Old Nov 26, 2012, 07:57 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Originally Posted by drmgcm View Post
Maybe i will get more comfortable on the DLG over time, be able to put more ballast in it and fly it in higher winds, but really at higher winds you are fighting
to catch any useable thermals, you must just bounce through them at that
speed.
Learning to find and stay with thermals in the wind has been something I've spent a big part of the last summer on. I will agree that it's not easy and if it gets windy enough darn near impossible for me. Yet, I've seen some better pilots work in the wind a lot better than I do so I know it can be done and that I have a lot left to learn.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Nov 26, 2012, 08:00 PM
Tmfury is offline
Find More Posts by Tmfury
up from the skies
Tmfury's Avatar
United States, CO, Fort Garland
Joined Jul 2011
Flew 2-practice sessions,focusing on qt's which I've never really been able to do respectably.catching the tip and peg really consistently is no prob, and I've got a smooth way to have my preset on.but I just can't seem to to get a seamless turn around! My qt's are between 4-5 sec, I've done a few in 3- sec but not consistantly . I feel like I may never see a 1.5 sec turn round!
That's what keeps it fun ,the challenge never ends
Make my words, ill get a my 1.5-2sec qt's and my grade10
Tom
Tmfury is offline Find More Posts by Tmfury
Old Nov 26, 2012, 08:02 PM
Tmfury is offline
up from the skies
Tmfury's Avatar
Joined Jul 2011
Make my words, ill get a my 1.5-2sec qt's and my grade10 !!
Tom
Old Nov 26, 2012, 08:12 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Flew 1S for about an hour. Had no issues, but I'm still wondering why I'm doing it as I've never had any issues with regulators
jfinch is offline Find More Posts by jfinch
Old Nov 26, 2012, 08:18 PM
gtrbaby is offline
Find More Posts by gtrbaby
New Zealand, Waikato, Hamilton
Joined Jul 2011
finally got my NEOS light back in the air after some "issues" crash and burnt out servos.
tested the repair at lunchtime - goes sweet - bit windy - probably 20kph+ - hooked some good wave lift and just stayed in it foe about 5-10 min - got to about 250-300m then bailed as I was over some commercial buildings....
rest of the time I was fighting turbulence - but had a few good flights..... love teh NEOS!!
gtrbaby is offline Find More Posts by gtrbaby
Old Nov 26, 2012, 08:22 PM
Hanger Rash is offline
Find More Posts by Hanger Rash
Launch low. Fly high ;)
Hanger Rash's Avatar
USA, UT, Alpine
Joined Dec 2010
Jon - You are the man to watch. I won't think about 1s until you haven't crashed your plane for 6 months.
Hanger Rash is offline Find More Posts by Hanger Rash
Old Nov 26, 2012, 08:36 PM
DeadServo is offline
Find More Posts by DeadServo
Joined Sep 2012
Finally sat down and input my flight modes in my Stobel. Used Jun's youtube video as my guide. But going back to work tomorrow so no flying every day anymore
DeadServo is offline Find More Posts by DeadServo
Old Nov 26, 2012, 08:38 PM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
Well i got my throws a bit higher with the momentary launch switch and more energy into the through but then I started to lose trim and it turns out I broke it. The ailerons are coming away from the foam. The skin is intact but pealed away from the foam on the inside of the wing. Anyone have a quick fix for this?
xrx1113 is offline Find More Posts by xrx1113
Old Nov 26, 2012, 08:55 PM
gtrbaby is offline
Joined Jul 2011
yep - take some thin epoxy and rub it on the surface of the affected area - it will soak in. LEAVE IT until it sets.
I just did this on my NEOS on some delam and it worked sweet - you only need a little bit of epoxy - but make sure its thin.......you can heat it to make it runny
Old Nov 26, 2012, 08:56 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Take a picture and post it in a new thread and I'm sure people offer up all sorts of good suggestions for the fix.
Old Nov 26, 2012, 09:51 PM
bbbp is online now
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
I first tried some superglue,but it came apart again, so next time I used standard Elmers carpenters glue I had on hand. Clamped it while drying and it is still together after a few months.
BP
bbbp is online now Find More Posts by bbbp
Old Nov 27, 2012, 07:28 AM
fwroberts is offline
Find More Posts by fwroberts
Rick Roberts
fwroberts's Avatar
United States, MA, Montague
Joined Aug 2012
Today, on the east coast, I loaded my DLG into the car hoping to get a couple flights at lunch time. And last night I ordered a new LightWave IV and dreamed about Spring in New England.
Rick
fwroberts is offline Find More Posts by fwroberts
Old Nov 28, 2012, 09:23 AM
xrx1113 is offline
xrx1113's Avatar
Joined Aug 2011
Since my maple leaf is out until i fix the delaminated ailerons i threw my poly 2 ch after work and got my momentary launch switch settings sorted out. I have right rudder and some up elevator on the momentary switch but when the elevator is trimed for leval flight (off momentary switch) it is too much up with the launch and it loops the glider so i put a cruse mode on a switch and I launch with the momentary than when I let the switch go I have a bit of down in the elevator so it continues up and dosn't loop then at the top i push it over and hit the cruse switch which puts me back on a good flat glide path. It was a good session and it gets the blood going after sitting all day at work.
Maple leaf : Tonight i'm going to squirt medium foam safe ca onto the gaps and weight the wing down with bags of sand overnight.
Old Nov 28, 2012, 03:10 PM
Wave Glider is online now
Find More Posts by Wave Glider
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
Really glad to see this thread is still going, hopefully inspiring people to "do stuff" with their DLG's daily I havent added anything constructive to the conversation lately, so I guess I'm due. I recently picked up a Taboo XL Poly, thats right, a circa 2003 rare-to-still-find-in-one-piece bird, and its beautiful. I'd say museum quality possibly. I've been working on it a little here and there, balancing it and converting it to LiFe and 2.4, but quite frankly, I'm almost a bit scared to throw it! I'm torn between tossing it and just hanging it in the ceiling as a piece of display art
Wave Glider is online now Find More Posts by Wave Glider
Old Nov 28, 2012, 03:26 PM
DProseus is online now
Find More Posts by DProseus
Wilson, NC
Joined Jun 2006
I have seen it. It is everything he says.
Dick
DProseus is online now Find More Posts by DProseus
Discussion How do you travel with your DLG, Blaster 2-3, Fireworks etc nph Hand Launch 17 Sep 28, 2015 03:55 PM
Discussion What crazy thing did you do with your plane today? RCAddict16 Electric Plane Talk 14 Nov 16, 2014 09:31 PM
Discussion What do you guys do with your Old RC Toys? Sherlock221B Chit Chat 11 Oct 08, 2014 01:46 AM
Discussion What Do *You* Do With Your Clapped-Out Servos? A Useless Geek DIY Electronics 6 May 03, 2012 03:30 PM
Poll What do you do with your Old Timer? orange&white Vintage & Old-Timer Designs 17 Apr 25, 2012 04:14 PM
