Old Oct 20, 2012, 05:28 PM
Mud Duck Bill is offline
Find More Posts by Mud Duck Bill
Mud Duck Bill's Avatar
Up State New York , USA
Joined Mar 2009
Only a few things to go. Come on Chris you have to play catch up.
Bill
Mud Duck Bill is offline Find More Posts by Mud Duck Bill
Old Oct 20, 2012, 10:47 PM
skydanz is offline
Find More Posts by skydanz
Sky's not the limit, ground is
skydanz's Avatar
United States, CA, Grass Valley
Joined Dec 2007
Awesome job Bill! I flew mine again off floats and really amazed a lot of guys at how well it flies. Of course I took all the credit but I didn't have the heart to tell them how easy it is to fly.
You'll be wowing them with yours in no time!
DC
skydanz is offline Find More Posts by skydanz
Old Oct 21, 2012, 03:57 AM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Bill ...that looks great........One little bit of advise.........suggest that you cut back the shaft on your motor ,so that none of it is exposed as it is very easy to bend the way you have it.
If the prop adapter is up tight to the body of the motor ,...then you are less lickley to bend it if you should nose over {not that you will}
I am a long way behind you........but this is the way that I tackled different parts.
Chris..........
britinoz is offline Find More Posts by britinoz
Old Oct 21, 2012, 09:25 AM
Joined Mar 2009
Chris:
We could be brothers, I like all your building methods it will make your finished product rather sleek! .Now if I can finish mine up today maybe I can hobble up to the field tomorrow for a Maiden, Dam leg is giving me a fit. Keep up the good work and post things as they unfold always helpful to us all !!
Bill
Old Oct 21, 2012, 06:55 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Brothers .......... Stumble & Fumble.....
Old Oct 22, 2012, 02:27 PM
Joined Mar 2009
Well fumble,
Stumble is done but all I can do is sit and look at it. I don't fancy standing on the field with crutches doing a maiden. Unless I can sweet talk someone to take me to the field. And help me out a little I'll have to wait till I can walk on my own again. A picture to follow !
Bill.
Old Oct 22, 2012, 04:42 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Looking good Bro.............
Old Oct 22, 2012, 09:22 PM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
Looks great Bill....I like how you mounted your servos on the side. Very nice!
Hope it goes well! It looks the part!
Joe
jodini is offline Find More Posts by jodini
Old Oct 22, 2012, 10:48 PM
skydanz is offline
skydanz's Avatar
Joined Dec 2007
I hope it's not your hips again there buddy. Have you been following dr's orders?
DC
Old Oct 24, 2012, 02:59 AM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Hey Bro...
Sorry but I just had to stick myself in the drivers seat..........and added a few panel lines.....
now I have to add a couple of decals and stick it all together
Happy Landings
Chris..
Old Oct 24, 2012, 08:27 AM
jodini is offline
jodini's Avatar
Joined Sep 2004
That is sweet! Love it Chris!
Joe
Old Oct 24, 2012, 09:46 AM
Joined Mar 2009
Chris you must be the older smarter brother, a fantastic job! Love the pilot scene and the window pains. Mom always liked you best.
Bill
Old Oct 24, 2012, 03:14 PM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Bill/Chris,
Great work...I should be getting mine in the next few days
What motors are you guys using? is it specifically shoe horned around electric?
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Oct 24, 2012, 03:27 PM
Joined Mar 2009
Rich
Check post # 44 that is my set up, I don't think you have to be pigeon holed to use just electric I think nitro would work too. Place the tank where the lipo would set add small servo for throttle up front and your done! Nitro would give you a bit more hang angle with the extra weight,mine hangs at 15 degrees just enough according to the manual.
Bill
Old Oct 25, 2012, 08:35 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Gentlemen
I do believe that this model is more suited for EP over IC...although I am sure Joe may not agree.
This kit has a very good selection of light balsa and 1/6 ply and in my opinion may need a little 'beefing" up to handle the vibrarion of an IC. The kit is well designed and goes together very easy.
As I have been flying the Scout for a few months with 37 flights to date, I have decided to use the same power set up as well as the same servos. The reason being that they both share the same head and rotor blades and the OAL is similar.The Kellett will I believe be a little heavier but as I never used more than half throttle on the Scout I think that all will be OK.
I have used smaller servos than recomended and am not concerned of them failing.
I have also made another minor modification by joining the two side panels to the profile with 2.5mm carbon rod,this is done to help transfer the hoad and keep it all nice and square with out adding weight.The rudder servo is also set up with a pull/pull system {as I did on the Scout.}
The motor I used is a Turnigy 3536-1100 with a 10 X 5E APC{copy} and the head servos are Corona CS-238MG that come with the clips to mount the servo on there side { that is required for this model .} The biggest job now is to make a respectable cowl/radial to stick on the front and at the moment I don't have a clue what to use.
If I were living in the U.S.then I would send for one of the vac formed dummy radials that are available over there ,but I just can't bring myself to pay twice as much in post as the item is worth.
Happy Landings
Chris.........
Build Log Eastern Airline Profile Kellett staying with I.C. Boneswamped Auto Gyros 172 Aug 27, 2011 11:01 AM
Discussion Profile Kellett out of Retirement... imsofaman Auto Gyros 14 Jul 01, 2010 07:01 AM
Discussion Profile Kellett Face Lift.... imsofaman Auto Gyros 8 Dec 11, 2009 02:39 PM
Discussion Profile Kellett *Movies* Last Flight... imsofaman Auto Gyros 125 Oct 16, 2009 05:01 PM
Discussion Profile Kellett 3 FUN Videos!!! imsofaman Auto Gyros 89 Sep 25, 2009 10:31 AM
