Old Mar 02, 2013, 09:48 AM
Twinwarbirdflier is offline
Find More Posts by Twinwarbirdflier
Buildin' fool
Twinwarbirdflier's Avatar
Queensbury New York
Joined Dec 2006
I wasnt going to, but I did seal up the retract bay(s), I had time while filler (more filler) was drying. I aslo got the door fit and temp mounted, no close up yet as I have a bit more fitting to do. Final coat of primer on the fuse! Now panel lines and rivots!!
Twinwarbirdflier is offline Find More Posts by Twinwarbirdflier
Old Mar 02, 2013, 10:49 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
So you're about half finished now?
Edwin
edwin1 is offline Find More Posts by edwin1
Old Mar 02, 2013, 11:13 AM
Buildin' fool
Queensbury New York
Joined Dec 2006
Yeah... But the fun stuff is coming!
Old Mar 03, 2013, 08:27 PM
Buildin' fool
Queensbury New York
Joined Dec 2006
Ok, so it's not so much fun...and there's a stink bug on my airplane!
Old Mar 04, 2013, 05:31 AM
CapMike is offline
Find More Posts by CapMike
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Looking good Phil. well except that damn bug doing a wing walk.
CapMike is offline Find More Posts by CapMike
Old Mar 04, 2013, 07:18 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I have those bugs around here, too, but usually in the Fall.
That panel line masking is tedious. The work is worth it, though.
TomCrump is offline Find More Posts by TomCrump
Old Mar 04, 2013, 06:59 PM
Buildin' fool
Queensbury New York
Joined Dec 2006
Damn... I have tomorrow off, gonta get a few coats of primer on her. then lining up the wing
Old Mar 05, 2013, 07:09 AM
Steve Merrill is offline
Find More Posts by Steve Merrill
Steve Merrill's Avatar
USA, IL, St Charles
Joined Nov 2002
What's your plan for the rivots?
Steve Merrill is offline Find More Posts by Steve Merrill
Old Mar 05, 2013, 11:50 AM
Buildin' fool
Queensbury New York
Joined Dec 2006
Lots of them!! I have two methods to apply. The syringe I used on the B25 and Corsair, or the "stylus" thing was lent to me from Norm to try. I'll see which one I can get to be more consistant.
Old Mar 05, 2013, 11:56 AM
Buildin' fool
Queensbury New York
Joined Dec 2006
Love the lines on this bird
Old Mar 05, 2013, 07:59 PM
Buildin' fool
Queensbury New York
Joined Dec 2006
I am sooooo out of practice ....
Old Mar 06, 2013, 06:01 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
You'll get plenty of practice.
That thing is a rivet farm. LOL
Old Mar 06, 2013, 07:29 AM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Originally Posted by tomcrump View Post
that thing is a rivet farm. Lol
lol!
grosbeak is offline Find More Posts by grosbeak
Old Mar 06, 2013, 06:05 PM
Martin5465 is offline
Find More Posts by Martin5465
Martin5465's Avatar
United States, TX, Garland
Joined Mar 2013
DC-3 here also.....
Twinwar, I have a Ziroli DC-3 that I started YEARS ago and now have decided to finally get back to it. Technology has changed so much that I scrapped the entire center wing section I had built a long time ago. Some questions if you have time: Are you using double bellcranks for the ailerons (I started that way)
or are you using two servos in the wing? I'm thinking of using pull/pull for the rudder and elevators....how about you? Probably going to use Robart air retracts. Someone else said they didn't want to spend $600.00 on retracts and then another $300.00 for conversion to electric. I'm not sure how accurate his conversion cost is.
One thing you can't help me with is the decision on rivets. Like another guy said, "That plane is a rivet farm"! The panel lines with tape wouldn't be so bad but all those rivets! Your in-progress pics seem to be a nice compromise between no rivets and the zillions that are actuall on the plane. I'm going to use G-38's also but not sure which props....any suggestions?
There have been several of these birds built in my area (DFW, Texas), but I don't know any of these guys. An in-person look at a complete plane would tell me a lot. I'm fairly new in this area so it looks like I'll have to cultivate some friends!
Martin5465 is offline Find More Posts by Martin5465
Old Mar 06, 2013, 06:34 PM
Buildin' fool
Queensbury New York
Joined Dec 2006
Welp...Let's see. Def servos in the wing. For a bird this big, no bellcranks. the least amount of slop the better. I bought the plane mostly framed up, so the original builder already had pushrods (Sullivan HD) run for the elevators and rudder. I personally would've done a pull pull for the rudder, but didn't have that option.
I'm going to take my time with the rivets and put a few million on, there's nothing like the wow factor at any field you may bring her to. (besides, we still have a few more weeks of crappy weather up here)
I plan on going three bladed http://www.v-eastonline.com/products...x25-cm%29.html
from other build (and fly) threads I've read, the pilots have had the best luck with these. I'm using G38s as well..
You should try to contact the builders in your area, I'm sure you'll find them very helpful. I love to give my $.02 cents worth, which usually becomes $5+, cause I love the hobby so much, I cant shut up about my planes..
Good luck and keep us posted!
Discussion PSU powering 3 reversible ESC + 3 outrunner dc motors causing the PSU to trip. late_fee Power Systems 4 Aug 05, 2012 08:22 AM
Wanted Ziroli DC-3 Short Kit Squeekeron Aircraft - Fuel - Airplanes (FS/W) 1 May 13, 2010 07:23 AM
For Sale FS- 3 NEW HS-81 Servos and 3 new ch56 xtals (hitec DC, GWS UM1, and FMA DC) Etonic Aircraft - General - Radio Equipment (FS/W) 1 May 29, 2005 11:30 AM
Ziroli DC-3 Jungmeisterman Scale Fuel Planes 0 Dec 02, 2004 07:12 PM
