Old Sep 09, 2012, 08:50 PM
bambanx is offline
Find More Posts by bambanx
Joined Sep 2012
bixler motor
Hello guys i am new on rc planes, i buyed my bixler(my first plane) and i need a recomendation for motor and battery , i have a esc 30A , i am looking for a good autonomy maybe a motor with a 5000MA is posible? pls guys i am beginner give me a hand .
thanks very much
bambanx is offline Find More Posts by bambanx
Old Sep 10, 2012, 02:37 PM
wayfaringdreamer is offline
Find More Posts by wayfaringdreamer
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
There's some great threads on the Bixler where you might find your answer:
http://www.rcgroups.com/forums/showt...ghlight=bixler
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Sep 10, 2012, 03:39 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
What the wayfaringdreamer said!
HK sold that (if it is the HK 1400 Bixler) with a motor they called the 2216 1900 Kv motor or something like that but no further details on the motor were made know nor was it one of the motors that HK sells. So the only way to figure out a power system for it would be to get the details (motor weight and size for example) from someone that has one.
I'm sure that whatver motor HK put in it, there would be a better motor you can use.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Sep 10, 2012, 05:22 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Note that when you look for an "equivalent", that HK 2216-1900 must be approximately 22mm diameter and 16mm length overall... [close to a 19g AX 1806 or ELE C20 motor].....not to be confused with the far more powerful Hyperion 2216 and Suppo 2217 motors which are 22mm stator diameter and 16-17mm stator depth (and 64g and 72g respectively).
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 11, 2012, 11:30 AM
bambanx is offline
Joined Sep 2012
Thx guys for your reply i buyed this:
http://www.mmhobbies.cl/product.php?id_product=365
What u think? Is not for fpv i am using bixler for learn to fly
What battery i can use for long time fly? I have a esc 30A
Thanks a lot
Old Sep 11, 2012, 07:30 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
That is a fairly heavy, but potent motor for a Bixler! For long flight time on 3s I wouldn't use more than a 5" prop (6x4 may pull 24A... even a 5.1x4.9 Zagi will draw 20A). At that rate (WOT) you'd need 2100mAh to get 6 minutes.
Old Sep 11, 2012, 07:40 PM
bambanx is offline
Joined Sep 2012
Some guy say he use 5000 ma battery what uthink? 6 minutes is little time o wanna fly more time
Old Sep 11, 2012, 08:08 PM
Jack
USA, ME, Ellsworth
Joined May 2008
That was six minutes at full throttle, do you think you'll fly at full throttle all of the time? I think most of us throttle back a few clicks or more and it is easy to drop the current draw to half and get double the time.
And I though the Bixler was supposed to be a glider of sorts, don't they turn the motor off and glide?
Jack
Old Sep 11, 2012, 08:23 PM
bambanx is offline
Joined Sep 2012
I dont know i am new but what u think on use this motor with a 5000ma battery?
Old Sep 11, 2012, 08:35 PM
Jack
USA, ME, Ellsworth
Joined May 2008
In this thread about Bixlers using the Turnigy 2826 2200 motor, Manuel V. says:
'"..I think, APCe 6x4 is tha best prop for this motor, around 20A and 19,000 rpm..."
So if you fly at a constant 20A current draw your duration would be as follows from a 5000 mAh battery. Typical battery efficiency says you'll get 80% usable capacity so you have 4000 mAh you can use
4000 mAh = 4A
4A x 60 minutes = 240 Amp/Minutes
240 Amp/Minutes @ 20A = 240 / 20 = 12 minutes.
So once again I ask, do you intent to fly at full throttle constantly? Will you not ever throttle back or shut down to glide?
Jack
Old Sep 11, 2012, 08:37 PM
bambanx is offline
Joined Sep 2012
I dunno cos will be my first fly but i like speed
Old Sep 11, 2012, 09:49 PM
Jack
USA, ME, Ellsworth
Joined May 2008
I'd try half throttle or less for the first launch and add power slowly as needed.
Learn to fly first, then learn to fly fast. It makes the airplanes last longer...
Jack
Old Sep 11, 2012, 11:29 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Suggested AUW for a Bixler is 650g... that goes out the window if you use a 5000mAh pack weighing 443g by itself!
Old Sep 28, 2012, 09:13 PM
itai n is offline
Find More Posts by itai n
Haifa, Israel
Joined Nov 2009
I fly my Bixler with the original motor. 6x5.5 APC prop and 4A ESC. I removed the weights and the front and use 2200 mah 3s batteries. The model is equipped with FPV system.
This setup gives me an average flight time of more than 20 minutes.
That prop is definitely too much for the model but I'm just too lazy to replace it.
Note to the OP - these models are definitely not designed for speed. When I tried full throttle on a lever flight I had some scary seconds losing control, probably result of the wings flexing.
Also do not even think of using 5000maH battery. The model is not designed to take that weight. Learn to fly first, then learn how to re-engineer a model.
itai n is offline Find More Posts by itai n
Old Oct 06, 2012, 09:21 PM
lectroglide is offline
Find More Posts by lectroglide
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
always hate hearing when someone wants to go constant WOT on a glider type model, normally we go WOT to get some altitude then throttle way back if not off ,pull up a lawn chair/good book and just fly around hoping to catch some hot air
lectroglide is offline Find More Posts by lectroglide
Discussion recommended glue for bixler motor mount asaak Foamies (Kits) 2 Jun 25, 2014 03:36 PM
Discussion Hobby King Bixler motor? wehrwolfzug Power Systems 6 Mar 01, 2014 12:33 PM
Discussion Bixler motor choice, need to decide which one to go for WiseDuck Foamies (Kits) 1 Apr 12, 2012 10:47 AM
Discussion bixler motor uppgrade n00lesd Electric Plane Talk 5 Mar 17, 2012 02:46 PM
Video Bixler Video - Testing the bixler Axnfloater Electric Plane Talk 15 Nov 10, 2011 07:50 AM
