Old Sep 10, 2012, 07:03 PM
Eddie500 is offline
Find More Posts by Eddie500
Joined Nov 2011
powerlab8 6s1p lipo paraboard question?
I already own the powerlab 8. I am new to lipo charging so have only charged NiMh batteries.
I will be purchasing 8 6s1p batteries. These are rated at 20c and are the turnigy 5000 hobby king batteries. I will be using these on my electric bicycle.
I was wondering if I cold charge all these packs together in my powerlab 8?
My questions are the following, will a paraboard balance all of the packs hooked into it while charging, if so how does it do that? Will the powerlab 8 know to stop the charge?
I see the paraboard 8 has 6 connections for batteries. Is there a way I can charge all 8 of my 6s1p batteries together? Like can I hook some up in parallel before hooking them up to the paraboard?
Please let me know any other important facts before I do this. I am new to this battery technology.
Eddie500 is offline Find More Posts by Eddie500
Old Sep 10, 2012, 08:06 PM
BVH is offline
BVH
Find More Posts by BVH
BVH
BVH's Avatar
United States, CA, Pismo Beach
Joined Dec 2006
If by Paraboard, you mean the FMA brand MPA board then you could charge all 8 at once if you buy a second MPA and connect it to the first one thru the daisy chain connector port and feed it main power via connection to the first boards high power connectors going into the charger. All connected packs are balanced charged during the normal charging cycle. All cell #1's of each of the 8 packs are essentially connected together thru the boards design, same thing with #2s, #3s and so on. The charger sees the whole mass of packs as one big 6S pack.
To get a 1C charge, you will need a high power, power supply to obtain 40 Amps output (1C in your case) Use FMAs' on-line calculator to be sure you can get what you want with the power supply you have in-mind. It will need to be 24 Volt, 50 Amp minimum.
http://www.revolectrix.com/PL8_calculators_Main.htm
What brand of bike?
BVH is offline Find More Posts by BVH
Sold Blue Lipo 6-Cell 4000mAh 6S1P 22.2v 20C DbleX Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jul 30, 2012 09:16 AM
Sold Pair of GENS ACE 3300mah 6S1P 22.2V 25C Lipos jabull Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 28, 2012 10:00 PM
Sold Pair of GENS ACE 3300mah 6S1P 22.2V 25C Lipos jabull Aircraft - Electric - Helis (FS/W) 2 Jul 28, 2012 11:24 AM
Sold SOLD - (2) GENS ACE 5300mah 6S1P 22.2V 30C LiPo RC Battery Pack KingJoe Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 28, 2012 09:25 AM
Sold GENS ACE 5300mah 6S1P 22.2V 30C LiPo RC livinma1 Aircraft - Electric - Batteries & Chargers (FS/W) 8 Apr 15, 2012 09:10 PM
