul 2011
I'll take a quick video tommaro with some pics of it running it sounds pretty good.
32mm 4700kv inrunner (maybe more) and 4s lipo and 8blade rotor trimmed down.
Old Mar 27, 2013, 07:33 AM
vrex is offline
Find More Posts by vrex
Denver
Joined Mar 2004
boredom.is.me,
Looking to build this:
Nitrocharged's 25mm EDF Micro BAE Hawk
Using a AR6400 with a Turnigy Plush 6A esc on 2S.
Would like EDF and motor, could you tell me how to order this?
vrex is offline Find More Posts by vrex
Old Mar 27, 2013, 11:40 AM
Joined Jul 2011
opps Wrong thread..........
Old Mar 29, 2013, 03:47 PM
Joined Nov 2007
I honestly do not knkow what the best setup would be. You might be better off with a 25mm edf powered by the new 8mm motor. It would be a lighter setup.
Can anyone else chime in here?
Old Mar 30, 2013, 12:30 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
I need to order some more EDf from you. I got a mini vapor brick begging to be put in a foot ws A-10
nemoskull is offline Find More Posts by nemoskull
Old Mar 31, 2013, 08:34 PM
Dr Komet is offline
Find More Posts by Dr Komet
Dr Komet's Avatar
Joined Mar 2005
8 mm brushless inquiry
Hi BIM,
I posted on my blog a quick test result of the 8mm brushless motor in a 30mm fan that I have been tinkering with. The numbers are for a 3 blade GWS cut down fan. The pics are with a 6 blade fan.
More info soon.... sorry I've been out of town. Dr Komet
Dr Komet is offline Find More Posts by Dr Komet
Old Apr 05, 2013, 09:24 AM
FanTasticModels is offline
Find More Posts by FanTasticModels
Southlake, Tx
Joined Apr 2002
UNGN-please call Jerry Small 817 379 6468 .We have some common interest
FanTasticModels is offline Find More Posts by FanTasticModels
Old Apr 05, 2013, 10:20 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Jerry,
I'm in Tokyo right now and am flying to Singapore in a few hours, but I'll give you a call when I get back to Texas.
UNGN is offline Find More Posts by UNGN
Old Apr 19, 2013, 05:39 PM
Joined Nov 2007
pdawg, Here is the spacer I came up with. The I.D. is 6mm. I can't make the I.D. any larger due to material thickness. And I believe this is the only way to be able to put everything together before sticking it into the shroud's motor housing.
For the 35mm, I expanded the I.D. by 0.8mm which is half the shroud thickness on both sides. That's kind of a weird one to explain. Either way, the old I.D. was 35mm. Now it is 35.8mm.
Sold K&B .82 Ducted Fan Engine (New) Steve35436 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 27, 2012 09:37 PM
Sold 2 Turbax Fan. 2 K&B .45 Ducted fan engines one new Green Fuel Boy Aircraft - Fuel - Jets (FS/W) 2 Jun 16, 2012 11:58 PM
For Sale 2 Turbax Fan. 2 K&B .45 Ducted fan engines one new Green Fuel Boy Aircraft - Fuel - Jets (FS/W) 0 Mar 02, 2012 06:33 PM
For Sale bimRC NDF22 Shrouds: 22mm Ducted Fans boredom.is.me Aircraft - Electric - Jets (FS/W) 2 Jan 28, 2012 11:06 PM
For Sale bimRC NDF22 Shrouds: 22mm Ducted Fans boredom.is.me Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 28, 2012 11:05 PM
