Old Sep 25, 2012, 03:09 PM
skydanz is offline
Find More Posts by skydanz
Sky's not the limit, ground is
skydanz's Avatar
United States, CA, Grass Valley
Joined Dec 2007
Originally Posted by jodini View Post
I'll have some video of this one flying later. A guy in the club built this prototype and really enjoyed it! Another guy joining the autogyro club!
Joe
Your buddy did a great job flying! Must have been all the professional coaching. Kudos for a great flying machine!
DC
skydanz is offline Find More Posts by skydanz
Old Sep 26, 2012, 09:17 PM
Sofaman NJ is offline
Find More Posts by Sofaman NJ
The 1st Sofaman
Sofaman NJ's Avatar
United States, NJ, Hawthorne
Joined Mar 2012
Don,
What a great job on your build. Red on the bottom and inside the stabs is brilliant. So.....you are flying off of land and water???? OMG! I was grinning ear to ear! On the water....it was so nice....I just could not believe it. So happy for you!
Much thanks to Joe Cole for his hard work and dedication. The support he has given to everyone is fantastic. All the things he does behind the scenes that no one knows about.....is bared none. He is the best!
Congrats Don!!!! I will be showing off these videos tomorrow.
Dave
Sofaman NJ is offline Find More Posts by Sofaman NJ
Old Sep 30, 2012, 10:12 AM
Mud Duck Bill is offline
Find More Posts by Mud Duck Bill
Mud Duck Bill's Avatar
Up State New York , USA
Joined Mar 2009
Geee I wish mine would show up in the mail box , maybe the RABBIT got lost !!
Bill
Mud Duck Bill is offline Find More Posts by Mud Duck Bill
Old Sep 30, 2012, 11:01 AM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
I wish it would too Bill! I shipped it September 20th with tracking! I bet your postman is building it as we speak!
Joe
jodini is offline Find More Posts by jodini
Old Sep 30, 2012, 12:34 PM
skydanz is offline
skydanz's Avatar
Joined Dec 2007
Thanks Dave. The Kellett was a joy to build. It flew perfect right off the building board. The new delta head works great. I'm going to try a different prop on the motor I used because the power was marginal. If that doesn't improve performance, I'll go to a larger motor. The floats were the same ones I made for the Scout. The mounts worked perfectly on the Kellett. There is no water rudder but in calm wind, it steered quite nicely.
The only major change I made was to the tailwheel mount. I prefer to have the steering wire parallel to the rudder hinge line. Other than adding a couple notches in the fuse side to allow Velcro straps to be inserted and a 1/2" hole to allow the servo wires to pass through to the RX mounted underneath, no other mods were made.
All the major parts of the fuse were covered prior to assembly for ease of covering. The wire bending for the UC can be a little daunting and I did manage to make an error. But it actually worked out better for me in the long run, and one less solder joint per side.
The Kellett is very stable and predictable in flight, no doubt due to the profile fuse sides. The elevon controls were easy to set up and gives a very stout control feel. ROG takeoffs start with full up elevator until just before full spinup, then zero elevator and add power. I was prepared to add some right aileron as it lifted off but found that barely any, if at all, was needed. Even on floats, the only corrections needed were to compensate for wind direction as it got light.
I had a blast flying the Kellett off water and put at least two flights on it each day while the wind was calm. Getting it back to shore once the wind picked up was a big challenge and I had to nearly fly it back to me.
Bill, the Kellett is worth the wait. I just hope it isn't lost!
DC
Old Sep 30, 2012, 07:30 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
G.Day Don
I was thinking that the motor and servos required would be very similar to those of the Scout.............
Chris..........
britinoz is offline Find More Posts by britinoz
Old Sep 30, 2012, 07:39 PM
The 1st Sofaman
Sofaman NJ's Avatar
Joined Mar 2012
I will be building mine soon.
Old Sep 30, 2012, 07:41 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Me to....................
Old Sep 30, 2012, 07:54 PM
skydanz is offline
skydanz's Avatar
Joined Dec 2007
Originally Posted by britinoz View Post
G.Day Don
Chris..........
I actually took the power gear off my Scout to get it in the air. While it does fly it pretty well, it's not near as peppy as the Scout. The Kellett is a little heavier and has considerably more drag. I used higher torque servos for the head per Joe's recommendation. You could probably use smaller servos but I liked how positive the controls felt, especially with the added weight of the floats.
DC
Old Sep 30, 2012, 07:57 PM
The 1st Sofaman
Sofaman NJ's Avatar
Joined Mar 2012
Hey Chris!!! G'day mate! So glad seeing you will build the Profile!!!!
Dave
Old Sep 30, 2012, 10:58 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
G'Day Dave .............Thanks Don.......
I have a C-30 profile as well as a Scout and they both fly pretty good.......the funny thing is that most people donn't pick that they are profiles untill they get up close after I have been flying........
Happy Landings
Chris
Old Oct 02, 2012, 11:26 AM
jodini is offline
jodini's Avatar
Joined Sep 2004
Just shipped out 4 more Kellett kits. Let me know when you guys get them.
Bill,
Your tracking number 03121430000137203639 for USPS says it was delivered on Saturday Sept. 29th. You better find that rabbit!
Joe
Old Oct 02, 2012, 10:26 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
What motor size, esc size, servo size, etc. are recommened for this bird?
Sammy70 is offline Find More Posts by Sammy70
Old Oct 02, 2012, 10:39 PM
jodini is offline
jodini's Avatar
Joined Sep 2004
Hey Sammy,
25 size electric motor
3 cell lipo (2100 mah)
two high torque servos (about 60 oz and up)
Regular servo for tail (you have the option to go standard servo or mini)
If you PM me your email address and I can send you the manual and you can look it over.
Joe
Old Oct 06, 2012, 10:12 AM
Joined Mar 2009
It finly arrived !
Well it arrived on Oct 4th, It must have been in the back of the postman's truck for days, That pesky rabbit must have been hiding it.
As you know I am in the middle of the Sig conversion and that is oh so close to flying. I have opened the Kellett up and taken a look see at the instructions looks like a quick and straight forward build. May get started right a way. A few picture to show future builders how very complete this kit is.
Bill
Build Log Eastern Airline Profile Kellett staying with I.C. Boneswamped Auto Gyros 172 Aug 27, 2011 11:01 AM
Discussion Profile Kellett out of Retirement... imsofaman Auto Gyros 14 Jul 01, 2010 07:01 AM
Discussion Profile Kellett Face Lift.... imsofaman Auto Gyros 8 Dec 11, 2009 02:39 PM
Discussion Profile Kellett *Movies* Last Flight... imsofaman Auto Gyros 125 Oct 16, 2009 05:01 PM
Discussion Profile Kellett 3 FUN Videos!!! imsofaman Auto Gyros 89 Sep 25, 2009 10:31 AM
