Old Sep 12, 2012, 11:47 PM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Maxx Products makes several different lengths of extensions for the remotes ... probably don't go quite so far as down the tailboom, but I think they have a 36" extension.
Realize that the manufacturer does not recommend this long an extension, but with the data logger you should be able to test until you feel good about the performance.
Others have done the same and are happy with the results.
tkallev is offline Find More Posts by tkallev
Old Sep 12, 2012, 11:54 PM
edfmaniac is offline
Find More Posts by edfmaniac
Joined Jul 2009
To twist those phone conductors easily and with almost machine like uniformity, grab your drill, anchor one end of the wires to something solid and put the other end in the drill chuck. I double the drill end of the wires over and/or put some tape around them to give the chuck something to hold on to. Pull the wires tight with 5 or 10 pounds of tension and twist away. Do as long a section as your work shop allows and roll up what you don't need for your next project.
edfmaniac is offline Find More Posts by edfmaniac
Old Sep 13, 2012, 07:02 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Any of the Spektrum/JR satelite based receivers should be fine. Getting the two receivers as far apart as is practical would be best as this will enhance diversity, but I would not be overly concerned. If I was using a Futaba FASST receiver I would simple spread the antenna and not be concerned. Spektrum/JR are the only ones who do this remove receiver thing. So the normal spread between receiver and remote is more than adequate.
AR710 should be fine
http://www.horizonhobby.com/products...iver-SPMAR7010
If you need a couple more channels or prefer the JR brand, then the JR 921X would be a good choice.
http://www.horizonhobby.com/products...eiver-JRPR921X
If you want to spread them out, use a receiver extension wire
http://www.horizonhobby.com/products...ension-JRPA185
http://www.horizonhobby.com/products...ension-JRPA183
aeajr is offline Find More Posts by aeajr
Old Sep 13, 2012, 10:17 AM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Originally Posted by aeajr View Post
... the normal spread between receiver and remote is more than adequate.
That may be so, but mounting the satellite receiver in the fin offers the additional advantages that:
  1. The antennas are vertical and therefore work well in conjunction with the forward antennas, which usually have to be horizontal, either left-to-right or front-to-back, to fit. Vertical orientation results in a horizontally omnidirectional antenna pattern when the sailplane is flying normally. The only nulls for the receiver in the fin are straight up and straight down, and those directions are covered by the main receiver in the nose.
  2. The antennas are far away from most of the rest of the plane and away from components like the battery and servos that might block line-of-sight communication.
  3. At least in a cross-tail Shadow or Xplorer, there's no carbon fiber in the upper 2/3 of the fin, as you can see in the picture I posted above where I held my fuselage in front of a bright light, so carbon is not a problem.
Miami Mike is offline Find More Posts by Miami Mike
Old Sep 13, 2012, 01:20 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
No arguement from me.
Old Sep 13, 2012, 01:40 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Rick-
30ga servo wire should work for the extension. Bum some from a DLG buddy.
G/L,
Target
target is offline Find More Posts by target
Old Sep 13, 2012, 02:22 PM
Evan D is online now
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
You can get a set of 2 that have a 60 and 90cm for under $2. But I warn you it's from that nasty Orange company someone here doesn't like... It's gets a satellite to the top f my vert stab in my 3.5 and 3.7 ships which both use Orange 9ch receivers with 2 satellites each. Great reception.
http://www.hobbyking.com/hobbyking/s...2pcs_set_.html
Evan D is online now Find More Posts by Evan D
Old Sep 13, 2012, 07:18 PM
Steve Bailey is offline
Find More Posts by Steve Bailey
Steve Bailey's Avatar
United States, IN, Mishawaka
Joined Sep 2009
Personally, I don't see the logic of spending thousands on a airframe and servos then trying to save a few bucks on the receiver and wire!
Steve Bailey is offline Find More Posts by Steve Bailey
Old Sep 13, 2012, 07:21 PM
ThermalBuster is offline
Find More Posts by ThermalBuster
ThermalBuster's Avatar
Orlando
Joined Sep 2004
Interesting. I have a supply of ribbon cable. I'll strip three conductors and extend the remote. I like Mike's explanation and he's never steered me wrong. I'll use a logger I have installed in another plane to check out the operation. Should give me the confidence I'm looking for... (I hope.)
Thanks Guys!
Rick
ThermalBuster is offline Find More Posts by ThermalBuster
Old Sep 13, 2012, 08:53 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Because the lower priced receivers have as good or better reputation than the expensive ones.
Old Sep 13, 2012, 08:57 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
Originally Posted by ThermalBuster View Post
Thanks Guys!
Incidentally, I got the idea from this post by Robglover almost two years ago.
I hope to see you at the IRKS field this weekend for FSS #6.
Old Sep 13, 2012, 09:05 PM
Joined Sep 2009
Where can I read these reviews? I most definetly would like to see that.
Old Sep 13, 2012, 10:29 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
I beleive my own results. Come on down and fly with me anytime and you can see for yourself...
Old Sep 14, 2012, 12:37 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
I'll second the solid reception of the HK 'OrangeRx' receivers - I exclusively use their 6ch offering in all my planes (uncased for low weight {4g} where appropriate) and haven't ever had a problem.
In larger planes I add their satellite to the system and have yet to have any sort of problem with range or control, even with a fast 1500mm .46-powered Stick and a 2.5m 2ch glider.
For a 4m competition glider I'd be tempted to recommend the long-range Spektrum chips with satellites but to be honest I'm yet to find the limitation of a HK 'OrangeRx' setup.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Sep 14, 2012, 12:48 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Thanks Guys!
Rick
I never "mount" a data logger in my plane... Just get a handful of servo extensions in the lightest wire gauge you can find, and just plug one in to the data port....
When you do your ground or after flight checks, just don't shut down your RX or TX power, and plug in your "hand held data logger" to the extension, and you have the info....
Two data loggeres are nice to have, one as a back up.
I even washed one of mine in the pocket of my shorts, and it STILL works after that!
The plane wouldn't fit in the washer, so you can see why I don't mount the data logger permanently in the fuse, right? Kidding.
You can use the data loggers loose is my point, and they are handy, but it's easy to misplace them, so be careful.
R,
Target
Sold Thanks SPasierb Aircraft - Sailplanes (FS/W) 1 Aug 15, 2012 01:04 PM
Help! Win the best 4 meter plane EVER! webbsolution Thermal 6 Feb 29, 2012 06:17 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 06:14 PM
Question best sailplane for Hacker B40-6L with 4.4:1 FULLSCALE Electric Sailplanes 8 May 13, 2011 06:09 PM
Discussion 3-4 meter wingspan sailplane for FPV; Alpina 4001/5001 Michael.Ryde High Performance 0 Mar 30, 2010 11:04 AM
