Joined Nov 2012
Hi mate,
I also have the Devo10/RX2703H-D combo, and its giving me trouble! Only pretty new to RC helis so jumping in at the deep end, I know. Been trying to level the swash plate, can get it perfectly flat at 60%, but having trouble adjusting it at the high and low end. I cannot for the life of me adjust the pitch travel at all. Elevator is no problem as is aileron. At 100% pitch, the pitch servo actually goes down from its previous position, and I have no idea why? Hopefully you might be able to help, if not, misery loves company! Regards, Owen from Melbourne. |
Did you level your swash-plate with pitch at 0% ? By that I mean the blades are at 0 degrees of pitch as in collective.
Your 60% is that throttle/collective if so your swash-plate may be level but your are at hover pitch angle which is around 5.5 - 6 degrees of pitch. Do you have a pitch gauge to measure the angle in degrees? Also, the adjustment links are not turn-buckles (1 left hand thread & 1 right hand thread) so you can't just turn the rod to adjust them, you need to dis-connect the ball-links & turn them the same amount of turns on each one in or out as needed. They are right-hand threaded & you will need pliers to hold the rod. In normal mode I run my collective at about 60 - 65% with the stick in mid position. But in stunt 1 or 2 they say to run it at 0 degrees at mid stick, problem with that is when you switch to stunt 1 or 2 and you are hovering you will jump downward. So I run my stunt 1 & 2 at 60 - 65% at mid stick, no jump! If you have to take off that fore/aft cyclic adjustment rod to adj. your fore/aft cyclic, you have to unscrew the anti-rotation plate to give you access to the ball-links. I just recently found out that the instruction I had for my helicopter TX/RX were not correct for doing the "Binding" You need to turn on the TX & put all of your trim adjustments to midpoint & sub-trims at 0% after that turn off the TX & it saves it in memory. Then, plug in the battery for your helicopter, you should see the RX red LED is not lit. Immediately turn on your TX & you should see the LED start blinking fast, then it blinks slow, then you hear a beep from the motor. You are now properly "Bind-ed" you should find that your swash-plate is level. You only have to bind like that for the first initial bind, or you get a new TX or RX like I did. For now on, to initialize or bind again, just turn on the TX first and after the TX beeps, turn on or plug in the battery with-in 10 seconds. Make sure you don't move the heli while it goes through its binding, check the LED to be sure it worked it should be a steady red & you heard the beep. I hope this helps you out Mate! Quote:
Sao Paulo, SP, Brazil
Joined Feb 2010
Hi guys,
I have a similar problem: I'm having a hard time to setup a CopterX 450 with the RX2703HD and my Devo 12s, as I can't find any documentation about this receiver. Could you post and share here any docs you may have, please? I thought it would be same as the RX2702, but it is nothing like that! The first thing I noticed was the absence of the four servo reversing switches, and in fact I need to reverse the elevator servo... Obviously I tried to reverse the channel at the TX but, as expected, it reversed the command and not at the swash mixing. Best regards, Haddad |
You need a Savox/Align servo they are the only ones that move in the correct direction other than the Walkera servos. Search for "IntegrityHndywrk" he has a blog about the V450 D01 and the servos.
I will attach 2 Pdf files one is on the RX & the other is on the Devo 8-12 TX I got it direct from Walkera when I emailed them about no owners manual on their web site. That file upload didn't happen, it exceeds the file size limit of 3 megabytes. So I would suggest that you go to Walkera's web site & ask for it in the support area of their web site. Sorry I couldn't help you out. |
Joined Feb 2010
Thanks for your answer! Is that pdf on the receiver alone too big to be posted? I already have something on the Devo 12s, but absolutely nothing on the RX2703HD. I think it could be of great help. Thanks again. |
The PDF file is too large to post. Contact Walkera & they will E-Mail you a copy. You will need both manuals as the RX is explained in the Devo 12s & the RX2703H-D manual.
Correction on the servos, those Align/Savox's are only good for a RX 2702 because you can reverse the travel on the RX. I think we are screwed by owning the 2703H-D RX, by being forced to only buy Walkera servos. |
Joined Feb 2010
Hi, Iflyhelis,
I finally got something from Walkera, but definitely it's not what you were talking about. It is only a pdf with about 1.2MB. It has four pages full of Devo12 screenshots explaining how to to set it up for the V450D01. But it has some questionable instructions like to set the swash type to 3 servos 120° and to reverse aileron channel... Any way, how do you feel about using DropBox, or whatever like that, to share some big files? ![]() Meanwhile, I don't think we are screwed by being forced to use Walkera's servos, actually I have just tried a few Corona DS-939MG I had at hand, and they fit. They are a bit slow but ok for scale flying. The Corona DS-929MG would be better, because the specs are close to the Walkera WK-09-9 but are metal gear and cheap. On the other hand, I'm comfortable with disassembling servos to reverse it.. And we could go for programmable digital servos, too. Best regards. |
I saw that before, & it isn't correct. Send me your E-Mail address in a private message here & I'll send you the two files I have one at a time, as I have a 10 megabyte E-Mail file size limit. One file is a hair over 9 MegaBytes, the other one is almost 4 MegaBytes.
About the servos, I just heard that a Futaba 9257 is of equal specs as our tail servo by Walkera, but you should validate that (size & power/torque) Quote:
Joined Feb 2010
I've sent you two private messages but they do not appear on my sent messages folder, so I don't know if the messages were actually sent... Could you please confirm reception? Regards |
Joined Feb 2013
Devo 10 + 2703-hd
Hi, just to go BACK to the original topic,
i UNFORTUNATELY bought this piece of cr*** , curious to see the "6 AXIS STAB" which i understand now is just...3D, gyros on 3axis , because A REAL 6 AXIS STAB MEANS 3 VERTICAL AND HORIZONTALS ACCELEROMETERS plus 3 GYROs, i doubt they Put this, and there are several things i can't figure out. First, just after unboxing the bird, it was absolutely UNFLyABLE ! Poor quality of settings (kind of random settings every where, like sticckers on blades, devo settings and very poor quality of blades, not the same COG) but the thing which make me crazy is because of the Throttle protection, which require that the throttle trim is at min, make it started on DEVO10 at -12.5% !!! So all my pitchcurve is useless and the bird fall as soon as i pull down the throttle because the Trim servo SUDDENLY return to the lowest position. Any idea guys ? |
| Thread Tools | |
| Sold Walkera devo 10 with receiver | vewdew | Aircraft - General - Radio Equipment (FS/W) | 0 | Jul 11, 2012 03:33 PM |
| Help! Walkera Devo 7 - Binding to an RX2614V-D | kmac1369 | Radios | 0 | Jul 05, 2012 11:06 AM |
| For Sale $ 1.00 NIB Walkera Devo 12S Radio With Telemetry Module (WK-CTL01-D) | Aurora9 | Aircraft - General - Radio Equipment (FS/W) | 4 | May 10, 2012 11:07 AM |
| For Sale SOLD **** Walkera RX2702V-D (YES DEVO) - NEW and TESTED | fletch3d | Aircraft - Electric - Helis (FS/W) | 5 | May 05, 2012 08:28 PM |
| Sold Walkera rx-2614v-d 3 axis for devo | dohcter | Aircraft - General - Radio Equipment (FS/W) | 2 | Apr 26, 2012 02:36 AM |
