Old Sep 11, 2012, 05:54 PM
tofast4u is offline
Find More Posts by tofast4u
speeddemon
United States, TX, Whitesboro
Joined Jun 2011
Velocity/edf hobbies 2950kv 4.0mm 70mm
Would this motor with 6 blade fan do fine with 4 and 5 cells even though its recommended for 6 cells? or should i get EDFhobbies 4200kv motor thats designed for 4/5 cells
tofast4u is offline Find More Posts by tofast4u
Old Sep 12, 2012, 04:23 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
You should be of fine, and to the safe side.
Claus
Velocity - RC
clausxpf is offline Find More Posts by clausxpf
Old Sep 12, 2012, 08:35 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
I've tested it with 5lbs 12oz on 65c\3300\6s around 1800 watts!! with a pitch similar to wemo\sapac rotors....
Really a good motor...
If you have the 6 blade rotor be careful of FOD....it'll wear the blades down quick
erh7771 is offline Find More Posts by erh7771
Old Sep 12, 2012, 09:25 AM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
What's "FOD"?
djacob7 is offline Find More Posts by djacob7
Old Sep 12, 2012, 09:29 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Foreign Object Damage
Old Sep 12, 2012, 08:45 PM
tofast4u is offline
speeddemon
Joined Jun 2011
Ok! good to know, now we are talking about the 2950kv right? just makin sure before i place my order in? also running with hobbywing 100amp ESC with 120amp burst, from the calculations it should handle the watts and power that motor draws
Old Sep 12, 2012, 11:47 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
triple 777, how many motor's do you have ????
capt soap is offline Find More Posts by capt soap
Old Sep 14, 2012, 12:53 PM
erh7771 is offline
Joined Nov 2005
Too many, need more planes to put them in
Old Sep 17, 2012, 01:48 PM
latinajet is offline
Find More Posts by latinajet
latinajet's Avatar
Joined Feb 2011
What about a 5s 64mm on 3950kv with a cyclone power metal shroud and a wemo mini cut to 64mm? Do yo think you can test that edfhobbies setup?
latinajet is offline Find More Posts by latinajet
Old Sep 17, 2012, 09:41 PM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Incredible motor..Solid 6 lbs thrust..eflite 69 mm fan..Just awesome power output and i actually like it better than the HET 1 w40 motor..
Did have one mess up on me though..
Should be no issues getting it fixed as its not burned up....
Hover or die is offline Find More Posts by Hover or die
Old Sep 18, 2012, 10:07 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
How much power can it take in the wm300 and how many cells?
br,
Erik
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Sep 19, 2012, 10:42 AM
MikePS is offline
Find More Posts by MikePS
AMA 983978
United States, FL, Jacksonville
Joined Sep 2011
I just purchaed this motor, my first real step up from the stock eflite habu motor. I'm going to be using an CC Ice lite 100amp ESC, 6S Hyperion 2600mah 35C or 6S Align 3300mah 40C batts and the 5 blade fan/housing from an older 3575KV RC Lander unit. All that said, should I be at all concerned about the gauge of the wires attached to the motor? They appear to be 12ga at best, whereas the leads from the ESC are 10ga. I'm putting 5mm bullets on the ESC and was planing to make a 5mm to 3.5mm adaptor to connect to the leads that run thru the Habu fuse.
MikePS is offline Find More Posts by MikePS
Old Sep 19, 2012, 04:20 PM
Joined Mar 2011
Should not be an issue..the motor wires are pretty small as well...12 or 14 gauge but very stiff stuff...
Old Sep 20, 2012, 07:10 AM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
My suggestion is replace the old lander blade with a wemo 70mm blade and an adapter from gary @ efflux rc. The lander blade/adapter are only good for low power systems dude!
ApexAero is online now Find More Posts by ApexAero
Old Sep 20, 2012, 08:58 AM
MikePS is offline
AMA 983978
Joined Sep 2011
Thanks guys. Any feelings about the HET 6904 unit vs the WeMoTec mini?
Build Log F-4J PHANTOM II "USS AMERICA" PLANET-HOBBY 70mm EDF GFK Balsa timmybeetle Electric Ducted Fan Jet Talk 3 Mar 28, 2014 06:01 AM
Sold 64mm edf w/motor 2-70mm edf's, 70mm edf motor Dave Barrow Aircraft - Electric - Jets (FS/W) 0 Aug 10, 2012 07:58 PM
For Sale $60 shipped Velocity 4200kv brushless inrunner for 70mm edf PRICE REDUCED $50shipped. SmokingFlite Aircraft - Electric - Jets (FS/W) 2 Jun 24, 2012 01:21 AM
Discussion Hobby King Twin 70mm EDF Mig 29 andrew_1967 Electric Ducted Fan Jet Talk 2 Mar 05, 2012 11:25 AM
Discussion EDFHobies 70mm 2950kv 4.0mm 2000KW mikes68charger Electric Ducted Fan Jet Talk 17 Mar 06, 2011 05:55 PM
