Old Sep 11, 2012, 05:55 PM
fooferdoggie is offline
Find More Posts by fooferdoggie
United States, OR, Happy Valley
Joined Aug 2012
If I could get a good list of all of the parts I need it would really help.
I want to start building simple planes to practice on. the night vapor can't handle much of any breeze and I don't have the space for much larger. I understand airplanes and built a fair amount. now it is so much easier using foam. but there are so many parts i need I am a bit lost. I want to build a plane around 12 to 15" winspan and a slow flyer. pusher would be better to save wear and tear. I would like 4 channels too. I have a dx6i radio. So If I could get an idea on what receiver and servo's and motor and props to get it would help a lot. I know I could get replacement parts from parkzone and do it but they seem bit spendy.
fooferdoggie is offline Find More Posts by fooferdoggie
Old Sep 11, 2012, 06:57 PM
mcnowhere is online now
Find More Posts by mcnowhere
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
Have you looked thru scratchbuild forum yet? They usually post all the equipment needed along with the plans.
mcnowhere is online now Find More Posts by mcnowhere
Old Sep 11, 2012, 07:46 PM
Joined Aug 2012
yes though I need to read more. like can I only use a Spektrum reciver or can it be a dsm2 like this one http://www.fancyfoam.com/index.php?m...products_id=71 are the servos universal of the plugs are the same?
Old Sep 11, 2012, 08:20 PM
Look out below
mcnowhere's Avatar
Joined Aug 2011
Yep plugs are the same for servos. You need to stay with same brand for your Tx (transmitter) that Rx is pretty big for a small foamie but will work. Try this one and they sell other sizes too.
Old Sep 11, 2012, 08:22 PM
Look out below
mcnowhere's Avatar
Joined Aug 2011
Do you know how to use thread tools and search this thread function?
Old Sep 13, 2012, 01:06 PM
Thirston is offline
Find More Posts by Thirston
United States, NC, Charlotte
Joined Jul 2012
TX
RX
Motor and motor mount (either home made or pre fabricated)
ESC
Prop w/prop saver
Battery and charger and extra XT60, JST or Deans connectors
Bullet Connectors / Shrink Tube
Solder / Soldering Iron / Flux
Hinge Tape / An old 3.5" Disk / Hot Glue Hinges / Plastic Hinges from HK
2,3 or 4 Servos with appropriate connectors. Possibly "Y" harness
Control Rods / control horns and some way to guide them (straws) and way to make "Z" bend
Foam / Hobby Knife / Low Temp Hot Glue / Gorilla Glue / Grilling Skewers and or Carbon rod
Printable directions from the Scratch built part of the site.
Thirston is offline Find More Posts by Thirston
Old Sep 13, 2012, 01:58 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
For the size of plane you are thinking about use the same electronics the Vapor uses.
But unless you go up in size and weight you still won't be able to fly in much wind.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Sep 13, 2012, 03:59 PM
Logan4169 is online now
Find More Posts by Logan4169
Joined Nov 2011
http://www.hobbyking.com/hobbyking/s..._Receiver.html
Logan4169 is online now Find More Posts by Logan4169
Old Sep 14, 2012, 01:24 AM
Joined Aug 2012
A little wind is all I am after. What size motor can I get away with with my vapor radio gear?
Old Sep 14, 2012, 01:26 AM
Joined Aug 2012
Yes way too much info to sort through. Been driving me nuts.
Old Sep 16, 2012, 10:42 PM
Thirston is offline
Joined Jul 2012
I think the J3 Cub motor might work for you. Pair it with the rx/esc combo from your Vapor.
You could also try using a 5g brushless with a small ESC and some linear or <2g servos. Perhaps see what electronics are being used on the Pico Sticks and such.
And I think I've read good things about the 5043 props being used on these small brushed foamies.
Old Sep 18, 2012, 12:29 AM
Joined Aug 2012
I made a pusher plane from 1/8" foam and used the p51 motor and gear box. but I could not get forward thrust even with the motor tipped way up. though later I saw how to fix it. but I thin kit would need so much up thrust It may not work. Almost think the servos don't have enough throw to work well but it is limited to where you can place the radio unless you replace the push rods and such. frustrated with planes right now. more spent with far less flying then with any of my heli's I can crash them a lot without any or much damage.
Discussion If you could choose anywhere in the world to live, where would it be and why? KiwiNATOR Life, The Universe, and Politics 41 Jun 30, 2012 10:27 PM
Discussion Would you buy LX models if you could get them on the East Coast wswayze USA - District IV 2 Jan 26, 2012 12:29 PM
Alert Would you buy LX models if you could get them on the East Coast? wswayze Electric Ducted Fan Jet Talk 11 Jan 18, 2012 03:41 PM
Discussion If anyone gets bored, could you please take a look at my parts list? SplitFire Multirotor Talk 4 Dec 05, 2011 02:21 PM
Discussion Do you record your li-po's life? We could all benefit if everyone would?? turnbui Micro Helis 14 Oct 20, 2008 07:00 PM
