Just a couple of extra little bits done. It got too warm to keep working so I had to stop, I'll likely do a bit more this evening. I need to route the servo wires and install the servos then cut the slots for the control horns.
Second elevon cut ![]() She's looking a bit more business like now! ![]() Control Horns
Servo holes cut and hollowed out. I still haven't decided how I'm going to seat them, I'm thinking that a light ply insert or some sheet fiberglass might do the trick.
![]() I've tunnelled out foam from the servo recesses and also through to the electronics bay. I've also made recesses for the servo connectors and the wires so that if I need to change them it's just a matter of lifting the elevons and swapping them out. ![]() Both servos and control horns installed but not permanent yet. I will use a standard two part epoxy on the control horns but I need to be able to replace servos if they die. ![]() ![]() Kahu will be pretty clean when she's all done and I'm still trying to decide if I want to put a duct forcing air both into the electronics bay and also to the motor or if I leave the motor in the wind. Again it's a case of making sure that I'm able to easily replace parts if they fail. I still need to figure out how to make the motor mount removable. The final thing that I will need to decide on is if the trailing edge in front of the prop needs to be streamlined - I'm guessing that if I want her quiet that a nice trailing edge will be needed. ![]() This will be it till I can get back to the hangars because I need to clean up the elevon interfaces, probably with some micro, before I install the hinges and then it'll be test flight time! |
Final(ish) CG calcs done using http://wingcgcalc.bruder.com.br/en_US/?
I gave myself a bit of a fright by not measuring properly the first time and the CG came out a good 25mm or just shy of an inch forward of what I though it was but then after some rather concerned and extremely anal remeasuring it came out exactly where I was expecting it. ![]() First test throws followed by the first test flight will be this weekend. I am quietly pooping myself as it's a whole lot of plane and she's no foamy... |
"I really need to finish one of these planes... I've told myself that I'm not allowed to start any more until I finish one first!!!"
Ha! That is my problem too. I'll be working in my shop on something, go looking for a part, tool, whatever, find something I forgot I had, and think, "Gee, I could make this into a really great (whatever) - I have the attention span of a qnat, which is definitely less than a goldfish, lol. |
I should be getting some work and hopefully first flight this weekend. Last time I tried to get it launched it ended up being a bit too cumbersome to hand launch so I've rigged a bungee but I'm going to have to put both a rail and a hook on the bottom of the wing to make launching a bit less painful. She's going to be a bit quicker on the landing than I was expecting I think.
Looks great Steve!
![]() Could I suggest you just glue your servos in with hot melt glue. If you glue around the outer perimeter of your servos you will be surprised how firmly they will be held in the foam. Also, could I suggest you shorten your servo arms way down - even so they are below the wing surface - as you will find your elevons won't need much travel and it is best to make use of the mechanical advantage that will bring - rather than dialling down of throws on your Tx to probably less than 20% that the current servo arms will require. Don't worry about the landing, it will be easy so long as your CG and throws are OK! Having the towhook will make it pull up really quickly when it does touchdown. Just on your CG calculation, it looks like you included the area of your winglets in the calculation. Is that right? I just think your proposed CG location looks to rearward by about 30mm. Good idea about using a bungee too! Regards Peter |
The wing has a fairly benign glide from the throws that I have completed so far but I can't get it floating for long enough to get the 11 inch prop spun up. Doing some cursory hang tests (giving it full throttle whilst hanging the wing from my hand) it has plenty of power once the motor spins up, it's just getting enough forward speed to get it flying. |
| Thread Tools | |
| Discussion Making a foam cored wing using 2-part rigid polyurethane foam in the mould. | AvB | Composites Fabrication | 233 | May 20, 2013 07:36 PM |
| Idea CNC Foam Core Tailless Flying Wing DLG SAL Design.. | RobertTHaas | Hand Launch | 41 | Dec 22, 2012 08:30 AM |
| Discussion What type / name of foam for wing core ? | lamafever | Composites Fabrication | 8 | Sep 16, 2010 12:25 AM |
| Build Log Mc Clain Wing Cores 48" virgin foam and EPP flying wing | pval3 | Flying Wings | 125 | Jun 03, 2010 03:13 AM |
| Foam core wings. Yes or No? | JimJams | Giant Scale Airplanes | 0 | Feb 02, 2005 06:54 PM |
