Old Nov 04, 2012, 04:06 PM
DontTMACajun is offline
Find More Posts by DontTMACajun
DontTMACajun's Avatar
United States, LA, Gray
Joined Jul 2011
Originally Posted by Hover or die View Post
Ive been told its a puller prop but it is the stock prop for a stryker and mounted at the back of the plane...mounted 2/3s back on the profile 22s...
Theyconly cost 2 or 3 bucks so certainly worth getting a few to experiment with........
Good enough for me, I'll order one up and give it a try. Thanks!
Is your BL15 the 3200kv or 3600kv version, and how many cells are you using? What size ESC?
DontTMACajun is offline Find More Posts by DontTMACajun
Old Nov 06, 2012, 02:11 PM
MikePS is offline
Find More Posts by MikePS
AMA 983978
United States, FL, Jacksonville
Joined Sep 2011
Just wanted to share my expereince with this motor. Running in a Habu 2, Castle Creations Ice 100 mounted in intake (12deg pwm, med timing), WeMo midi fan, Glacier 30C 3300mAh 6S battery. 1st 3 flights performance was OK, 4th flight motor stuttered badly. I cut throttle, dead sticked in, motor smelled burned, visually inspection showed blacked windings - primarily at fan end of motor. I originally purchased the Velocity/edf hobbies 2950kv motor because it was a few $$ cheaper then what seemed like similar motors. I got great service from edf hobbies and wouldn't hesitate to buy from him again, but I'm replacing this with a Velocity High Performance Motor V28-60-2900 from Gary at EffluxRC.
MikePS is offline Find More Posts by MikePS
Old Nov 11, 2012, 05:17 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Fort Langley
Joined Jul 2011
I also just wanted to share my experience with this motor...
My 2950kv edf spark show (2 min 34 sec)
The sad part is that this is the third replacement motor/fan combo to do this and I have actually been paying the extra money to have this mounted and balanced so that I can have a trouble free experience.
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Nov 11, 2012, 06:44 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Is that from EDF Hobbies or Efflux RC? I'm beginning to think that they're not the same motor. What fan & cell count is that?
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Nov 11, 2012, 07:07 PM
WhalleyB0Y's Avatar
Joined Jul 2011
2950kv motor, WeMo mini pro, on 5s all mounted and balanced from edfhobbies for the tune of roughly $160.
http://edfhobbies.com/index.php?rout...product_id=176
I'm not sure what to do at this point.
Old Nov 11, 2012, 09:08 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
The real McCoy's shouldn't do that. If you're looking for a replacement, get it from Gary at Efllux RC who carries genuine Velocity-RC motors. The EDF Hobbies ones are listed as 29mm, the velocity ones are 28mm.
Site Sponsor
Old Nov 11, 2012, 09:16 PM
WhalleyB0Y's Avatar
Joined Jul 2011
Sorry, I am confused by that statement. The title of this thread, the motor in discussion, and edfhobbies... are you suggesting that I have bought imitations?
Old Nov 11, 2012, 09:18 PM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
See post #30. "The Velocity-RC motor is 2900 kv. If the motor does not have a RED, Velocity-RC sticker on it, it's not a Velocty motor."
172AMD is offline Find More Posts by 172AMD
Old Nov 11, 2012, 09:37 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
It's essentially a thread about a counterfeit motor, yes.
Site Sponsor
Old Nov 11, 2012, 11:06 PM
WhalleyB0Y's Avatar
Joined Jul 2011
oh... this feels like I just got kicked in the nuts
Old Nov 12, 2012, 05:53 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
http://www.youtube.com/watch?v=Pbz-ekx_UIo
How many run ups before the sparks?
> 3000 watts through the EDF Hobbies 2950kv motor, not the slightest indication of burnt windings...
CS 10 blade rotor, EDFHobbies 2950kv motor, 6s, 3000watts 7lbs of thrust (2 min 17 sec)
erh7771 is online now Find More Posts by erh7771
Old Nov 12, 2012, 05:57 AM
Joined Nov 2005
Here's the same motor at 80 amps with a wemo rotor
Wemo\6s\80amps\4400mah\5.5lbs of thrust (0 min 43 sec)
Old Nov 12, 2012, 09:28 AM
WhalleyB0Y's Avatar
Joined Jul 2011
This is the first time in this thread that is has been said that these motors are counterfeit. I do realize that Gary had made mention of the difference by way of the label but that happened after I had already been mislead by the competitor's website product description. Add to that the confusion caused by many people telling me that what I have are the good motors when really everyone has been bamboozled.
What it seems like is I have walked in on a joke where I am the last to understand the punchline. And I have based an entire build around an ill advised motor recommendation.
I should have dealt with efflux RC from the beginning and maybe this wouldn't have happened. But at the time I didn't know the difference and by looking at two foreign websites who is to say which one is counterfeit?
All the times I had posted my problems and not taking heed to the right advice, I apologize to everyone for that.
Old Nov 12, 2012, 11:09 AM
Joined Nov 2005
I've used and abused these motors for a while, I've had none of this experience with them.
They've eaten 2000 watts all day with CS rotors, Wemos etc...
I think HorD is still running his at 6lbs of thrust with the eflight rotor
Old Nov 13, 2012, 09:14 PM
WhalleyB0Y's Avatar
Joined Jul 2011
You ever had an issue where the motor leads get pulled upon from the fan thrust? Talking to edfhobbies today and he was inquiring about the way the esc is attached and how it might be pulling on the motor leads. Is there any particular way to mount an esc behind the motor so as to not cause damage?
Description:
Does your motor look like this?
Description:
Description:
And where did you buy it from? (I am just trying to determine exactly what is that I have)
Build Log F-4J PHANTOM II "USS AMERICA" PLANET-HOBBY 70mm EDF GFK Balsa timmybeetle Electric Ducted Fan Jet Talk 3 Mar 28, 2014 06:01 AM
Sold 64mm edf w/motor 2-70mm edf's, 70mm edf motor Dave Barrow Aircraft - Electric - Jets (FS/W) 0 Aug 10, 2012 07:58 PM
For Sale $60 shipped Velocity 4200kv brushless inrunner for 70mm edf PRICE REDUCED $50shipped. SmokingFlite Aircraft - Electric - Jets (FS/W) 2 Jun 24, 2012 01:21 AM
Discussion Hobby King Twin 70mm EDF Mig 29 andrew_1967 Electric Ducted Fan Jet Talk 2 Mar 05, 2012 11:25 AM
Discussion EDFHobies 70mm 2950kv 4.0mm 2000KW mikes68charger Electric Ducted Fan Jet Talk 17 Mar 06, 2011 05:55 PM
