Old Sep 09, 2012, 06:45 PM
Twinwarbirdflier is offline
Find More Posts by Twinwarbirdflier
Buildin' fool
Twinwarbirdflier's Avatar
Queensbury New York
Joined Dec 2006
Build Log
Ziroli DC 3
Hey All, I recently bought a Ziroli DC 3 all framed up, with very little building left to do. Are there any build threads around? (I already did a search here) I was thinking G38s for power as the DC3 isnt a speedster...or shouldnt be any way, but for a big plane, I want to make sure I have the power I need in case of an emergency...
Twinwarbirdflier is offline Find More Posts by Twinwarbirdflier
Old Sep 09, 2012, 08:41 PM
jwellsy is offline
Find More Posts by jwellsy
United States, IL, Champaign
Joined Aug 2012
This may help.
http://www.rcuniverse.com/forum/m_1136542/tm.htm
jwellsy is offline Find More Posts by jwellsy
Old Sep 10, 2012, 06:49 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Around here, the G-38 is the common choice. It provides plenty of power for the Z-DC-3.
TomCrump is offline Find More Posts by TomCrump
Old Sep 10, 2012, 07:45 PM
gordonnora is offline
Find More Posts by gordonnora
United States, PA, Easton
Joined Feb 2010
rcscalebuilder.com under designer, ziroli, has a number of builds....
gordonnora is offline Find More Posts by gordonnora
Old Sep 10, 2012, 08:52 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
We had a guy in the Delaware R/C club years ago,who built one and powered it with Saito 1.80 4strokes......He flew the most interesting pattern routine....a full aerobaticshow,everytime he flew
I've seen him burn a gallon of fuel a day,having more fun than the law allows.
It was painted up as a Camera Company's Executive transport.......If you want to have fun with a large twin,that's IT!
RIP Wayne-we haven't forgotten you.
epoxyearl is offline Find More Posts by epoxyearl
Old Sep 12, 2012, 06:22 PM
Buildin' fool
Queensbury New York
Joined Dec 2006
Thanks all, I found a very good build thread there on rcscalebuilders, he's just about ready for the maiden
Old Oct 13, 2012, 08:26 AM
Buildin' fool
Queensbury New York
Joined Dec 2006
Ok Kids, I'm finally getting started on this HUGE project. I need some input here. As you can see, the original builder,(Norm) didn't opt to build the scale hinges on both the rudder and elevators, now that's not a real issue for me, however, the torque rod for the rudder is right up against the TE of the fin...My question is (and I have a few ideas, but would like other options to consider) is how would you go about installing a control rod on this rudder. she's tight, but should I bend the rod at a 90 degree, solder a arm? ideas? Suggestions?
Thanks in advance!
btw..27 degree this am...yuk!
Old Oct 13, 2012, 09:17 PM
epoxyearl's Avatar
Joined Oct 2011
After watching you work,I'm surprised you aren't adding the scale hinges...Oh come on !-you know you want to....
If you leave it as is,everything will be hidden,so it has to be reliable...I'd opt for a bent torque arm-nothing to work loose or break.slip the point into a brass/aluminum tube,well glued into the structure.
The rudder's easy to move,you just need to guard against accidental bumps.
Old Oct 13, 2012, 09:53 PM
Buildin' fool
Queensbury New York
Joined Dec 2006
Thanks for your reply Earl, I wouldve added scale hinges, but this is how I bought the plane...... I bought her "as is" I trust the builder, however, I'm at a loss as to why he didn't build her with the scale hinges.... So, here I am, looking for input
Old Oct 20, 2012, 09:10 AM
Buildin' fool
Queensbury New York
Joined Dec 2006
Well, I did bend the torque rod, and silver soldered and bound a threaded rod. The problem is, is it sticks out a little more than the siding, not a whole lot, just enough to frustrate me that I didn't see that coming.. I'm still thinking on it...Maybe a small bubble or blister to cover it. I know, not scale, but...
Old Oct 20, 2012, 09:13 AM
Buildin' fool
Queensbury New York
Joined Dec 2006
Hey, How do you Guys feel about the Sullivan HD ny-rod? these were already installed when I bought this bird. She's braced at every former to minimize flex, however a 45# bird... Input anyone?
Old Oct 20, 2012, 06:36 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Are you talking about the yellow inner, and black outer, using 4-40 hardware ?
If so, I use it in almost all my big birds.
Old Oct 20, 2012, 06:54 PM
epoxyearl's Avatar
Joined Oct 2011
Don't worry about 'scale'....If you need that lil' bump put it there....And I wouldn't worry about the large nyrods either...well braced they will be fine.
A 45 lb. airframe doesn't work the servos all that hard,so I wouldn't be overly concerned there either.
Normal care is required to have a safe model...
Old Oct 21, 2012, 06:44 PM
Buildin' fool
Queensbury New York
Joined Dec 2006
Yes Tom and Earl, They are the yellow, with black outer HC pushrods, and thanks for the quick replies. I got the tail section "relatively" blocked, next comes filler, sanding, filler, sanding...etc...
Old Oct 24, 2012, 05:20 PM
Buildin' fool
Queensbury New York
Joined Dec 2006
I know I have a long way to go till painting, but here are a few schemes I'm looking at...
Why be normal..
Discussion PSU powering 3 reversible ESC + 3 outrunner dc motors causing the PSU to trip. late_fee Power Systems 4 Aug 05, 2012 08:22 AM
Wanted Ziroli DC-3 Short Kit Squeekeron Aircraft - Fuel - Airplanes (FS/W) 1 May 13, 2010 07:23 AM
For Sale FS- 3 NEW HS-81 Servos and 3 new ch56 xtals (hitec DC, GWS UM1, and FMA DC) Etonic Aircraft - General - Radio Equipment (FS/W) 1 May 29, 2005 11:30 AM
Ziroli DC-3 Jungmeisterman Scale Fuel Planes 0 Dec 02, 2004 07:12 PM
