Old Oct 22, 2012, 04:07 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi J,
Do set the Tx trim settings to 1/20 for Elevator and Aileron. That allows for finer trim tuning for multicopters which when properly setup, undamaged and mechanically balanced should not require more than 5 clicks of trim. I set that 1-step trim setting in all the various computer Tx's that I use to fly my multicopters. Most do use 4 as the default which is generally too high for fine tuning multicopter flight controllers.
Like most multicopter flight controllers, the Ladybird sets the gyro trim using the accelerometers for level on initial boot or power-on. You should have the subtrims and initially trims set to zero. During flight, any more than 5 clicks and something else is not correct such as the lipo not in CG, a bent prop or damaged props causing a poor balance and vibrations, a weak or damaged motor or improper mechanical dynamic trim, i.e. motor tilt is not correct due to bent or twisted arms or mounts. In these conditions if it takes more than 5 clicks of trim when the Trim setting are set to 1/20, then it is time to find and fix one of the previously mentioned issues.
Hope that helps!
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Originally Posted by jfdpl686 View Post
Isn't it something? I've been researching about the trims. When you set it to 0/20 then the mechanical trim don't work. My theory is that the value given is the number of steps each time you move the trim, so if you move it once to the right, then your trim is 4, twice is 8 while if you set 1/20, then your trim advance one at a time. Like the Tunirgy 9x.
I will research more.
I used the subtrim in my LB and now I get it to hover almost perfect, but if it's not advisable, I will remove it.
I'm new at this and now following all your gides, I have the V911, LB and my challenge is the mini cp which I just finish setting and have to try.
I really appreciate all your post helping people learning like myself.
A big thank you to you!
jesolins is offline Find More Posts by jesolins
Old Oct 26, 2012, 12:21 AM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Hi Jim,
Thanks for the tip on the Tx trim settings to 1/20 for Elevator and Aileron.
I just set my Devo 10 models for the Hoten X and Ladybird to 1/20 for Elevator and Aileron.
Tom
Tom Z is offline Find More Posts by Tom Z
Old Nov 11, 2012, 07:23 PM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
My Hoten was shipped monday and arrived Wen. I flew it first time Thru. and knew it would be fun. I sure was not let down, it flys great. I have been flying Ladybird's and Y-6 and this is a monster in size compared to them. I was concerned about brushless motors but Hoten is an old friend now. Flys just like V1 L/Bird. I have two V929's so size wasn't an issue but you need to respect those four blades powered by much more powerful motors. Its a Winner for sure !! Walkrea is putting out some nice stuff.
dankar04 is online now Find More Posts by dankar04
Old Nov 12, 2012, 04:01 AM
kosem is offline
Find More Posts by kosem
Former IAF pilot. Retired
kosem's Avatar
France, IdF, Paris
Joined Apr 2012
Yes, it's a fantastic aircraft!
I wish Walkera will release a transportation case and a much better embedded camera.
kosem is offline Find More Posts by kosem
Old Nov 12, 2012, 09:14 AM
Tucson, Az
Joined Feb 2007
I first recieved Scorpion Y-6 w Devo 7. I could not get over how nice it flys then bought Ladybird V1 from X-heli [$58.00] I again was amazed at its flying and smooth it flew. I looked at Hoten but seemed it was out of stock then ran across Wow hobbies had it on special W battery. I bought it and once more this big Quad flys wonderful. Downside is once you flys these clones just don't cut it. I'll use tthe clones to gain more daring experience. The clones even with T9X are not even close to these Walkrea birds. Walkrea Rocks !!
Old Nov 07, 2014, 08:56 AM
Tucson, Az
Joined Feb 2007
Well a couple years later and Hoten-X bl stilla rockin and rollin !! Been a great Quad no issues at all. Some day like to get a 3 cell quad about 350/ 400 size.
Something with 6ch and options. I care little about cameras FPV.
Old Nov 07, 2014, 08:23 PM
Rogersresort is offline
Find More Posts by Rogersresort
Joined Sep 2007
I Agree with you dankar ,very dependable quad ,I converted mine to FPV with a 808 #16 D and enjoy it very much.
Rogersresort is offline Find More Posts by Rogersresort
Old Nov 11, 2014, 01:08 AM
Tucson, Az
Joined Feb 2007
I wanted a nice bl Quad and got waht i wanted. Couple years later bird flys as good as day one. Ladybird V1's still fly great, even Scorpion Y-6. I became a Walkera fan first flight of L/B V1. Well over two years on them.
Old Dec 11, 2014, 11:45 AM
Tucson, Az
Joined Feb 2007
I had new battery for V200D01 1250 ma 25 C w/ jst connector. Made adapter to work with Hoten-X. Six minutes into flight losing power. Same thing with Value hobby battery. I had a new WK battery for this Quad. charged it up and presto full flights no issue. Its only rated 1000ma . Anyway good to go and flys good as ever. I'm sure ohms from adapter had a factor. Hey all I care is bird flys.
Walkera is pretty slick with odd ball batteries and battery trays. Plus ga. wire they use. Most two cell cheapies have thin ga connetor wires. upshot is I find stock Walkera batteries out last many replacements. My V200D01 FBL BL F/P flew for two years with original battery. Not flown everyday but no dust Queen either.
I wanted a bl quad just to fly and Hoten-X bl Rocks on for me. Ladybirds V1/ Scorpion Y-6 still fly fine after many/ many hours of airtime.
Discussion Walkera HOTEN X Ariete Multirotor Talk 2 Jan 08, 2015 10:23 AM
Mini-Review Walkera HOTEN-X Quadrotor Mini-Review thwaitm Multirotor Talk 48 Jan 08, 2015 10:20 AM
Mini-Review Walkera Hoten-X Review jameschen072 Mini Multirotors 1080 Aug 15, 2014 10:28 PM
