Old Sep 11, 2012, 03:49 AM
abroadhurst94 is offline
Find More Posts by abroadhurst94
abroadhurst94's Avatar
United Kingdom, England, Lincoln
Joined Jun 2011
Help!
SolidWorks & Laser Cutting
Hi all,
I have a query about SolidWorks.
I'm designing a built up plane in SolidWorks using formers and ribs and was wondering if there is any way to cut these shapes out on a laser cutter?
At school we use 2D Design V2 to cut to a laser cutter, but I cannot find a way of transferring parts from SolidWorks into 2D design for cutting.
Is there a way of doing this or can you laser cut directly from SolidWorks?
Or is this just not possible?
Alex.
abroadhurst94 is offline Find More Posts by abroadhurst94
Old Sep 11, 2012, 08:50 AM
awmeade is offline
Find More Posts by awmeade
Registered Slopeaphile
awmeade's Avatar
S-u-A, UK.
Joined Jan 2003
Hi there,
We do this every day at work - just take a plan view of your former to be cut, stick it on a "blank" drawing sheet, and save as an AutoCAD DXF @ 1:1 scale. These are then imported to the nesting program en masse.
Hope that helps!
Andy
awmeade is offline Find More Posts by awmeade
Old Sep 11, 2012, 11:05 AM
limeybob is offline
Find More Posts by limeybob
United States, TX, Rockwall
Joined Jun 2007
Originally Posted by abroadhurst94 View Post
Hi all,
Alex.
Also, you can create a drawing from your solid, then section the drawing wherever you need to.
This then can be exported as a DXF.
limeybob
limeybob is offline Find More Posts by limeybob
Old Sep 12, 2012, 03:57 AM
Joined Jun 2011
Originally Posted by awmeade View Post
Hi there,
Hope that helps!
Andy
Hi Andy,
I gave this a go but couldn't seem to be able to save the drawing as a AutoCAD DXF format. Is there anything special I have to do to be able to do this?
Old Sep 12, 2012, 05:31 AM
awmeade is offline
awmeade's Avatar
S-u-A, UK.
Joined Jan 2003
Hi again,
So you have a 3D former (for instance) as apiece part on the screen.
My process is :
File > Make drawing from part
Select a "no border" sheet. This is an A3 bit of paper essentially, with no other details on it, completely blank.
Drag from the "view pallete" that pops up on the right hand side the correct view (i.e. the view of the part that will be cut)
Set the scale to 1:1 in the view contest menu on the left hand side of the screen
Go to file > save as
Use the drop down box to select *.DXF
Click the "options" box (lower left)
You can then select a version (we use R12) and the drop down box on the right we select "AutoCAD standard styles"
Click OK (window disappears)
Then you select a path to save the file to, jobs done.
I have attached a screenshot (hopefully!) of the "Export Options" window with my day-to-day settings on it.
Hope this helps!
Andy.
Old Sep 12, 2012, 06:39 AM
Joined Jun 2011
Andy, that was great, thanks! Tried it and it works perfectly.
For some reason the DXF format didn't come up as an option at home, but does at school. I'll experiment at home again in a bit.
Looking forward to cutting out some parts now
Old Sep 14, 2012, 08:05 AM
Hemikiller is online now
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Andy's method is exactly how I've been doing it since 2007 when we switched to SW.
Hemikiller is online now Find More Posts by Hemikiller
Old Feb 23, 2014, 06:57 PM
EdChamberlain is offline
Find More Posts by EdChamberlain
Joined Feb 2014
How did you get on with this? I'm having the same problem at the moment!
The setup we have is that we go file > print from 2D design, So I guess question is do you load the DXF into 2D design or do you cut it some other way?
EdChamberlain is offline Find More Posts by EdChamberlain
Old Feb 25, 2014, 07:58 AM
Hemikiller's Avatar
Joined Dec 2005
Did this solution in post #5 not work for you?
Hi again,
My process is :
Hope this helps!
Andy.
Old Feb 25, 2014, 02:08 PM
Joined Jun 2011
As Hemikiller says, the method described in post 5 has worked for me.
I then went into 2D Design and imported the .DXF file and it worked a charm for cutting out. I haven't cut anything with this method since last posting on this thread though as I've left sixth form and no longer have the access to the laser cutter sadly.
Old Feb 26, 2014, 03:00 AM
awmeade is offline
awmeade's Avatar
S-u-A, UK.
Joined Jan 2003
Get on it then fella
http://www.coultersmithing.com/forum...&t=78&start=50
Help! Laser Cutting services in South Africa bradley123 South Africa 4 Sep 15, 2012 08:00 AM
Discussion Laser cutting prices xterarc CAD/CAM 1 Aug 16, 2012 06:47 PM
Discussion Inexpensive Foam Cutting Template to be Laser-cut? dlinegar CAD/CAM 15 Jul 30, 2012 08:11 AM
Question Laser Cutting Service? Tail Spin1 Free Flight 5 Jul 06, 2012 04:49 PM
Question Cutting Depron with a 30 watt laser? rbneville CAD/CAM 4 Jun 21, 2012 04:39 PM
