http://www.headsuprc.com/servlet/the...70-Zoom/Detail with the acp 6x4. Like I said, I put 1.5oz lead in the nose. With a 1300mah battery, my AUW is 19oz |
Wow, this plane just gets better and better! It flies nearly as well carrying my GoPro as it does without, even with the change in CG (GoPro is right at the nose, weighs 4 oz). The only adjustment I make when I mount the GoPro is give a couple clicks of up-trim to the elevons.
As-designed, the plane flies rather smoothly. I've added gyros to enhance that, and to provide extra control when flying in wind. The control is so good that I don't mind flying just a few feet off the deck, even in wind. Here's my latest in-flight video. The only change I've made to the plane is to go from a 9x4.7 SlowFly prop to a 9x6 Electric. It made a big difference.
What issue did you have with your 40 in build. I'm thinkingof building a big one out of multiple layers.
I salvaged what I could from that plane and made a new 30" span version using dollar store foamboard. I followed brandon's plans more closely. I even used the same motor and prop. It flew, but barely! That's when I decided to try a different prop. I went from a 9x3.8" Slow Fly to a 9.47" Slow Fly... and it made a huge difference. The first prop, with my 1130 Kv motor, must have been right on the hairy edge of constant prop-stall. With the new prop, the plane actually flew pretty well. My latest change was to go from that 9x4.7 SlowFly to a 9x6 Thin Electric... which really did the trick! Climb rate, maintaining speed and elevation through turns, and top speed were all improved dramatically. Now that I look back on the whole experience, I probably could have made the 40" version work, had I just tried a different prop. Oh well, at least I know now what I need to do on the next one. Good luck with it... I think if you keep the airframe stiff and give it enough speed, it will probably fly great. I plan to build another one myself... properly this time. |
I learned a lesson today: don't get cocky and start believing you're a master of flight, especially near water. It doesn't matter how great things were the day before... All it takes is one mistake and then you're thigh deep in the lake, retrieving your little plane made of foam and paper.
| Thread Tools | |
| Discussion Simple Delta... a quick build "prop on the front" delta | dekan | Foamies (Scratchbuilt) | 2719 | May 09, 2013 10:49 PM |
| Sold AWESOME FLYING PLANE...NIB MIDWEST PITTS SPECIAL w/FREE S&H!!! | Plasmajoe | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jul 22, 2012 10:22 AM |
