Old Sep 11, 2012, 09:31 PM
marco_ul is offline
Find More Posts by marco_ul
marco_ul's Avatar
Canada, QC, Montreal
Joined Jun 2006
FashCut CNC 2000
Hello,
I was lucky enough to get a hand on a Flashcut CNC 2000. The tricky part is the the machine is incomplete. What I have is the frame with the steppers equiped with optical encoder (E2 from US Digital). There are also limit switches installed on the 3 axes. All the electronics is missing (power supply, breakout board, stepper driver). There's no spindle and the lead screw of the z-axis is missing. I don't plan to use the optical encoder for now because I'd like to keep the cost low.
Right now i'm trying to evaluate if it's worth to put this thing back to a fully functional state? What do you experts think? How much should I expect to invest ?
Thanks for you help
Marco
marco_ul is offline Find More Posts by marco_ul
Old Sep 11, 2012, 11:26 PM
Ward Hagaman is online now
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Sorry, I can't be of any help except to say that I have the utmost in confidence in Flashcut CNC as a company. I retrofit a knee mill 10 years ago with a Flashcut system and it has never let me down.
Ward Hagaman is online now Find More Posts by Ward Hagaman
Old Sep 12, 2012, 04:17 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Looks like a Sherline based machine. Are you sure those are steepers, they did have a servo motor option. Servo motors have encoders. Some steeper systems also use encoders, but not as common. A package quality deal with a controller, cables, and steppers should be around $550. You can get the costs down from there, depending on brands. Any pictures?
Roto Rob is offline Find More Posts by Roto Rob
Old Sep 13, 2012, 08:18 AM
marco_ul is offline
marco_ul's Avatar
Joined Jun 2006
I believe that what it is. I'm not quite sure what it means, yet. I will do my homworks, I promise.
I'm not 100% sure, but I think that's what they are based on their apparence, plus theyr have 6 wires. I'll post pictures and you can confirm.
That would be just about what I was planing to invest. More on that in a future post. I already have all the cables and the steppers, if that what tey really are...
Any pictures?
I'll post pictures tonight.
Thanks for you input, that was very helpful!
Marco
Old Sep 13, 2012, 10:48 PM
marco_ul is offline
marco_ul's Avatar
Joined Jun 2006
Ok, so I did a little research and I came up with alot of answers.
1- It is a Sherline-based machine.
2- The motors are steppers.
I supplied a few pictures of the machine.
Is there good electronics and spindle options out there for this machine? Sherline sells a plug-and-play controller 600$ (P/N 8760) and spindle assembly for 500$ (P/N 6517).
Marco
Old Sep 14, 2012, 05:02 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
I don't think you would want that spindle, it has the dove tail base. You want the one to attach to your mills plate. I think it is the one above it on that web site. Your mount plate is missing the center pin. I might have one, in the shop I'll look around. This is the Sherline based mill I had, might give you some ideas. http://www.rcgroups.com/forums/showthread.php?t=1378684
I don't know of any cheap controllers to do the steppers with the encoders. The steppers do look like the Sherline steppers.
Old Sep 14, 2012, 12:45 PM
marco_ul is offline
marco_ul's Avatar
Joined Jun 2006
Thanks again Rob for the info. Nice thread. It did give me some ideas. I don't plan using the encoders in a closd-loop system. I'll start with open-loop first. I'm still at the very begining of the learning curve.
Marco
Mini-HowTo Turn any DVM with a 2000ľA range into a universal DIY 2000 Amp DC Ammeter. xandrios Power Systems 0 Jul 23, 2012 12:31 PM
Discussion 1/3.5 wilga 2000 Discusdan1 Scale Sailplanes 3 Feb 24, 2012 04:40 PM
For Sale Raptor 90 Custom CNC Fan, CNC Engine Mount and CNC tail case timmaay Aircraft - Fuel - Helis (FS/W) 0 May 27, 2011 12:21 PM
