Walkera Hoten X Review - Devo 10 Transmitter - UP02 Upgrade Tool/UP-02 Adapter
Walkera HM Hoten X Quadcopter - 200 size brushless quad - 4 Channel ![]() ![]() First Impression: WOW! This is huge! I can't wait to fly it. First Flight: I charged up the battery and took it outside for my first flight. I was expecting it to be very loud but it wasn't. It has a low pitch sound to it. I lifted off and hovered it around for a bit to see how it handles and how stable it is. It is very stable! Even more stable than my Ladybird QR. This is my second quad. I was able to fly it pretty easy the first battery pack. Just need to get use to the big size and power of it. Telemetry: I have found out that using the telemetry eats up the battery time. I went from 5 full minutes of flight time on my Master CP with telemetry inhibited in the TX to 1:25 minutes flight time with the telemetry enabled. I found the same thing with my Mini CP, 1:25 minutes flight time with the telemetry enabled and 3 minutes flight time with the telemetry inhibited. My friends Mini CP had the same results as I did with telemetry inhibited and enabled. Devo 10 I set the Sensor Setting - Voltage - External: V1- Alarm Voltage to 3.5V. This give me 3.72V per cell no load which is pretty good. Overview: The Quad feels like it is built well. The landing gear is wide and sturdy. It has 4 rubber tips on the ends of the landing gear. Motor booms feel strong and the motors feel like they are mounted securely. Canopy feels strong. Battery tray holds the battery in very well. It has 4 bright LED lights. Two in the front and two in the back. The front two are white and the back two are Red in 6 axis mode and Blue in 3 axis mode. The lights help you see the quad from a distance and help you with the orientation. Also the lights look good at night. The two orange props are big and bright. You can see them from a good distance away which helps you with orientation. Battery life is good. About 10 minutes which is very good for something this big using 4 BL motors. It has a telemetry feature so you can monitor your Quads battery voltage but you must upgrade the firmware to use this feature. The first thing I was concerned about with a Quad this big was safety. Being cut with such a big prop powered by a BL motor. I posted a question about this. The answers were good to know. See post # 419 and below. http://www.rcgroups.com/forums/showt...693774&page=28 http://www.rcgroups.com/forums/showt...693774&page=29 http://www.rcgroups.com/forums/showp...&postcount=448 Pros:
Cons:
![]() Flight Time: - Stock Battery
Transmitter Setup Guides: http://www.rcgroups.com/forums/showthread.php?t=1325037 What is in the box: ARF Package
Weight: Quad: 268.5 grams. Quad with battery: 332.3 grams Battery: 63.8 grams Specifications: 1). Main Rotor Diameter:186mm 2). Transmitter(standard): DEVO 7 3). Gyro:6 Axis Gyro 4). Overall Lenghth:266mm 5). Transmitter(Option): DEVO 10/8S/7E 6). Brushless Motor:WK-WS-26-004 7). Fuselage width:266mm 8). Receiver:RX2635H-D 9). Battery:7.4V 1000mAh Li-Po 10).ESC:WK-WST-16A4 1). Product type: Quad-copter in 200 size 2). Recommend Environment: Outdoor 3). Experience Level: Intermediate 4). Latest 6-Axis Gyro Control system provides super stable flight 5). Brushless motor system ensures more powerful and fantastic flips and rolls flight 6). The RX firmware can Update Online (required UP02 upgrade cable and adapter ) 7). Telemetry Function(require to update the firmware and a telemetry function radio is a must) 8). The simple and compact modularized design, easy to install and maintain Final thoughts: Walkera did a good job with this Quad. It looks and feels like it is made well. Flight time is very good. Power seems good for a Quad of this size and weight. This will be great with a camera on it. I am looking into getting one for this and will add information and videos to this review. Hobbyone sent me the Hoten-X, Devo 10 TX, and UP02 + UP02 Adapter Package to review at my request. Thanks Lena for sending me the samples to review! http://www.hobbyone.com.hk/cn/produc...d=11179&cid=43 http://www.hobbyone.com.hk/cn/product.jsp?id=11083 http://www.hobbyone.com.hk/cn/product.jsp?id=11125
* My Blog has links to all my reviews. Also it has information, and pictures of all my Helicopters and Quads* http://www.rcgroups.com/forums/member.php?u=170718 -
Walkera Devo 10 Review
The Devo 10 is really nice. It feels good in my hands and the joysticks feel smooth.
I am using a 3S Lipo in mine so it is lighter which is great as it takes 8 AA batteries which make it heavy. The LCD screen resolution is high and it contains graphs like the WK2801-PRO. LCD screen can be viewed in daylight. It has Telemetry features which include voltage, temperature, rpm and GPS. Firmware can be upgraded with an adapter and firmware on Walker's web site. You can load model settings for different modles from Walkera. You can also export model settings. It has a vibration alarm which is a great feature. The menus are easy to work your way through. I was programming it as fast as my WK2801-PRO. There are a lot of features in this transmitter and at a great price. I will add more information and videos soon. Tom
Walkera UP02 Upgrade Tool and the Walkera UP-02 adapter
The UP02 Upgrade Tool/UP-02 adapter worked well for me.
I updated the firmware on the transmitter for my Devo 7 and Devo 10, Imported/Exported models for each of the transmitters, and updated the receiver firmware for my Hoten X, Ladybird, and Mini CP. See my post for How to update firmware on the Devo TX/RX and How to Save/Load Models. http://www.rcgroups.com/forums/showp...1&postcount=31 Tom |
For a 3 or 6 axis gyro you are not suppose to use any subtrim or trim from what I have read.
Some people do though and it seems to be OK. I don't know how the trim system works, good question. They show it in the PDF owners manual on page 19 but don't explain in detail how it works. See picture in thumbnail. Tom |
Latest blog entry: My RC Web Site
Your welcome. It is, I have been searching around also and can't find anything. If I find something I will let you know. Your theory sounds like that is what the trim system does. If your LB is working well with subtrim I would use it. The general rule for a 3 or 6 axis gyro is not to use any subtrim or trim but I see many people using it without any issues. I have tried it also and it worked fine. Tom |
I just found this. It explains what trim system does. Also see my post #9 above. Tom |
which one is which. When I was flying I was thinking how can I tell the countdown timer alarm from the sensor voltage alarm. I have both of them on. You have the sensor view on so you can't see the main screen to see the timer. Tom |
Flight Times
Added flight times to the review.
Tom |
| Thread Tools | |
| Mini-Review Walkera Hoten-X Review | jameschen072 | Mini Multirotors | 784 | May 21, 2013 10:36 AM |
| Mini-Review Walkera HOTEN-X Quadrotor Mini-Review | thwaitm | Multirotor Talk | 35 | Jan 26, 2013 06:15 PM |
| Discussion Walkera HOTEN X | Ariete | Multirotor Talk | 1 | Jul 27, 2012 01:22 AM |
