Old Sep 09, 2012, 06:57 PM
Balsa is for doll houses
Skrogg's Avatar
Texas, San Antonio
Joined Aug 2004
Had an old ESC burn up on me
Built a Tuffwing quick with an old 25amp ESC i bought back in 2006. the motor was a EMAX CF2822 & 5x7 prop . Was flying around for about 4 minutes when she rolled inverted and burned in from 100ft , I lost all control .. when i picked up the wing I could smell the esc. I did cut off the bullet connectors and soldered the wires straight to the motor. Did I do something wrong? I didn't notice anything funky when i ran it on the bench.
Skrogg is offline Find More Posts by Skrogg
Old Sep 10, 2012, 11:43 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
2006
It is hard to say what it could be...
Looks liken there is no ventilation for the ESC... What temps was the ESC running at? I would be concerned about temps. Did you loose servo power also?
You can use the online repair form to send in the ESC...
http://www.castlecreations.com/support/repairs.html
Clintstone is offline Find More Posts by Clintstone
Old Sep 10, 2012, 01:57 PM
Skrogg's Avatar
Texas, San Antonio
Joined Aug 2004
Thanks for the reply . Yeah I lost everything and it went in. I wasn't really concerned with the ventilation because of the little motor & prop.. I was only in the air for around 4 minutes before it gave up the ghost.
Not worth it to me to send it in for repair , nothing I'm flying these days would use a 25amp esc. Probably pick up one of the newer 40amps y'all are putting out.
Help! Help! Burn the Flysky 9x radio, and now shows me 1.1V on the screen Mc.Daniel Radios 9 Nov 19, 2012 04:36 PM
Question Is there an easy way to test whether ESC or motor is burned out? demuddy Beginner Training Area (Aircraft-Electric) 4 Feb 29, 2012 02:52 AM
Discussion Burned up an ESC, question airbagit13 Electric Plane Talk 11 Jul 31, 2010 10:57 PM
Wanted looking for old broken or burned up BL motors or escs MATTS650 Aircraft - Electric - Power Systems (FS/W) 1 Jan 19, 2009 01:33 PM
Why would an ESC burn up with power but no signal? roccobro Power Systems 25 Jun 30, 2006 01:06 PM
