Old Oct 06, 2012, 09:44 AM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Originally Posted by WhalleyB0Y View Post
How about the 2950kv motor paired with CS10 fan, 110A ZTW esc running on 5s? Some people have even said this motor would be good on 5s and others are happy running it on 4s. Anyone have comments on this?
It might work well on 4S or 5S on the CS fan, there is a good thread here which will give you an idea of the kv / cell count combinations.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Oct 06, 2012, 01:28 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
This motor is 250% heavier as the mega 16/15/3 which performs fine at 4s. I wouldn't be suprised if 6s or more would work. if you run at 4s you will have a major weight penalty in your drive system!
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Oct 06, 2012, 01:39 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
It's for a 6s setup in a 3-6 bladed fan. The added weight is a benefit in it's mass and ability to shed heat.
Yes, your an "energy star" EDF'r eric, but some folks want 1900+w. (with 5-6+ lbs thrust)
The 61.5 mm long MEGAs and the HET 1W-40's are being used there as well.
Long can, low kv motors are being used by the CS guys. so the rotor doesn't burn up the motor. at lower power levels (<1300w)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Oct 06, 2012, 02:31 PM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
why do you think we offer different motors?
2900/ 2950 kv are for 6 S
3200 kv are for 5 S
and the lower S the more amps for the same thrust, and the less efficiency due to heat loss.
Claus
clausxpf is offline Find More Posts by clausxpf
Old Oct 10, 2012, 07:19 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
I put my 2950kv in my H2 with a Changesun 10 blade 70mm and here is some numbers I got with the 4s and 5s packs I had.
5s 3300mAh 30C
15.59vm
106.9ap
1787wp
3min fly time
4s 3500mAh 35C
13.11vm
82.96ap
1130wp
2.52 min duration
Auw of the Habu with various pack sizes
5s 2200 1.6kg / 3lb9oz
5s 3300 1.8kg / 3lb13oz
* 22grams needed to balance
4s 3500 1.63kg / 3lb9oz
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Oct 11, 2012, 06:58 AM
MikePS is online now
Find More Posts by MikePS
AMA 983978
United States, FL, Jacksonville
Joined Sep 2011
Got my 2950kv installed in my H2 last night, WeMoTec Minifan Pro, 6s 3300 40C. At WOT:
85.1a
1850 watts
MikePS is online now Find More Posts by MikePS
Old Oct 12, 2012, 06:45 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
85.1a
1850 watts
I got a little over 5.5lbs of thrust with this setup, this will take 65c packs all day and not break a sweat
erh7771 is online now Find More Posts by erh7771
Old Oct 12, 2012, 08:11 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Here's a little fat to chew on guys! V 4200, 5s 4200 65c, Ice100, 7.5lb thrust, lander shroud/wemo pro 70mm impeller
ApexAero is offline Find More Posts by ApexAero
Old Oct 12, 2012, 01:51 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
199A! Wow! Were you able to check the motor temp after the fact? Was the Cool 42 in fact still cool?
Site Sponsor
Old Oct 12, 2012, 03:16 PM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
That isn't the half of it! Did you see the watts? I never have trusted CC's data recording to be all that accurate. The motor lasted in the setup untill I put it in a eflite f-86, maiden takeoff and 1/4 lap then poof! Went around the field one and a half laps to slow down to land though! Thats with the stock gear hanging!
Old Oct 12, 2012, 03:24 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Agreed. I'm gonna guess +/-20%, and Castle doesn't even guarantee that it's supposed to be accurate anyways. I find that they generally over-read.
That being said, even if you're 25% over, that's still over 150A!
Site Sponsor
Old Oct 12, 2012, 03:26 PM
AMA 983978
Joined Sep 2011
interesting to be sure! my readings were with the eflight power meter in line..
Old Oct 13, 2012, 12:25 PM
Joined Nov 2005
~7lbs of thrust at 140 amps with 2950kv motor from EDFHobbies
CS 10 blade rotor, EDFHobbies 2950kv motor, 6s, 3000watts 7lbs of thrust (2 min 17 sec)
Motor wasn't properly heat sunk to shroud or can sink...
With proper heat sink magnets will like watts way more
Old Oct 13, 2012, 11:05 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
What jet you putting this in? 777
capt soap is offline Find More Posts by capt soap
Old Oct 13, 2012, 11:06 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
Now try it on 5s, maybe a 65c pack ?
Build Log F-4J PHANTOM II "USS AMERICA" PLANET-HOBBY 70mm EDF GFK Balsa timmybeetle Electric Ducted Fan Jet Talk 3 Mar 28, 2014 06:01 AM
Sold 64mm edf w/motor 2-70mm edf's, 70mm edf motor Dave Barrow Aircraft - Electric - Jets (FS/W) 0 Aug 10, 2012 07:58 PM
For Sale $60 shipped Velocity 4200kv brushless inrunner for 70mm edf PRICE REDUCED $50shipped. SmokingFlite Aircraft - Electric - Jets (FS/W) 2 Jun 24, 2012 01:21 AM
Discussion Hobby King Twin 70mm EDF Mig 29 andrew_1967 Electric Ducted Fan Jet Talk 2 Mar 05, 2012 11:25 AM
Discussion EDFHobies 70mm 2950kv 4.0mm 2000KW mikes68charger Electric Ducted Fan Jet Talk 17 Mar 06, 2011 05:55 PM
