Old Sep 10, 2012, 10:41 PM
Dave Moore is offline
Find More Posts by Dave Moore
United States, AZ, Sun City
Joined Jun 2002
Help!
Wing ID Needed - Stork?
I have a second-hand sailplane that is supposed to have a Stork wing (married to a Genie fuse). I damaged the wingtips and need to find replacements. I have two questions for you:
1. Can anyone confirm that the wing is a Stork? A key point is that the carbon fiber joiner is 0.35 x 0.47 inches (9 mm x 12 mm) and is straight, no built-in dihedral.
2. If not a Stork, any idea what it might be?
Dave Moore is offline Find More Posts by Dave Moore
Old Sep 11, 2012, 09:16 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
That certainly looks like a Stork. Mine is at the club right now, give me a day or so to get some measurements to confirm.
jkettu is offline Find More Posts by jkettu
Old Sep 12, 2012, 09:21 AM
jkettu is offline
Joensuu, Finland
Joined Mar 2002
Well, there are some differences to mine - the tip shape is slightly different and my joiner blades have a couple of degrees dihedral built-in. But there are several versions of Stork, maybe yours is just a different variant. The following data applies to a Stork 4 electric, x-tail.
Panel length: 930 mm = 36.61"
Profile thickness at root: 18.7 mm = 0.74"
Wing chord at root, including aileron: 221 mm = 8.7"
Incidence pin diameter: 3.0 mm = 0.12"
Distance between incidence pins, center to center: 123.5 mm = 4.86"
Distance from leading edge to center of front pin: 16 mm = 0.63"
Distance from wing bottom surface to center of front pin: 8.0 mm = 0.31"
Distance from wing bottom surface to center of rear pin: 9.0 mm = 0.35"
Distance from leading edge to front face of wing joiner: 73 mm = 2.87"
Distance from wing bottom surface to bottom of wing joiner: 3.1 mm = 0.12"
Wing joiner dimensions: 9 mm x 12 mm = 0.35" x 0.47"
Manufacturer's home page: http://www.heinrich.sk/index.html
Hope this helps.
Old Sep 15, 2012, 11:12 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
It could be an earlier version of the Stork, possibly version 1 or 2?
R,
Target
target is offline Find More Posts by target
Old Sep 21, 2012, 09:54 PM
Joined Jun 2002
Stork 1 - USA Version
After some research I'm pretty well convinced that this is a Heinrich Stork 1 - USA version. I've posted a wanted ad for the tips, but gotten no hits. So I thought I would bump this up and see if any of you can help me out.
The alternative is to throw away the whole wing or maybe try some sort of repair, which I would probably screw up and end up with a flying piece of ... junk.
Please save me from my attempts at a repair
Old Sep 21, 2012, 10:45 PM
jkettu is offline
Joensuu, Finland
Joined Mar 2002
Have you e-mailed the manufacturer (heinrich@heinrich.sk)? Even if they don't have that particular model listed on their website, they might still have all the molds and could make you a new tip at a reasonable cost.
Exactly how is it broken? Got pictures? If you can't find a replacement, what do you have to lose by attempting to repair it? Repairing composites is no more difficult than repairing balsa or foam, only different. Start a thread at http://www.rcgroups.com/composites-fabrication-210/ with as much information as you can provide and the gurus there will walk you through the repair. I'm sure you could make it usable. Maybe not pretty, but certainly usable.
Old Sep 30, 2012, 03:15 AM
drorsoffer is offline
Find More Posts by drorsoffer
Joined Feb 2006
My old Stork I had a terrible crash last year and the fuselage cone was permanently damaged. I wrote to Heinrich and they made me a new cone from molds they had. The service was great, it is flying again and I am happy.
drorsoffer is offline Find More Posts by drorsoffer
Old Sep 30, 2012, 09:52 AM
Joined Jun 2002
I contacted Heinrich and was told that they do not produce parts for the 10 year old old wing. So I'm stuck with finding used or repairing.
Found Stork wing kbellos Aircraft - Sailplanes (FS/W) 1 Sep 06, 2012 03:51 AM
Discussion Need help to ID parts moosebutler Parkflyers 1 Jul 10, 2012 08:55 PM
Question please help id wing and cg (cg found) steeg Slope 3 May 07, 2012 09:46 PM
Wanted Need: Left wing for Stork-e ChrisS Aircraft - Sailplanes (FS/W) 0 Mar 24, 2012 04:38 PM
Discussion Vintage High Wing ID Help nate1590 Fuel Plane Talk 3 Mar 03, 2012 01:14 PM
