Old Sep 20, 2012, 07:13 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Originally Posted by pencon View Post
Kahlog , when building the exhaust stacks , you need to keep in mind once you squeeze them to flare them out they will become much wider so they should really go down a size or two . What I would do is take a pair of pliers and a tape measure to the hardware store and sacrifice a couple of elbows in the store . Squeeze them and measure them . Then you'll be spot on .Mine ended up about 3/4 the diameter of the flare .Also if you look closely at the ones on my system there are raised weld beads .You can achieve this look by grinding away copper around the beads .Plane's looking great by the way .
They are already done and glued in place. I recessed them using scratch built internal boxes. The planes opening is 1", so using 3/4" elbows worked well.
Ive since added the german markings and a few other things. Will get a pic soon.
kahloq is offline Find More Posts by kahloq
Old Sep 20, 2012, 07:15 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Originally Posted by Joespeeder View Post
Hi kahloq,
Congrats and well done once again !!
I love the info about the gun cover and the repaint. I have some builds to do this winter but I still have a Laser 300v that needs a home and with the access the gun cover gives it moves this plane up in my choices. I'd love to use that space for access.
Thanks and congrats !
Joe
A laser 300v would fit this plane well ad would sound awesome.
The 21x14 prop im using is way more prop then needed to fly. The pitch makes the plane rocket Will try the 23x12 next time out.
Old Sep 22, 2012, 02:38 PM
gregg660 is offline
Find More Posts by gregg660
Joined Mar 2007
Great looking conversion. Im working on the same 190... but will be using the da 60. Im gathering the cg of 155mm is good to go as a starting point as stated in manual? Again..beautiful plane.
Gas n Go
gregg660 is offline Find More Posts by gregg660
Old Sep 23, 2012, 02:55 AM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Yeah, 155mm works fine. I think Im going to move it up a bit just to get the plane to plant on the wheels on landing instead of wanting to continue flying.
Old Sep 24, 2012, 06:39 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Adding the cockpit and pilot required compensating for that up front with about 9oz of lead. Odd since the cockpit/pilot isnt that far behind the CG, but........oh well.
Old Sep 24, 2012, 06:41 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Plane on her legs with markings and such applied.
Old Sep 24, 2012, 07:42 PM
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
fantastic job, glad the maiden went well
I gotta get my Platt kit out and build it
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Sep 24, 2012, 09:25 PM
Ldm is offline
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
Great job Kahlog
Ldm is offline Find More Posts by Ldm
Old Sep 25, 2012, 05:04 AM
SAPSPIT is offline
Find More Posts by SAPSPIT
Make me a proper Spitfire!
SAPSPIT's Avatar
Norway
Joined Jul 2009
Looking good
SAPSPIT is offline Find More Posts by SAPSPIT
Old Oct 01, 2012, 04:57 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Well.....got lucky at Warbirds over the Rockies event this past weekend.
A vendor was clearance selling an ESM Dornier-335 because they didnt want to lug it back to Canada from the event here in Colorado.
I got it for less then even the best place on the net VQwarbirds...who lists it at 579. My special grab it up price? $480 and I didnt even have to pony up shipping which would have been another $150. On top of this I also got the electric retracts as part of the whole deal.
I'll start a new thread on it, but Ive already ordered another rimfire 65cc motor for the front and will use something a bit smaller at the tail. A DO-335 is an inline twin motor setup.
Old Oct 02, 2012, 12:03 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
That great!
Are you gonna run two Power 160's?
Dornier 335 Maiden Flight (3 min 20 sec)
TripleW is offline Find More Posts by TripleW
Old Oct 02, 2012, 06:42 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Nope....a rimfire 65cc up front just like my Dora9 and then will have a power 60 at the tail. Plane seems to need a lot of nose weight, so using a big 65cc rimfire and 12s 8000 up front and a smaller 60 size motor in the back on only 6s should help with NOT having to add dead lead. The battery for the tail motor can still be positioned forward of the CG. I can also use a mix and turn that motor off if I want.
Old Oct 03, 2012, 11:43 AM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
With the 65cc motor you could run a drive shaft to the rear, And spin both props!
Old Oct 04, 2012, 05:37 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
SURE...but the weight to set that up reliably would add probably 3 pounds just by itself....and....wouldnt quite be scale
Old Oct 16, 2012, 07:37 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Got another flight on the Dora. This time used full flaps on the landing even though there was a decent head wind. The plane settled on the mains a lot better and there was no nasty bounce.
I had also added another 6oz of dead weight in the cowl(6oz of lead) to bring the CG a bit forward of the manual's suggested location(which is fine in the air, but not that great for landing).
Sold ESM FW-190 nib 300.00 shipped con us nofuelheli Aircraft - Fuel - Airplanes (FS/W) 4 Aug 30, 2012 06:15 PM
Sold ESM FW-190 kit for sale NIB 300.00 shipped nofuelheli Aircraft - Electric - Airplanes (FS/W) 2 Aug 29, 2012 03:12 PM
Wanted Esm fw-190-a scootrb4 Aircraft - Fuel - Airplanes (FS/W) 0 Jul 15, 2012 06:13 PM
Sold Pica Focke Wulf FW-190 D9 kit with extras jjscott Aircraft - Fuel - Airplanes (FS/W) 5 Apr 03, 2012 06:08 PM
Discussion ESM FW-190 D9 (50cc) Corsair 29 Glow to Electric Conversions 0 Mar 04, 2012 12:56 PM
