Old Sep 11, 2012, 11:03 PM
mashca is offline
Find More Posts by mashca
mashca's Avatar
Joined Apr 2009
Do you know what airplane is this and who made it?
Hi
Do you know what airplne is this? And who made this model? It was built between 60' and 70'. The caracteristics are:
Wing 2.20m
body 1.54m
engine .60 to .90
mashca is offline Find More Posts by mashca
Old Sep 12, 2012, 10:12 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
My first thought was the Top Flight Elder, but upon inspection of your pictures one can see the construction is different and also the dimensions.
Well, at least the Elder can be ruled out.
http://www.top-flite.com/airplanes/topa0215.html
aeronca52 is offline Find More Posts by aeronca52
Old Sep 13, 2012, 03:05 AM
brokenenglish is offline
Find More Posts by brokenenglish
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
It doesn't have to be a kit or even a known plan.
In any case, it's based on a between wars German fighter, Junkers or similar.
I don't know whether it's actually a scale model or not. I'll check.
brokenenglish is offline Find More Posts by brokenenglish
Old Sep 13, 2012, 06:33 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I was at first thinking it was a kit bashed version of a Sterling Fokker D-VII setup as a monoplane. But it may really be a scratch built plane that someone made.
earlwb is offline Find More Posts by earlwb
Old Sep 13, 2012, 08:00 AM
Joined Nov 2011
Earl, the front of a DVII fuselage isn't tapered like that.
Around 1917 to 1920 there were several Austro-German low-wing fighters like this one and, if it really is scale then it's one of those.
It's a shame the ailerons are missing as, on some of the planes concerned, the ailerons were an artistic curly shape that would have been a valuable clue.
Old Sep 13, 2012, 10:31 AM
rchopper56 is offline
Find More Posts by rchopper56
rchopper56's Avatar
Newport News, Va
Joined Sep 2004
Looks like a modified Proctor Antic
rchopper56 is offline Find More Posts by rchopper56
Old Sep 13, 2012, 01:44 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Thanks brokenenghlish, good point, I was thinking someone changed the front somewhat. But yeah it is likely one of those Austo-German low wing fighters. So then it leads me back to it being a scratch build from plans somewhere. Of course a Top Flite Elder flipped upside down so it is a low wing instead of a shoulder wing might be what the builder did.
rchopper, the Proctor kits that I have seen all used built up multi-piece wing ribs. A builder needed to spend a considerable amount of time just making up the wing ribs, before they did anything else. The Proctor kits tended to be works of art, you sort of, hated to have to cover it when done.
Old Sep 13, 2012, 01:48 PM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
That was my first thought so I had a look at the Proctor web site and if it is a modified Antic it has been modified out of sight - low wing instead of shoulder, different tail and fin shape, different fuselage front end etc. The only real similarity is the open girder rear fuselage - but given that the covering has been stripped off the wings maybe this was also covered originally?? So I don't buy it as a modified Antic and I think the theory that it might be a one off is probably close to the mark. Are there any markings on the ribs etc to indicate that it might have been built from a pre-cut kit?
Sundancer is offline Find More Posts by Sundancer
Old Sep 13, 2012, 08:07 PM
williame3590 is offline
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
I would say that someone scratched it out, wing tips are a good sign.
Bill
williame3590 is offline Find More Posts by williame3590
Old Sep 13, 2012, 08:10 PM
Joined Aug 2007
Here's my Antic
Bill
Old Sep 13, 2012, 11:37 PM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Originally Posted by williame3590 View Post
Here's my Antic
Bill
Yes very very nice I remember one Proctor kit I had in the past but never got to build it, these kits were made for BUILDERS, very expensive kits as well. I still do have two Proctor scimitar wood laminated propellors NIP. Friend Emmanuel that I bought the Record Breaker from did build have one of these Proctor Jenny's and magnificent it is. Remember there was also a mini-antic
Reginald is offline Find More Posts by Reginald
Old Sep 13, 2012, 11:43 PM
mashca is offline
mashca's Avatar
Joined Apr 2009
Many thanks for answering, the wood does not bring any brand, the previous owner died and his son sold me this aircraft as well as is and just told me that her father had for
over 40 years and do not know the name of the aircraft Espro help me greetings from mexico
Discussion Do you know what airplane is this and who made it? mashca The Builders Workshop 5 Sep 11, 2012 07:05 PM
Question How do you know what part is bad? j2591 Micro Helis 5 Aug 13, 2012 07:39 PM
Discussion Do you know what this is? jaizon Thermal 3 Jul 22, 2012 02:09 PM
Question Do you know this FPV radio???? hayataro Radios 1 Mar 23, 2012 08:18 AM
Wanted do you know what plane this is ? streetbikegod4 Aircraft - Electric - Airplanes (FS/W) 5 Mar 18, 2012 08:41 AM
