Espritmodel.com Heli Air
Old Sep 12, 2012, 01:15 PM
Estonia, Harju County, Tallinn
Joined Jun 2012
Scrachbuild Rc hovercraft MAX FORCE XRT-617
Started building it in march 2012. Now its allmost finished
Lenght-85cm
Weight about-2,5kg
Skirt made out of ripstop nylon
Thrust motor-89mm edf unit 1300w outrunner 3800kv brushless
lift is provided by 54mm edf 500w outrunner 4200kv
One steering servo Towerpro with metal gears 12kg max torque.
Headlock gyro gives super stability in steering
All the electronics are powered by 3s lipo 5000mah
This sis just a short overview of the hovercraft, if i have more time i will take some pics. and write more about the building process.
RC Hovercraft Max Force XRT 617 (0 min 33 sec)
hovermaniac is offline Find More Posts by hovermaniac
Old Sep 12, 2012, 08:04 PM
United States, WA, Lake Stevens
Joined Jul 2005
Very, VERY, cool!
jnoetzelmann is offline Find More Posts by jnoetzelmann
Old Sep 21, 2012, 12:01 AM
Click my name for night blades
Timtreo's Avatar
United States, PA, Warminster
Joined Nov 2011
Very cool! I think this will be my next project when I get some time. Have you tried it over water yet? Most of the DIY hovercraft builds I've seen look very DIY, but yours came out awesome looking and fast too. Mind posting any electronics specs you used (motor +prop size, 1 or 2? and esc/s)? Thanks, Tim
EDIT Sorry didn't see your other post with the specs until right now, nice!
Timtreo is offline Find More Posts by Timtreo
Old Sep 21, 2012, 10:00 PM
Joined Jun 2012
Hi
It goes as fast on the water as on the asphalt,sand, concrete or on the mud. I will make new video soon when i get the new aluminium edf impeller http://i.ebayimg.com/t/Metal-90mm-EDF-Ducted-Fan-housing-With-Aluminum-Bracket-Sets-/00/s/MzgwWDQwMA==/$(KGrHqRHJDgE-VPE4YobBPtFe3yKLg~~60_35.JPG
Right now with the old plastic edf impeller, the motor gets so hot it starts melting down the motor mount brackets. So i have to change this and then will see.
Im using 2 esc-s. Lift fan has 40-50A Turnigi SS Series ESC and Thrust fan has 50-65A Turnigy SS Series ESC
Old Sep 25, 2012, 10:27 AM
Joined Jun 2012
Today i recieved a new edf fan housing that looks like this:
http://www.upload.ee/image/2701227/IMG_1205.JPG
Old Oct 03, 2012, 07:05 PM
Timtreo's Avatar
Joined Nov 2011
Nice that looks like it should hold up. Can't wait for the video.I have been digging around the EDF Jets section to start getting into that scene and there are a lot of good deals over there on fans and motors.
Old Oct 11, 2012, 12:24 PM
Joined Jun 2012
I made few upgrades
1. New lift motor 5250kv 64mm edf with dynamically balanced blades.
2. New aluminium thrust edf housing with new 4400kv turnigy motor.
3. Repainted the body and installed yellow flashing lights
(like real hovercrafts have)
Now its got loads of power Im waiting for the first snow to test it out
Little video with the old configuration and old motors on the sand
RC Hovercraft cruising on the sand. (1 min 11 sec)
http://www.upload.ee/image/2739306/P1010017.JPG
http://www.upload.ee/image/2739333/P1010020.JPG
http://www.upload.ee/image/2739338/P1010023.JPG
http://www.upload.ee/image/2739345/P1010012.JPG
http://www.upload.ee/image/2739347/P1010015.JPG
Old Oct 13, 2012, 06:38 PM
Timtreo's Avatar
Joined Nov 2011
Nice! That should be a pretty good test for the hovercraft going over the uneven sand, looks like it does pretty well. Nice job. Ide still like to see a short glide across the water in the backround though . Just kidding I wouldn't want to risk my hard work either.
Old Oct 15, 2012, 12:55 PM
Joined Jun 2012
Heres your short glide
RC Hovercraft (1 min 14 sec)
Old Oct 15, 2012, 03:25 PM
camoesas's Avatar
Portugal/Ovar/Válega
Joined Mar 2007
Hovermaniac, congratulations!
It performs very well and also looks quite maneuvreable.
Regards,
Carlos
camoesas is offline Find More Posts by camoesas
Old Oct 15, 2012, 04:22 PM
Joined Jun 2012
Regards,
Carlos
Thanks Carlos
Yes its fast and it has great maneuverability thanks to head-lock gyro. Im very satisfied with the result this far!
Old Oct 16, 2012, 12:16 PM
Joined Jun 2012
Small video from today
Rc Hovercraft (1 min 44 sec)
Old Oct 25, 2012, 01:59 AM
Timtreo's Avatar
Joined Nov 2011
Hey WOW that does great on the water! I didn't know you were using a gyro, that is a good idea! How do you have the 2 ESCs wired to the receiver? Both to the throttle channel? But then if so how do you keep the air bag filled when you stop moving forward? Do you have one battery powering everything? Ide like to try to build one these or maybe even a hoverwing when I get some time. Yours is pretty awesome. Tim
Old Oct 25, 2012, 04:31 AM
Joined Jun 2012
2 ESCs are in wired in separate channels, so one stick is controlling the air bag and other stick is for the thrust. Im operating with 2 joysticks at the same time. Usually i have one battery to save the weight but i have 2 battery holders built in. i think that on the ice and snow im using 2 batteries 2x5000mah 3s lipo.
Today i but gps on the hovercraft to measure speed and the result was 43,6kmh or 28.96mph
Old Oct 26, 2012, 12:57 AM
Timtreo's Avatar
Joined Nov 2011
Throttle and what the elevator channel for the 2 seperate ESCs?
Discussion What have I done? BIG RC Hovercraft alsetek RC Hovercraft 8 Apr 28, 2013 08:04 AM
Cool Simple Dollar Tree foamboard RC ( skirtless ) hovercraft balsa or carbon RC Hovercraft 24 Dec 30, 2012 06:01 PM
Yippee! FPV RC Tank Battle w/ Unimax Forces of Valor 1/24 tanks w/ 5.8ghz tx and rx KTL13 RC Tanks 5 Nov 03, 2012 05:41 PM
Yippee! FPV RC Tank Battle w/ Unimax Forces of Valor 1/24 tanks w/ 5.8ghz tx and rx KTL13 Video Piloting (FPV/RPV) 3 Aug 23, 2012 10:21 AM
Discussion Max Force Lipo's rotorkilla Racing Boats - Electric 0 Apr 11, 2012 08:42 AM
